CA14162_TATIANA-1X4-B
    LEDIL(芬兰)
CA14162_TATIANA-1X4-B 数据手册
PRODUCT RELEASE TATIANA – Lens module optimized for Russian roads LEDiL - a global forerunner in the designing and manufacturing of secondary optics for LED lighting introduces TATIANA family of optical modules designed to fulfil and exceed Russian street lighting standards. With the introduction of TATIANA, LEDiL introduces a new adjustable modular platform into the market. TATIANA module consists of four lenses that simply can be snapped apart into single lenses. Lenses have LEDiL standard 25x25mm footprint compatible with existing SQ and 2X2 platforms. This compatibility across the full range simplifies retrofitting into existing luminaires with LEDs. FEATURES • Designed especially to meet Russian street lighting standards. • Optimized for Cree XM-L and 3535 sized high power LEDs. • New 1x4 module size is compatible with the SQ-family. • Module can be snapped into four single lenses which enable upgrading old lighting fixtures and gives more freedom when designing the fixture. • Designed for lighting fixtures with 15° mounting angle. • Suitable also for wire-mounted catenary luminaires. TYPICAL APPLICATIONS • Street lighting on Russian Class A and Class B road classes up to A4 class The information contained herein is the property of LEDiL Oy, Salorankatu 10, FI-24240 SALO, Finland and is subject to change without notice. Please visit www.ledil.com for additional information, such as the latest photometric files, 3D mechancial models, and application notes relating to handling, gluing and taping. TECHNICAL SPECIFICATIONS • Dimensions: 102 x 25 mm • Height: 7,7 mm • Efficiency 95% without the installation tape and 91% with the tape • Easy and accurate mounting with positioning pins • Optional adhesive tape available for easy installing • Module can be snapped into four single lenses compatible with SQ-platform • Precision-molded from optical grade PMMA – UL94 HB rated material with operating rating -40°C to +80°C C14128_TATIANA-1X4-B • Optimized for Cree XM-L and XM-L2 LEDs 105˚ 105˚ 90˚ 90˚ 75˚ 75˚ 60˚ 60˚ 400 45˚ 45˚ 600 800 30˚ 15˚ cd/klm C0 - C180 0˚ C90 - C270 15˚ 30˚ C14128_TATIANA-1X4-B C14161_TATIANA-1X4-B • Optimized for Cree XT-E/XP-G2 DESIGN EXAMPLE Luminaire: C14128_TATIANA-1X4-B_(XM-L2) Eff.95.9% Luminous flux (Luminaire): 9404 lm Luminous flux (Lamps): 9800 lm Luminaire Wattage: 90 W Arrangement: Double row, opposing Pole Distance: 40.000 m Mounting Height: 12.000 m Height: 12.000 m Overhang: 0.853 m Boom Angle: 15.0 ° Boom Length: 1.500 m Maximum luminous intensities at 70°: 447 cd/klm at 80°: 36 cd/klm at 90°: 11 cd/klm ORDERING INFORMATION 0 4.38 8.75 13.13 17.50 21.88 26.25 30.63 35 lx C14128_TATIANA-1X4-B (without tape) C14161_TATIANA-1X4-B (without tape) CA14129_TATIANA-1X4-B (with installation tape) CA14162_TATIANA-1X4-B (with installation tape) Visit www.ledil.com for ordering codes and latest product specifications, which may vary by LED The information contained herein is the property of LEDiL Oy, Salorankatu 10, FI-24240 SALO, Finland and is subject to change without notice. Please visit www.ledil.com for additional information, such as the latest photometric files, 3D mechancial models, and application notes relating to handling, gluing and taping.
CA14162_TATIANA-1X4-B 价格&库存
很抱歉,暂时无法提供与“CA14162_TATIANA-1X4-B”相匹配的价格&库存,您可以联系我们找货
