IF-562
IF-562
    INDUSTRIALFIBER
    PLASTIC FIBER COUPLERS
IF-562 数据手册
Plastic Plastic Fiber Couplers (Splitters) 7/13 Description Fiber couplers, or splitters, are special fiber optic devices with one or more input fibers for distributing optical signals into two or more output fibers. The optical light is passively split into multiple output signals (fibers), each containing light with properties identical to the original except for reduced amplitude. Because the splitter is a passive device it is immune to EMI, consumes no electrical power and does not add noise to system design. The splitter’s passive design is bi-directional and operationally independent of wavelength, constrained only by the physical properties of the PMMA fiber core. Fiber couplers have input and output configurations defined as M×N. M is the number of input ports and is one or greater. N is the number of output ports and is always equal to or greater than M. When there are multiple inputs, output signals are always a combination of the input signals – a coupler can also be considered a combiner. Applications ➤ Feedback Control Circuits Fiber optic couplers or splitters are available in a wide range of styles and sizes to split or combine light with minimal loss. All couplers are manufactured using a very simple proprietary process that produces reliable, low-cost devices. They are physically rugged and insensitive to operating temperatures. Couplers can be fabricated in custom fiber lengths and/or with terminations of any type. ➤ Ethernet and Automotive LANs ➤ Medical Instruments ➤ Automotive Electronics ➤ Optical Sensors Features ➤ Wavelength Multiplexing ◆ Light, Compact Design ➤ Audio Systems ◆ Standard Jacketed 1000 µm Core Plastic Fiber Cable ➤ Electronic Games ◆ High Isolation ◆ Light-Tight Stainless Steel Housing ◆ Low Loss ◆ Excellent Temperature Stability ◆ RoHS Compliant Maximum Ratings (TA =25°C) Operating Temperature Range (TOP)........................-40° to 85°C Storage Temperature Range (TSTG).......................-55°to 85°C Fiber Bending Radius.............25 mm Fiber Tensile Strength.................5 kg Fiber Characteristics (TA =25°C) Material: Fiber couplers are manufactured with Mitsubishi GH4001 1000 µm core jacketed step-index optical fiber. See website for detailed fiber specifications. Parameter Symbol Typ. Max. Unit Fiber Attenuation (650 nm light) – Min. Fiber N/A – – – – Core Refractive Index – – .51 – – Cladding Refractive Index – – – – I ndustrial F iber O ptics , I nc . • www.i-fiberoptics.com – .14 1.492 1.402 .16 dB/m Plastic Plastic Fiber Couplers (Splitters) C HA R A C T E R I S T I C S STOCK NUMBER SPLITTING RATIO % IF-540 PORTS 2 ×2 IF-541 2 ×2 80:20 IF-542 2 ×2 90:10 IF-562 1 ×2 50:50 IF-543 1 ×3 33:33:33 IF-544 4 ×4 25:25:25:25 50:50 INSERTION LOSS (MAX) Port A Port A Port B Port B Port A Port A Port B Port B Port A Port A Port B Port B Port A Port A Port A Port A Port A - Port C 5.6 dB - Port D 3.7 db - Port C 3.7 dB - Port D 5.6 db - Port C 9.9 dB - Port D 2.9 db - Port C 2.9 dB - Port D 9.9 db - Port C 1.5 dB - Port D 2.5 db - Port C 2.4 dB - Port D 1.5 db - Port C 5.6 dB - Port D 3.7 db - Port B 8.2 dB - Port C 8.2 db - Port D 8.2 dB — — EXCESS LOSS (MAX) Port A 1.6 dB Port B 1.6 dB Port A 1.7 dB Port B 1.7 dB Port A 2.0 dB Port B 2.0 dB Port A 1.6 dB Port A 2.2 dB — — All devices are available with ST®, SMA or Versalink fiber terminations. FIGURE 1. Reference measurement - (pre-fused) FIGURE 2. Excess & insertion loss measurement - (post-fused) FIGURE 3. Overall Dimensions for 2 × 2 Coupler I ndustrial F iber O ptics , I nc . • www.i-fiberoptics.com
IF-562
1. 物料型号: - IF-540:2×2分配,50:50比例 - IF-541:2×2分配,80:20比例 - IF-542:2×2分配,90:10比例 - IF-562:1×2分配,50:50比例 - IF-543:1×3分配,33:33:33比例 - IF-544:4×4分配,25:25:25:25比例
2. 器件简介: 光纤耦合器(分光器)是一种特殊的光纤设备,具有一个或多个输入光纤,用于将光信号分配到两个或更多的输出光纤中。这种设备是被动的,因此不受电磁干扰影响,不消耗电能,也不会给系统设计增加噪声。
3. 引脚分配: 耦合器的输入输出配置定义为M×N,其中M是输入端口数(至少为1),N是输出端口数(总是大于或等于M)。当存在多个输入时,输出信号始终是输入信号的组合,耦合器也可以视为合路器。
4. 参数特性: - 工作温度范围:-40°C至85°C - 存储温度范围:-55°C至85°C - 光纤弯曲半径:25mm - 光纤抗拉强度:5kg - 光纤特性参数包括损耗、模数不详、芯折射率、包层折射率等。
5. 功能详解: 光纤耦合器具有轻便紧凑的设计,使用标准带护套的1000µm芯塑料光纤电缆,高隔离度,轻密闭的不锈钢外壳,低损耗,优秀的温度稳定性,符合RoHS标准。
6. 应用信息: 光纤耦合器或分光器可用于反馈控制电路、以太网和汽车局域网、医疗仪器、汽车电子、光学传感器、波长复用、音频系统、电子游戏等多种应用。
7. 封装信息: 所有设备均可配备ST®、SMA或Versalink光纤终端。
IF-562 价格&库存
很抱歉,暂时无法提供与“IF-562”相匹配的价格&库存,您可以联系我们找货
