Developed for use in a wide range of industrial and commercial applications, this integrated keypad and optional display is ideal for
use in exposed, hostile or public environments. The display type can be specified to suit most applications.
The optional LCD display module is securely located behind a coated, scratch resistant water sealed polycarbonate window.
Generous provision is made for the locatin of interface and encoding circuitry on the rear face of the keypad.
The FT Integrated Keypad can also be specified with the unique Storm ‘Graphics’ keytop technology. These innovative keytops
enable customization of keytop characters and colours (even in low quantities). Please refer to the Storm ‘Graphics Series’
keypads datasheet for more information and Storm’s ‘Graphics’ keytop technology.
• Weather and vandal resistant for outdoor and
unsupervised public environments
• Optional 20 character x 4 line, illuminated LCD display
• Rapid, responsive and reliable data entry
• Stainless steel front plate
• Available with high impact polymer or chromed metal
keys
• Easily and securely installed in vending machines, carwash controllers, public telephones, ticketing machines,
gasoline pumps and car-parking control equipment
Electrical
Contact Bounce
Contact Resistance
Insulation Resistance
Breakdown Voltage
Operating Voltage
Operating Current
Mechanical
Operational Life
Keytop Travel
Actuation Force
Connector
5ms (max)
100 ohms (max)
50 Mohms (min)
500V AC (max 60 secs.)
24V DC (max)
50mA (max)
4 million cycles (min) per key
1.4mm nominal
180gms nominal
0.1" pitch, gold plated square pin, male
Environmental
Water/Dust Sealed
Operational Temperature
Material
Chassis
Front Panel
Keytops
IP65 (when mounted to suitable enclosure)
-20°C to +60°C (dry)
Super High Impact Polymer (black)
Stainless Steel
Engraved chromed die-cast zinc, laser printed black polymer
or 'Graphic'
Gold on Nickel plated FR4
Contact Circuit
FT Range
Item
Chromed metal keys, no LCD
Chromed metal keys,with LCD
Polymer keys, no LCD
Polymer keys, with LCD
Graphic keys, no LCD
Graphic keys, with LCD
Accessories
Item
Mountng kit
Part Number
FTMK010
PC Interface
Ribbon cable
4200-00
4200-10
Part Number
FT1K050
FT1K080
FT2K050
FT2K080
FT4K100
FT4K090
Notes
Includes gasket &
frame
RS-232 encoder
Ribbon cable for
connection to encoder
很抱歉,暂时无法提供与“5001-200203”相匹配的价格&库存,您可以联系我们找货
