CA12062_EMILY-D
CA12062_EMILY-D
    LEDIL(芬兰)
CA12062_EMILY-D 数据手册
PRODUCT DATASHEET CA12062_EMILY-D EMILY-D ~11° diffused spot beam. 14.74 mm high lens. SPECIFICATION: Dimensions Ø 26.0 mm Height 14.7 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length EMILY-D Single lens PMMA clear 26.0 SPUTNIK-TAPE Tape Acrylic foam black 25.0 ORDERING INFORMATION: Component CA12062_EMILY-D » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 1690 260 130 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.5 1/16 PRODUCT DATASHEET CA12062_EMILY-D See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED XB-H FWHM / FWTM 10.0° / 22.0° Efficiency 89 % Peak intensity 17.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM 8.0° / 18.0° Efficiency 92 % Peak intensity 18.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP35 HI FWHM / FWTM 11.0° / 22.0° Efficiency 92 % Peak intensity 14.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED XM-L FWHM / FWTM 14.0° / 27.0° Efficiency 90 % Peak intensity 10.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L2 FWHM / FWTM 14.0° / 27.0° Efficiency 90 % Peak intensity 10.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM 8.0° / 18.0° Efficiency 87 % Peak intensity 27.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 10.0° / 20.0° Efficiency 90 % Peak intensity 20.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G3 FWHM / FWTM 11.0° / 24.0° Efficiency 94 % Peak intensity 13 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 13.0° / 26.0° Efficiency 90 % Peak intensity 10.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED XP-L HI FWHM / FWTM 9.0° / 19.0° Efficiency 87 % Peak intensity 20 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 9.0° Efficiency % Peak intensity 14 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON A FWHM / FWTM 11.0° Efficiency 91 % LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 10.0° Efficiency 91 % LEDs/each optic 1 Light colour/type White Required components: LED NS9x383 FWHM / FWTM 14.0° / 30.0° Efficiency 90 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square EC FWHM / FWTM 9.0° / 20.0° Efficiency 86 % Peak intensity 20.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED LH351B FWHM / FWTM 12.0° / 25.0° Efficiency 88 % Peak intensity 14 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351Z FWHM / FWTM 10.0° / 21.0° Efficiency 88 % Peak intensity 20 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M1/Z5M2 FWHM / FWTM 10.0° / 20.0° Efficiency 94 % Peak intensity 18.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (MEASURED): LED Z8Y22P FWHM / FWTM 11.0° / 24.0° Efficiency 93 % Peak intensity 11.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED XHP35.2 HD FWHM / FWTM 16.0° / 30.0° Efficiency 93 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L HVW FWHM / FWTM 14.0° / 27.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 12.0° / 24.0° Efficiency 95 % Peak intensity 15.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 8.0° / 16.0° Efficiency 91 % Peak intensity 31.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X FWHM / FWTM 12.0° / 24.0° Efficiency 96 % Peak intensity 14.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2Z FWHM / FWTM 10.0° / 22.0° Efficiency 96 % Peak intensity 18.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED LUXEON MZ FWHM / FWTM 14.0° / 28.0° Efficiency 95 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 8.0° / 16.0° Efficiency 95 % Peak intensity 33.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM 10.0° / 18.0° Efficiency 95 % Peak intensity 24.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED LUXEON Z ES FWHM / FWTM 9.0° / 18.0° Efficiency 96 % Peak intensity 28.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 16.0° / 34.0° Efficiency 89 % Peak intensity 6.3 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 10.0° / 20.0° Efficiency 93 % Peak intensity 21.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED NF2x757G FWHM / FWTM 12.0° / 22.0° Efficiency 95 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxE21A FWHM / FWTM 10.0° / 22.0° Efficiency 94 % Peak intensity 18.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 2424 FWHM / FWTM 10.0° / 18.0° Efficiency 96 % Peak intensity 24.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/16 PRODUCT DATASHEET CA12062_EMILY-D OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 9.9° / 20.0° Efficiency 94 % Peak intensity 22.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SFH 4725AS FWHM / FWTM 11.0° / 22.0° Efficiency 95 % LEDs/each optic 1 Light colour/type IR Required components: LED Z5M4 FWHM / FWTM 12.0° / 24.0° Efficiency 96 % Peak intensity 15.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/16 PRODUCT DATASHEET CA12062_EMILY-D GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/16
CA12062_EMILY-D 价格&库存
很抱歉,暂时无法提供与“CA12062_EMILY-D”相匹配的价格&库存,您可以联系我们找货
CA12062_EMILY-D
    • 4+26.95935
    • 32+26.36576
    • 64+25.80029
    库存:260
    CA12062_EMILY-D
    • 130+15.24170
    • 260+14.86055
    • 520+14.63249
    库存:260
