IF-543
IF-543
    INDUSTRIALFIBER
    PLASTIC FIBER COUPLER
IF-543 数据手册
Plastic Plastic Fiber Couplers (Splitters) 7/13 Description Fiber couplers, or splitters, are special fiber optic devices with one or more input fibers for distributing optical signals into two or more output fibers. The optical light is passively split into multiple output signals (fibers), each containing light with properties identical to the original except for reduced amplitude. Because the splitter is a passive device it is immune to EMI, consumes no electrical power and does not add noise to system design. The splitter’s passive design is bi-directional and operationally independent of wavelength, constrained only by the physical properties of the PMMA fiber core. Fiber couplers have input and output configurations defined as M×N. M is the number of input ports and is one or greater. N is the number of output ports and is always equal to or greater than M. When there are multiple inputs, output signals are always a combination of the input signals – a coupler can also be considered a combiner. Applications ➤ Feedback Control Circuits Fiber optic couplers or splitters are available in a wide range of styles and sizes to split or combine light with minimal loss. All couplers are manufactured using a very simple proprietary process that produces reliable, low-cost devices. They are physically rugged and insensitive to operating temperatures. Couplers can be fabricated in custom fiber lengths and/or with terminations of any type. ➤ Ethernet and Automotive LANs ➤ Medical Instruments ➤ Automotive Electronics ➤ Optical Sensors Features ➤ Wavelength Multiplexing ◆ Light, Compact Design ➤ Audio Systems ◆ Standard Jacketed 1000 µm Core Plastic Fiber Cable ➤ Electronic Games ◆ High Isolation ◆ Light-Tight Stainless Steel Housing ◆ Low Loss ◆ Excellent Temperature Stability ◆ RoHS Compliant Maximum Ratings (TA =25°C) Operating Temperature Range (TOP)........................-40° to 85°C Storage Temperature Range (TSTG).......................-55°to 85°C Fiber Bending Radius.............25 mm Fiber Tensile Strength.................5 kg Fiber Characteristics (TA =25°C) Material: Fiber couplers are manufactured with Mitsubishi GH4001 1000 µm core jacketed step-index optical fiber. See website for detailed fiber specifications. Parameter Symbol Typ. Max. Unit Fiber Attenuation (650 nm light) – Min. Fiber N/A – – – – Core Refractive Index – – .51 – – Cladding Refractive Index – – – – I ndustrial F iber O ptics , I nc . • www.i-fiberoptics.com – .14 1.492 1.402 .16 dB/m Plastic Plastic Fiber Couplers (Splitters) C HA R A C T E R I S T I C S STOCK NUMBER SPLITTING RATIO % IF-540 PORTS 2 ×2 IF-541 2 ×2 80:20 IF-542 2 ×2 90:10 IF-562 1 ×2 50:50 IF-543 1 ×3 33:33:33 IF-544 4 ×4 25:25:25:25 50:50 INSERTION LOSS (MAX) Port A Port A Port B Port B Port A Port A Port B Port B Port A Port A Port B Port B Port A Port A Port A Port A Port A - Port C 5.6 dB - Port D 3.7 db - Port C 3.7 dB - Port D 5.6 db - Port C 9.9 dB - Port D 2.9 db - Port C 2.9 dB - Port D 9.9 db - Port C 1.5 dB - Port D 2.5 db - Port C 2.4 dB - Port D 1.5 db - Port C 5.6 dB - Port D 3.7 db - Port B 8.2 dB - Port C 8.2 db - Port D 8.2 dB — — EXCESS LOSS (MAX) Port A 1.6 dB Port B 1.6 dB Port A 1.7 dB Port B 1.7 dB Port A 2.0 dB Port B 2.0 dB Port A 1.6 dB Port A 2.2 dB — — All devices are available with ST®, SMA or Versalink fiber terminations. FIGURE 1. Reference measurement - (pre-fused) FIGURE 2. Excess & insertion loss measurement - (post-fused) FIGURE 3. Overall Dimensions for 2 × 2 Coupler I ndustrial F iber O ptics , I nc . • www.i-fiberoptics.com
IF-543 价格&库存
很抱歉,暂时无法提供与“IF-543”相匹配的价格&库存,您可以联系我们找货
