Web Site: www.parallax.com
Forums: forums.parallax.com
Sales: sales@parallax.com
Technical: support@parallax.com
Office: (916) 624-8333
Fax: (916) 624-8003
Sales: (888) 512-1024
Tech Support: (888) 997-8267
Parallax Serial LCD
2 rows x 16 characters, Non-backlit, with Piezospeaker (#27976)
2 rows x 16 characters, Backlit, with Piezospeaker (#27977)
4 rows x 20 characters, Backlit, with Piezospeaker (#27979)
The Parallax Serial LCDs are very functional, low-cost liquid crystal displays that can be easily interfaced
to and controlled by a microcontroller using a I/O pin. The LCD displays provide basic text wrapping so
that your text looks correct on the display. Full control over all of their advanced LCD features allows you
to move the cursor anywhere on the display with a single instruction and turn the display on and off in
any configuration. They support visible ASCII characters Dec 32-127, and in addition you may define up
to eight of your own custom characters to display anywhere on the LCD.
NOTE: If your Serial LCD Display does not have a speaker on the back, use the specifications
and information in the Product Change Notice: Revision E and Earlier section on page 11.
Features
Clear 40-pixel characters (8 H x 5 W)
Supports ASCII DEC characters 32-127
Define up to eight custom characters
Automatic text wrapping
Single command cursor placement
Single command clears the display
Select 2400, 9600, or 19,200 baud with switches on
the back of the device
Display type: STN, YG, positive transflective LCD
Adjustable contrast knob on the back of the device
YG LED for backlit model displays
Key Specifications
Power requirements:
o
Non-backlit: +5 VDC, 20 mA
o
Backlit: +5 VDC, 20 mA (light off), ~ 80 mA typical (light on)
Communication: Selectable asynchronous serial baud rates: 2400, 9600, 19200
Operating temperature: -4 to +158 °F (-20 to +70°C)
Dimensions: NOTE - Board and LCD size and style may vary
o
2x16: Approx. 1.42 x 3.15 in (36 x 80 mm)
o
4x20: Approx. 2.37 x 3.86 in (60.2 x 98.1 mm)
Copyright © Parallax Inc.
Parallax Serial LCDs (#27976, 27977, 27979)
v3.1 3/11/2013 Page 1 of 11
Quick-Start Circuit
The Serial LCDs should be powered from an external regulated 5 V power supply. Make sure the power
supply has an adequate current rating to power the Serial LCD and the BASIC Stamp, Propeller chip, or
whichever microcontroller and other devices you are using.
CAUTION
DO NOT PROVIDE A SIGNAL TO THE 'RX' PIN BEFORE APPLYING 5 VDC TO THE '5V' PIN.
Baud Rate Setup
After connecting the Serial LCD, you will need to select the baud rate at which you are going to send it
data. You have three choices: 2400, 9600, and 19,200 baud. To set the baud rate, move the dip switches
on the back of the LCD into the correct positions according to the table next to the switches, which is also
repeated below:
MODE
Test
2,400
9,600
19,200
SW1
OFF
ON
OFF
ON
SW2
OFF
OFF
ON
ON
As you can see from the table, there is also a fourth choice called Test. Use this Test mode to confirm
that the power and ground to the LCD are hooked up correctly before you send it any data. Move the dip
switches to the Test setting and turn on the power. The LCD display should turn on with the backlight on
(models 27977, 27979) and display the following text:
Parallax, Inc.
www.parallax.com
If you don’t see the text at first, try adjusting the LCD contrast by turning the pot labeled “Increase
Contrast” with a screwdriver. Turn it in the direction of the arrow to make the characters show up more
clearly. If you still don’t see the characters, go back and check your electrical connections and try again.
Once you’ve successfully completed test mode, move the dip switches to the correct positions to select
the baud rate you want to use for your application.
v3.1 3/11/2013 Page 2 of 11
Displaying Text
Now that the LCD is set up, it’s time to start sending text to the display. To display a character of text on
the Serial LCD, simply send the ASCII code of that character to the Serial LCD over the serial port at the
correct baud rate.
When a character is received, the Serial LCD displays that character at the current cursor position and
then moves the cursor one position to the right. When you first turn on the LCD, the cursor is in the
leftmost position on the top line, as you might expect. The short bar on the bottom of the character
shows where the cursor is positioned currently.
Once you’ve sent a full line characters to the LCD, you will notice that the cursor automatically wraps
around to the leftmost position of the second line, just like the text in a book. The text will wrap like this
at the end of every line, with the end of the bottom line wrapping back around to the top line of the LCD.
The text will never “run off” the display; you’ll always see all of the characters you send.
Example code is provided below. You may download the example code files from the 27976, 27977, or
27979 product pages at www.parallax.com; just enter any of these product numbers in the “search” field
on the home page
BASIC Stamp® 2 Example Code
You may download the example code from the 27976, 27977, or 27979 product pages at
www.parallax.com; just enter any of these product numbers in the “search” field on the home page. Try
the following code on your BASIC Stamp 2 to send a text string to the LCD display. First, set the baud
rate on your Serial LCD to 19,200. Then, load the code below into your BASIC Stamp 2 and run it.
You will see the text string show up and wrap to the second line of the display.
In all of your Serial LCD code, you should pause for 100 ms at start-up to give time for the Serial LCD to
initialize. You should also set the serial port pin on the BASIC Stamp to HIGH before the 100 ms start-up
delay, as this is the normal state of a serial port when it isn’t sending any data.
' {$STAMP BS2}
' {$PBASIC 2.5}
TxPin
Baud19200
CON
CON
HIGH TxPin
PAUSE 100
' Set pin high to be a serial port
' Pause for Serial LCD to initialize
SEROUT TxPin, Baud19200, ["Hello, this text will wrap."]
Propeller P8X32A Example Code
Try the following code on your Propeller to send a text string to the LCD display. First, set the baud rate
on your Serial LCD to 19,200. Then, load the code below into your Propeller and load RAM or EEPROM.
In all of your Serial LCD code, you should wait for 100 ms after starting the FullDuplexSerial.spin object,
to give the object and the Serial LCD time to initialize. The FullDuplexSerial.spin object is included with
the Propeller Tool.
v3.1 3/11/2013 Page 3 of 11
Serial_LCD_Demo.spin
For Parallax Serial LCDs 27976, 27977, 27979
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
TX_PIN = 0
BAUD = 19_200
OBJ
LCD : "FullDuplexSerial.spin"
PUB Main
LCD.start(TX_PIN, TX_PIN, %1000, 19_200)
waitcnt(clkfreq / 100 + cnt)
' Pause for FullDuplexSerial.spin to initialize
LCD.str(string("Hello, this text will wrap."))
Moving the Cursor
When you send a character to the Serial LCD, it always displays at the current cursor position. There are
a few different ways to move the cursor on the Serial LCD display. After each character you send, the
cursor automatically moves over one position. Along with this, there is a standard set of cursor move
commands including Backspace, Carriage Return, and Line Feed.
The Backspace/Left command (Dec 8) moves the cursor one place to the left and the Right command
(Dec 9) moves the cursor one place to the right. These can be useful for moving the cursor around to
overwrite existing text. These commands wrap to the next line of the display, if necessary. The Line Feed
command (Dec 10) moves the cursor to the next line of the display without changing the horizontal
position of the cursor. The Carriage Return command (Dec 13) also moves the cursor to the next line, but
it moves the cursor to the leftmost position on that line as well. The Form Feed command (Dec 12) clears
the entire display and moves the cursor to the leftmost position on line 0, just like when you first turn on
the display. You will need to pause for 5mS in your code after sending the Form Feed command, to give
the Serial LCD time to clear the display. Except for Form Feed, none of these move commands affects the
characters on the display.
There are also direct move commands that you can use to move the cursor to any position on the display
with a single command. The commands in the range Dec 128 to 143 and Dec 148 to 163 move the cursor
to the 16 different positions on each of the two lines of the model 27976 and 27977 LCDs. The
commands in the range Dec 128 to 207 move the cursor to the 20 different positions on each of the four
lines of the model 27979 LCD.
Controlling the Display
You also have control over the various display modes of the Serial LCD. The display-off command (Dec
21) turns off the display so that all of the characters disappear. The characters aren’t erased from the
display, though, and you can even keep writing new characters to the display when it is turned off. A
trick to make a lot of text show up all at once, even at a slow baud rate, is to turn off the display and
then send all of your text. Then, when you turn the display on again, all of the text appears instantly.
v3.1 3/11/2013 Page 4 of 11
The display-on commands (Dec 22 to 25) turn the display back on and also control whether you want to
display the cursor and/or make the cursor character blink. The cursor is the short bar that shows up
below the character at the current cursor position. The blink option makes that character blink on and off
repeatedly. You can turn the cursor and blink options on or off, in any combination, as listed in the
command set table. You can change the cursor and blink mode even if the display is already on; you
don’t need to turn it off and then back on again.
With models 27977 and 27979, you can also control the backlight of the display. The backlight lights up
the display so that it is easier to see in the dark. There are commands to turn the backlight on (Dec 17)
and off (Dec 18).
Custom Characters
The Serial LCD has the capability to store up to eight user-defined custom characters. The custom
characters are stored in RAM and so they need to be redefined if you turn off the power. You can display
the custom characters by sending the commands Dec 0 to 7, as shown in the command set table. The
custom character will display at the current cursor position.
The custom characters are five pixels wide by eight pixels high. Each of the characters is stored as a
series of eight data bytes where the low five bits of each byte represent a row of pixels in the character.
The high three bits of each byte are ignored. A bit value of one turns that pixel on (i.e. makes it black).
The bottom row of pixels is often left blank (all zeros) to make it easier to see the cursor.
To define a custom character, you will send a total of 9 bytes to the Serial LCD. The first byte needs to
be a valid define-custom-character command (Dec 248 to 255) and must be followed by eight data bytes
that define the pixels of the character. The Serial LCD will always use the next eight bytes it receives to
set the pixels of the character. The data bytes define the character starting at the topmost row of pixels,
as shown in the example code.
BASIC Stamp 2 Custom Character Example
Define a custom character using the code example below. First, set the baud rate on your Serial LCD to
19,200. Then, load the code below into your BASIC Stamp 2 and run it. You will see a diamond character
appear on the screen.
' {$STAMP BS2}
' {$PBASIC 2.5}
TxPin
Baud19200
CON
CON
HIGH TxPin
PAUSE 100
SEROUT TxPin, Baud19200, [250]
SEROUT
SEROUT
SEROUT
SEROUT
SEROUT
SEROUT
SEROUT
SEROUT
SEROUT
TxPin,
TxPin,
TxPin,
TxPin,
TxPin,
TxPin,
TxPin,
TxPin,
TxPin,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
Baud19200,
[%00000]
[%00100]
[%01110]
[%11111]
[%01110]
[%00100]
[%00000]
[%00000]
[2]
Define custom character 2
Now send the eight data bytes
%00000 =
%00100 = *
%01110 = * * *
%11111 = * * * * *
%01110 = * * *
%00100 = *
%00000 =
%00000 =
Display the new custom character 2
v3.1 3/11/2013 Page 5 of 11
Propeller™ P8X32A Example Code
19,200. Then, load the code below into your Propeller and load RAM or EEPROM. You will see a diamond
character appear on the screen. Note: the FullDuplexSerial.spin object is included with the Propeller Tool
software.
Serial_LCD_Custom_Character.spin
CON
TX_PIN = 0
BAUD = 19_200
OBJ
PUB Main
LCD.tx(250)
LCD.tx(%00000)
LCD.tx(%00100)
LCD.tx(%01110)
LCD.tx(%11111)
LCD.tx(%01110)
LCD.tx(%00100)
LCD.tx(%00000)
LCD.tx(%00000)
LCD.tx(2)
%00000 =
%00100 = *
%01110 = * * *
%11111 = * * * * *
%01110 = * * *
%00100 = *
%00000 =
%00000 =
Playing Music
The Serial LCD has a built-in piezoelectric speaker which can play musical notes. The LCD includes a
sophisticated music player enabling users to program songs and tunes. You can play musical notes by
sending three types of note commands (Dec 214 to 232), as shown in the command set table.
Set Length
The “set length” commands (Dec 208 to 214) determines the length of time each note will play for. This
value remains the same until another “set length” command is received. A note’s length can range from
a 1/64th note to a whole note. A whole note is 2 seconds long.
v3.1 3/11/2013 Page 6 of 11
Set Scale
The “set scale” commands (Dec 215 to 219) determines the octave each note will play in. This value
remains the same until another “set scale” command is received. The current octave can be set to a
value between 3 and 7, and each octave consists of 12 notes. The frequency for each note and scale
combination is shown in the table below.
Scale
3
4
5
6
7
A
220
440
880
1760
3520
A#
233
466
932
1865
3729
B
247
494
988
1976
3951
C
262
523
1047
2093
4186
C#
277
554
1109
2217
4435
D
294
587
1175
2349
4699
D#
311
622
1245
2489
4978
E
330
659
1319
2637
5274
F
349
698
1397
2794
5588
F#
370
740
1480
2960
5920
G
392
784
1568
3136
6272
G#
415
831
1661
3322
6645
Play Note
The “play note” commands (Dec 220 to 232) play a single note for the currently set time and in the
currently set octave.
Command Set
The tables on the following pages list all of the valid Serial LCD commands. Commands marked as N/A
are invalid and are ignored. The lines of the LCD display are numbered starting from 0, with line 0 being
the top line. The character positions on each line are numbered starting from 0, with position 0 being the
leftmost position on the line.
Dec
Hex
Action
2
3
4
5
6
7
00
01
02
03
04
05
06
07
8
08
9
09
10
0A
Dec
Hex
Display custom character 0
Display custom character 1
Display custom character 2
Display custom character 3
Display custom character 4
Display custom character 5
Display custom character 6
Display custom character 7
Backspace / Left - The cursor is moved one position to the left. The
command doesn’t erase the character.
Right - The cursor is moved one position to the right. The
Line Feed - The cursor is moved down one line. For the two line
LCD model, if on line 0 it goes to line 1. If on line 1, it wraps
around to line 0. The horizontal position remains the same.
Action
11
0B
12
0C
13
0D
14 - 16
17
0E - 10
11
N/A
Form Feed - The cursor is moved to position 0 on line 0 and the
entire display is cleared. Users must pause 5mS after this
command.
Carriage Return – For the two line LCD model, if on line 0 the cursor
is moved to position 0 on line 1. If on line 1, it wraps around to
position 0 on line 0.
N/A
Turn backlight on (only on models 27977, 27979)
v3.1 3/11/2013 Page 7 of 11
Dec
Hex
Action
18
19 - 20
21
22
23
24
25
26 - 31
32 - 127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
12
13 - 14
15
16
17
18
19
1A - 1F
20 - 7F
80
81
82
83
84
85
86
87
88
89
8A
8B
8C
8D
8E
8F
90
91
92
93
94
95
96
97
98
99
9A
9B
9C
Turn backlight off (Default)
N/A
Turn the display off
Turn the display on, with cursor off and no blink
Turn the display on, with cursor off and character blink
Turn the display on, with cursor on and no blink (Default)
Turn the display on, with cursor on and character blink
N/A
Display ASCII characters. See the ASCII character set table.
Move cursor to line 0, position 0
Move cursor to line 0, position 1
Move cursor to line 0, position 2
Move cursor to line 0, position 3
Move cursor to line 0, position 4
Move cursor to line 0, position 5
Move cursor to line 0, position 6
Move cursor to line 0, position 7
Move cursor to line 0, position 8
Move cursor to line 0, position 9
Move cursor to line 0, position 10
Move cursor to line 0, position 11
Move cursor to line 0, position 12
Move cursor to line 0, position 13
Move cursor to line 0, position 14
Move cursor to line 0, position 15
Move cursor to line 0, position 16 (only on model 27979)
Move cursor to line 0, position 17 (only on model 27979)
Move cursor to line 0, position 18 (only on model 27979)
Move cursor to line 0, position 19 (only on model 27979)
Move cursor to line 1, position 0
Move cursor to line 1, position 1
Move cursor to line 1, position 2
Move cursor to line 1, position 3
Move cursor to line 1, position 4
Move cursor to line 1, position 5
Move cursor to line 1, position 6
Move cursor to line 1, position 7
Move cursor to line 1, position 8
Dec
Hex
Action
157
158
159
160
161
162
163
9D
9E
9F
A0
A1
A2
A3
Move
Move
Move
Move
Move
Move
Move
cursor
cursor
cursor
cursor
cursor
cursor
cursor
to
to
to
to
to
to
to
line
line
line
line
line
line
line
1,
1,
1,
1,
1,
1,
1,
position
position
position
position
position
position
position
9
10
11
12
13
14
15
v3.1 3/11/2013 Page 8 of 11
Dec
Hex
Action
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
A4
A5
A6
A7
A8
A9
AA
AB
AC
AD
AE
AF
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
BA
BB
BC
BD
BE
BF
C0
C1
C2
C3
C4
C5
C6
C7
C8
C9
CA
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Move
Dec
Hex
Action
203
204
205
206
207
208
CB
CC
CD
CE
CF
D0
Move cursor to line 3, position
Set note length to 1/64 note
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
cursor
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
line
1,
1,
1,
1,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
2,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
3,
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
position
0 (only on model 27979)
1 (only on model 27979)
2 (only on model 27979)
3 (only on model 27979)
4 (only on model 27979)
5 (only on model 27979)
10 (only on model 27979)
11 (only on model 27979)
12 (only on model 27979)
13 (only on model 27979)
14 (only on model 27979)
15 (only on model 27979)
15
16
17
18
19
(only
(only
(only
(only
(only
on
on
on
on
on
model
model
model
model
model
27979)
27979)
27979)
27979)
27979)
v3.1 3/11/2013 Page 9 of 11
Dec
Hex
Action
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233 - 247
D1
D2
D3
D4
D5
D6
D7
D8
D9
DA
DB
DC
DD
DE
DF
E0
E1
E2
E3
E4
E5
E6
E7
E8
E9 – F7
248
F8
249
F9
250
FA
251
FB
252
FC
253
FD
254
FE
255
FF
Set note length to 1/32 note
Set note length to 1/16 note
Set note length to 1/8 note
Set note length to 1/4 note
Set note length to 1/2 note
Set note length to whole note (2 seconds)
Select the 3rd scale (A = 220 Hz)
Select the 4th scale (A = 440 Hz)
Select the 5th scale (A = 880 Hz)
Select the 6th scale (A = 1760 Hz)
Select the 7th scale (A = 3520 Hz)
Play A note
Play A# note
Play B
Play C
Play C#
Play D
Play D#
Play E
Play F
Play F#
Play G
Play G#
Pause for current note length (no sound)
N/A
Define custom character 0. This command
eight data bytes.
Define custom character 1. This command
eight data bytes.
Define custom character 2. This command
eight data bytes.
Define custom character 3. This command
eight data bytes.
Define custom character 4. This command
eight data bytes.
Define custom character 5. This command
eight data bytes.
Define custom character 6. This command
eight data bytes.
Define custom character 7. This command
eight data bytes.
must be followed by
must be followed by
must be followed by
must be followed by
must be followed by
must be followed by
must be followed by
must be followed by
v3.1 3/11/2013 Page 10 of 11
If your Serial LCD Display does not have a piezospeaker on the back and looks similar to the image
above, please use the following information and specifications when using this product. All connections,
test code and commands remain the same, except for commands controlling the piezospeaker.
Key Specifications
Power requirements:
o
o
Backlit: +5 VDC, 20 mA (light off), 80 mA (light on)
Dimensions: Board and LCD size and style may vary
o
2x16: Approx. 1.5 x 3.15 in (38 x 80 mm)
o
4x20: Approx. 2.4 x 3.9 in (60 x 100 mm)
REV E CAUTION: DO NOT PROVIDE A SIGNAL TO THE ‘RX’ PIN BEFORE APPLYING 5 VDC TO THE ‘5V’
PIN.
Revision History
Version 3.1: corrected current draw specification on Page 1 from 50 mA to 80 mA.
v3.1 3/11/2013 Page 11 of 11
