SCE5744
SCE5744
    AMSOSRAM(艾迈斯半导体)
    PDIP
    DISPLAY 4CHAR 5X7 SER HE GRN DIP
SCE5744 数据手册
0.180’’ 4-Character 5x7 Dot Matrix Serial Input Dot Addressable Intelligent Display® Devices Lead (Pb) Free Product / RoHS Compliant SCE574x Standard Red SCE5740 Green SCE5743 SCE574xP-SIP SCE574xQ-SIP with right angle bends Yellow SCE5741 High Efficiency Green SCE5744 DESCRIPTION ALSO AVAILABLE WITH OPTIONS (see page 8) • SCE574xP-SIP • SCE574xQ-SIP with right angle bends The SCE574x is a four digit, dot addressable 5 x 7 dot matrix, serial input, alphanumeric Intelligent Display device. The four digits are packaged in a rugged, high quality, optically transparent, plastic 14 pin DIP with 2.54 mm (0.1") pin spacing. FEATURES • Four 4.57 mm (0.180") 5 x 7 Dot Matrix Characters in Red, Yellow, Super-red, Green, High Efficiency Green, Orange • Optimum Display Surface Efficiency (display area to package ratio) • High Speed Data Input Rate: 5.0 MHz • ROMless Serial Input, Dot Addressable Display Ideal for User Defined Characters • Built-in Decoders, Multiplexers and LED Drivers • Wide Viewing Angle, X Axis ± 55°, Y Axis ± 55° The SCE574xP is a SIP version of SCE574x. The SCE574xQ is also a SIP version of the SCE574x but the leads are at right angles to the package so that the part can be mounted vertically. The SIP version parts have only 7 pins. The SIP parts do not have the option of using an external clock. All the electrical descriptions for the SCE574x apply to the SIP versions except the allusions to the external clock. The on-Board CMOS has a 140 bit RAM, one bit associated with one LED, each to generate User Defined Characters. In Power Down Mode, quiescent current is < 50 µA. ATTRIBUTES – 140 Bit RAM for User Defined Characters – Eight Dimming Levels plus eight fine dimming levels. – Power Down Model (< 250 mW) – Hardware/Software Clear Functions – External Clock-SCE574x only The SCE574x is designed for work with the serial port of most common microprocessors. Data is transferred into the display through the Serial Data Input (DATA), clocked by the Serial Data Clock (SDCLK), and enabled by the Load Input (LOAD). The SCE574x Clock I/O (Clk I/O) and Clock Select (CLKSEL) pins offer the user the capability to supply a high speed external multiplex clock. This feature can minimize audio in-band interference for portable communication equipment or eliminate the visual synchronization effects found in high vibration environments such as avionic equipment. A divide by 16 prescalar is built into the part and can be accessed by software to reduce the multiplex frequency if a high speed external clock is used. 2006-03-30 Super-red SCE5742 Orange SCE5745 1 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Ordering Information Type Color of Emission SCE5740 standard red Q68100A1369 SCE5741 yellow Q68100A1370 SCE5742 super-red SCE5743 green SCE5744 high efficiency green Q68100A1373 SCE5745 orange Q68100A1374 2006-03-30 Q68100A1372 4.57 (0.180) 19.91 (0.784) IDOD5006 2 Ordering Code Q68100A1371 4.57 (0.180) Dimensions in mm (inch) 10.16 (0.400) ±0.38 (0.015) Package Outlines Character Height mm (inch) SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Maximum Ratings Parameter Symbol Value Unit Operating temperature range Top – 40 … + 85 °C Storage temperature range Tstg – 40 … + 100 °C DC Supply Voltage VCC -0.5 to + 7.0 V -0.5 to VCC +0.5 V 260 °C 85 % 2.0 kV Input Current 130 mA Maximum Number of LEDs on at 100% Brightness 64 Maximum Power Dissipation 0.6 Input Voltage Levels Relative to GND Solder Temperature 1.59 mm (0.063“) below seating plane, t < 5.0 s TS Relative Humidity ESD (100 pF, 1.5 kΩ) VZ W Optical Characteristics at 25°C (VCC=5.0 V at 100% brightness level, viewing angle: X axis ± 55°, Y axis ± 65°) Green SCE5743 High Efficiency Green SCE5744 Orange SCE5745 Unit Super-red SCE5742 Values Yellow SCE5741 Symbol Red SCE5740 Description Luminous Intensity (min.) IV (typ.) 30 60 60 150 60 150 60 150 80 180 60 150 µcd/dot µcd/dot Peak Wavelength (typ.) λpeak 655 583 630 565 568 605 nm Dominant Wavelength (typ.) λdom 639 585 620 573 574 610 nm Notes: 1. Dot to dot intensity matching at 100% brightness is 1.8:1. 2. Displays within a given intensity category have an intensity matching of 1.5:1 (max.). 2006-03-30 3 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Electrical Characteristics (over operating temperature) Parameter Min. Typ. Max. Units Conditions VCC 4.5 5.0 5.5 V — ICC (Power Down) 1) 2) — — 50 µA VCC=5.0 V, all inputs=0 V or VCC ICC 4 digits 20 dots/character3) 90 115 130 mA VCC=5.0 V, “#” displayed in all 4 digits at 100% brightness at 25°C IIL Input current — — –10 µA VCC=5.0 V, VIN=0 (all inputs) IIH Input current — — 10 µA VCC=VIN=5.0 V (all inputs) VIH 3.5 — — V VCC=4.5 V to 5.5 V VIL — — 1.5 V VCC=4.5 V to 5.5 V Row Multiplex Rate 375 768 1086 Hz — θJC-pin — — 45 °C/W — Notes: 1) Unused inputs must be tied high. 2) External oscillator must be stopped. 3) Peak current 5/3 x ICC. Electrical Characteristics for SCE574x only Parameter Min. Typ. Max. Units Conditions IOH (CLK I/O) — –28 — mA VCC=4.5 V, VOH=2.4 V IOL (CLK I/O) — 23 — mA VCC=4.5 V, VOL=0.4 V Fext External Clock Input Frequency 120 — 3 MHz VCC=5.0 V, CLKSEL=0 Fosc Internal Clock Input Frequency 120 — 347 kHz VCC=5.0 V, CLKSEL=1 Clock I/O Bus Loading — — 240 pF — Clock Out Rise Time — — 500 ns VCC=4.5 V, VOH=2.4 V Clock Out Fall Time — — 500 ns VCC=4.5 V, VOH=0.4 V Input/Output Circuits Figures „Inputs“ and „Clock I/O“ show the input and output resistor/diode networks used for ESD protection and to eliminate substrate latch-up caused by input voltage over/under shoot. Inputs Clock I/O (SCE574X only) VCC Input VCC 1 kΩ input/output 1 KΩ GND GND IDCD5021 2006-03-30 4 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Switching Specifications (over operating temperature range and VCC=4.5 V to 5.5 V) Symbol Description Min. Units Description Min. Units TRC Reset Active Time 600 ns TSDCW Symbol Clock Width 70 ns TLDS Load Setup Time 50 ns TLDH Load Hold Time 0 ns TDS Data Setup Time 50 ns TDH Data Hold Time 25 ns TSDCLK Clock Period 200 ns TWR Total Write Time 2.2 µs TBL Time Between Loads 600 ns Note: TSDCW is the minimum time the SDCLK may be low or high. The SDCLK period must be a minimum of 200 ns. Timing Diagram—Data Write Cycle T LDS LOAD T DS DATA TLDH D0 D7 TDH SDCLK T SDCW T SDCLK Timing Diagram—Instruction Cycle TWR TBL LOAD SDCLK DATA D0 D1 D2 D3 D4 D5 D6 D7 D0 D4 D5 D6 D7 D0 OR LOAD SDCLK DATA 2006-03-30 D0 D1 D2 D3 5 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Top View Pin Definitions 14 Digit 0 Pins Digit 1 1 8 Digit 2 Pin Function Definitions 1 VCC Power supply 2 LOAD Low input enables data clocking into 8-bit serial shift register. When LOAD goes high, the contents of 8-bit serial Shift Register will be decoded. Digit 3 3 DATA Serial data input 7 4 N/C no connection 5 SDCLK for loading data into the 8-bit serial data register 6 RST Asynchronous input, when low clears the Multiplex Counter, Control Word Register, User RAM and Data Register. Control Word Register is set to 100% brightness. The display will be blank. Pins IDPA5105 Pin Assignment Pin Function Pin Function 1 VCC 14 CLK SELECT 2 LOAD 13 no pin 7 GND Supply ground 3 DATA 12 no pin 8 CLK I/O Outputs master clock or inputs external clock. 4 no connection 11 no pin 9 N/P No pins 5 SDCLK 10 no pin 10 N/P No pins 6 RST 9 no pin 11 N/P No pins 7 GND 8 CLK I/O 12 N/P No pins 13 N/P No pins 14 CLKSEL H=internal clock, L=external clock Dot Matrix Format C1 C2 C3 C4 C5 Display Column and Row Format R0 R1 R2 0.23 (0.009) typ. R3 6.86 (0.270) 1.09 (0.043) typ. 4.45 (0.175) R4 C0 C1 C2 C3 C4 Row 0 1 1 1 1 1 Row 1 0 0 1 0 0 Row 2 0 0 1 0 0 Row 3 0 0 1 0 0 Row 4 0 0 1 0 0 Row 5 0 0 1 0 0 Row 6 0 0 1 0 0 1= Display dot „ON“ 0=Display dot „OFF“ R5 R6 Column Data Ranges 1.14 (0.045) typ. Tolerance: ±0.25 (0.010) Row 0 00H to 1FH Row 4 00H to LFH Row 1 00H to LFH Row 5 00H to LFH Row 2 00H to LFH Row 6 00H to LFH Row 3 00H to LFH IDOD5013 Dimensions in inches (mm) 2006-03-30 6 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Block Diagram RST DATA SDCLK LOAD OSC 64 Counter Y Address Decode CLKSEL 8-bit Serial Register CLK I/O 7 Counter MUX Rate Column Drivers Digit 0 to 4 User RAM Memory 7 x 20 bits Row Control Logic and Row Drivers Rows 0 to 6 Display Column 0 to 20 0 1 2 3 X Address Decode 3-bit Address Register 6-bit Control Word Register Control Word Logic Operation of the SCE574x The SCE574x display consists of a CMOS IC containing control logic and drivers for four 5 x 7 characters. These components are assembled in a compact plastic package. Individual LED dot addressability allows the user great freedom in creating special characters or mini-icons. The serial data interface provides a highly efficient interconnection between the display and the mother board. The SCE574x requires only three lines as compared to 14 lines for an equivalent four character parallel input part. The on-board CMOS IC is the electronic heart of the display. The IC accepts decoded serial data, which is stored in the internal RAM. Asynchronously the RAM is read by the character multiplexer at a strobe rate that results in a flicker free display. Figure „Block Diagram“ (page 7) shows the three functional areas of the IC. These include: the input serial data register and control logic, a 140 bits two port RAM, and an internal multiplexer/display driver. 2006-03-30 IDBD5063 The following explains how to format the serial data to be loaded into the display. The user supplies a string of bit mapped decoded characters. The contents of this string is shown in Figure „Loading Serial Character Data a“ (page 8). Figure „Loading Serial Character Data b“ (page 8) shows that each character consist of eight 8 bit words. The first word encodes the display character location and the succeeding five bytes are row data. The row data represents the status (On, Off) of individual column LEDs. Figure „Loading Serial Character Data c“ (page 8) shows that each 8 bit word is formatted to represent Column Data or Character Address. Figure „Loading Serial Character Data d“ (page 8) shows the sequence for loading the bytes of data. Bringing the LOAD line low enables the serial register to accept data. The shift action occurs on the low to high transition of the serial data clock (SDCLK). The least significant bit (D0) is loaded first. After eight clock pulses the LOAD line is brought high. With this transition the OPCODE is decoded. The decoded OPCODE directs D4–D0 to be latched in the Character Address register, stored in the RAM as Column data, or latched in the Control Word register. The control IC requires a minimum 600 ns delay between successive byte loads. 7 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Loading Serial Character Data Example: Serial Clock=5.0 MHz, Clock Period=200 ns 352 Clock Cycles, 70.4 µs a. Character 0 Character 1 Character 2 Character 3 88 Clock Cycles, 17.6 µs Character 0 Address b. Row 0 Row 1 Row 2 Row 3 Row 4 Column Data Column Data Column Data Column Data Column Data 11 Clock Cycles, 2.2 µs Row 6 Column Data 11 Clock Cycles, 2.2 µs Time Character Address OPCODE D0 D1 D2 D3 D4 D5 D6 D7 Between Loads 0 0 0 0 0 1 0 1 600ns(min) c. Row 5 Column Data Time Column Data OPCODE D0 D1 D2 D3 D4 D5 D6 D7 Between Loads 0 0 600ns(min) D D D D D 0 LOAD Clock Period Serial Clock DATA d. D0 D1 D2 D3 D4 D5 D6 D7 Time between Loads t0 Table „Character ’D’“ (page 8) shows the Row Address for the example character “D.” Column data is written and read asynchronously from the 140 bit RAM. Once loaded the internal oscillator and character multiplexer reads the data from the RAM. These characters are row strobed with column data as shown in Figures „Row and Columns Locations for a Character ’D’“ (page 8) and „Row Strobing“ (page 9). The character strobe rate is determined by the internal or user supplied external MUX Clock, the IC’s counter and the prescaler. Row and Column Locations for a Character “D” Off LED Row 1 On LED Row 2 Character “D” Row 3 Op code D7 D6 D5 Column Data D4 D3 D2 C0 C1 C2 D1 C3 D0 C4 Row 0 0 0 0 1 1 1 1 0 1E Row 1 0 0 0 1 0 0 0 1 11 Row 2 0 0 0 1 0 0 0 1 11 Row 3 0 0 0 1 0 0 0 1 11 Row 4 0 0 0 1 0 0 0 1 11 Row 5 0 0 0 1 0 0 0 1 11 Row 6 0 0 0 1 1 1 1 0 1E 2006-03-30 Row 0 Hex Row 4 Row 5 Row 6 0 1 2 3 Columns 4 IDXX5183 8 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Row Strobing Row Load Load Row 0 Load Row 1 Load Row 2 Load Row 3 Load Row 4 Load Row 5 Load Row 6 0 0 0 0 0 0 0 1 1 1 1 1 1 1 2 2 2 2 2 2 2 3 3 3 3 3 3 3 4 4 4 4 4 4 4 5 5 5 5 5 5 6 6 0 1 2 3 4 Columns 6 0 1 2 3 4 Columns 6 0 1 2 3 4 Columns 6 0 1 2 3 4 Columns 5 6 0 1 2 3 4 Columns 6 0 1 2 3 4 Columns 0 1 2 3 4 Columns IDXX5184 Multiplexer and Display Driver The four characters are row multiplexed with RAM resident column data. The strobe rate is established by the internal or external MUX Clock rate. The MUX Clock frequency is divided by a 448 counter chain. This results in a typical strobe rate of 768 Hz. By pulling the Clock SEL line low, the display can be operated from an external MUX Clock. The external clock is attached to the CLK I/O connection (pin 8). The maximum external MUX Clock frequency should be limited to 3 MHz. When a high speed external clock is used the frequency can be further divided down by 16 by using the built in prescaler. In the control word format data bit D4 is set high (D4=1). It is not recom- mended to use the prescaler with the internal clock. An asynchronous hardware Reset (pin 6) is also provided. Bringing this pin low will clear the Character Address Register, Control Word Register, RAM, and blanks the display. This action leaves the display set at Character Address 0, and the Brightness Level set at 100%. The user can activate four Control functions. These include: LED Brightness Level, IC Power Down, Prescaler, or Display Clear. OPCODEs and six bit words are used to initiate these functions. The OPCODEs and Control Words for the Character Address and Loading Column Data are shown in Tables „Load Character Address“ (page 10) and „Load Column Data“ (page 10). Basic Instruction Set Instruction Opcode Address/Data LCD 000 D4 LDA 101 X SCL 110 LCWD 111 Comments D3 D2 D1 D0 Load Column Data X A2 A1 A0 Load Digit Address PS B3 B2 B1 B0 Software Clear PS B3 B2 B1 B0 Load Control Word Data Control Word Format D7 D6 D5 D4 D3 D2 D1 D0 1 1 1 PS B3 B2 B1 B0 PS Pre-Scalar 0 No Divide by 16 1 MUX Clock/16 B2 0 0 0 0 1 1 1 1 B1 0 0 1 1 0 0 1 1 B0 0 1 0 1 0 1 0 1 Brightness 100% 53% 40% 27% 20% 13% 6.6% Blank Display & Power Down B3 Peak Current 0 Full 1 Reduce to 12.5% IDCW5162 2006-03-30 9 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Op code D7 D6 D5 Character Address D4 D3 D2 D1 D0 Hex Operation Load 1 0 1 0 0 0 0 0 A0 Character 0 The SCE574X offers a unique Display Power Down feature which reduces ICC to less than 50 µA. When EFHEX is loaded, as shown in Table „Power Down“ (page 10), the display is set to 0% brightness. When in the Power Down mode data may still be written into the RAM. The display is reactivated by loading a new Brightness Level Control Word into the display. 1 0 1 0 0 0 0 1 A1 Character 1 Power Down 1 0 1 0 0 0 1 0 A2 Character 2 1 0 1 0 0 0 1 1 A3 Character 3 Load Character Address Op code D7 D6 D5 Control Word D4 D3 D2 D1 D0 1 0 1 1 1 1 1 1 Hex Operation Level EF 0% brightness Load Column Data Op code D7 D6 D5 Column Data D4 D3 D2 D1 D0 Operation Load 0 0 0 C0 C1 C2 C3 C4 Row 0 0 0 0 C0 C1 C2 C3 C4 Row 1 0 0 0 C0 C1 C2 C3 C4 Row 2 The Software Clear (C0HEX), given in Table „Software Clear“ (page 10), clears the Address Register and the RAM. The display is blanked and the Character Address Register will be set to Character 0. The internal counter and the Control Word Register are unaffected. The Software Clear will remain active until the next data input cycle is initiated. 0 0 0 C0 C1 C2 C3 C4 Row 3 Software Clear 0 0 0 C0 C1 C2 C3 C4 Row 4 Op code D7 D6 D5 Control Word D4 D3 D2 D1 D0 0 0 0 C0 C1 C2 C3 C4 Row 5 1 0 0 0 0 0 C0 C1 C2 C3 C4 Row 6 The user can select eight specific LED brightness levels (Table „Display Brightness“ (page 10)) by changing the peak current driving the LEDs. The peak current is varied by varying the ON time of the row drivers. Note that data line 3 is low (logic 0). If dimming is required with finer control between 12.5% brightness and 0.0% brightness, data line 3 can be set high (logic 1). The 12.5% peak current is now the brightness reference (100%-E8) for further dimming and as shown in Table “Display Brightness“ (page 10) eight levels of dimming are provided. For example the hex code EC in Table “Display Brightness“ (page 10) will provide a brightness level 29% lower than the 12.5% brightness level. Display Brightness Op code D7 D6 D5 Control Word D4 D3 D2 D1 D0 Hex Operation Level 1 1 1 0 0 0 0 1 1 1 0 0 0 0 0 E0 100% 1 E1 1 1 1 0 0 0 53% 1 0 E2 1 1 1 0 0 40% 0 1 1 E3 1 1 1 0 27% 0 1 0 0 E4 1 1 1 20% 0 0 1 0 1 E5 1 1 13% 1 0 0 1 1 0 E6 1 1 6.6% 1 0 0 1 1 1 E7 0.0% 2006-03-30 10 1 0 0 0 0 Hex Operation Level C0 CLEAR SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Electrical and Mechanical Considerations Thermal Considerations Optimum product performance can be had when the following electrical and mechanical recommendations are adopted. The IC is constructed in a high speed CMOS process, consequently noise on the SERIAL DATA, SERIAL DATA CLOCK, LOAD and RESET lines may cause incorrect data to be written into the serial shift register. Adhere to transmission line termination procedures when using fast line drivers and long cables (> 10 cm). Good ground and power supply decoupling will insure that ICC (< 400 mA peak) switching currents do not generate localized ground bounce. Therefore it is recommended that each display package use a 0.1 µmF and 0 µF capacitor between VCC and ground. When the internal MUX Clock is being used connect the CLKSEL pin to VCC. In those applications where RESET will not be connected to the system’s reset control, it is recommended that this pin be connected to the center node of a series 0.1 µF and 100 kΩ RC network. Thus upon initial power up the RESET will be held low for 10 ms allowing adequate time for the system power supply to stabilize. Using filters emphasizes the contrast ratio between a lit LED and the character background. This will increase the discrimination of different characters. The only limitation is cost. Take into consideration the ambient lighting environment for the best cost/benefit ratio for filters. Incandescent (with almost no green) or fluorescent (with almost no red) lights do not have the flat spectral response of sunlight. Plastic band-pass filters are an inexpensive and effective way to strengthen contrast ratios. The SCE5740 is a red display and should be used with long wavelength pass filter having a sharp cut-off in the 600 nm to 620 nm range. The SCE5742 is a super-red display and should be used with long wavelength pass filter having a sharp cut-off in the 570 nm to 600 nm range. The SCE5744 is a high efficiency green display and should be used with long wavelength pass filter that peaks at 565 nm. Additional contrast enhancement is gained by shading the displays. Plastic band-pass filters with built-in louvers offer the next step up in contrast improvement. Plastic filters can be improved further with anti-reflective coatings to reduce glare. Optimal filter enhancements are gained by using circular polarized, anti-reflective, band-pass filters. The circular polarizing further enhances contrast by reducing the light that travels through the filter and reflects back off the display to less than 1%. Several filter manufacturers supply quality filter materials. Some of them are: Panelgraphic Corporation, W. Caldwell, NJ; SGL Homalite, Wilmington, DE; 3M Company, Visual Products Division, St. Paul, MN; Polaroid Corporation, Polarizer Division, Cambridge, MA; Marks Polarized Corporation, Deer Park, NY, Hoya Optics, Inc., Fremont, CA.One last note on mounting filters: recessing displays and bezel assemblies is an inexpensive way to provide a shading effect in overhead lighting situations. Several Bezel manufacturers are: R.M.F. Products, Batavia, IL; Nobex Components, Griffith Plastic Corp., Burlingame, CA; Photo Chemical Products of California, Santa Monica, CA; I.E.E.-Atlas, Van Nuys, CA. The trade-off is fuzzy characters. Mounting the filters close to the display reduces this effect. Take care not to overheat the plastic filter by allowing for proper air flow. ESD Protection The input protection structure of the SCE574x provides significant protection against ESD damage. It is capable of withstanding discharges greater than 2.0 kV. Take all the standard precautions, normal for CMOS components. These include properly grounding personnel, tools, tables, and transport carriers that come in contact with unshielded parts. If these conditions are not, or cannot be met, keep the leads of the device shorted together or the parts in anti-static packaging. Soldering Considerations The SCE574x can be hand soldered with SN63 solder using a grounded iron set to 260°C. Wave soldering is also possible following these conditions: Preheat that does not exceed 93°C on the solder side of the PC board or a package surface temperature of 85°C. Water soluble organic acid flux (except carboxylic acid) or rosin-based RMA flux without alcohol can be used. Wave temperature of 245°C ± 5°C with a dwell between 1.5 sec. to 3.0 sec. Exposure to the wave should not exceed temperatures above 260°C for five seconds at 1.59 mm (0.063") below the seating plane. The packages should not be immersed in the wave. Microprocessor Interface The microprocessor interface is through the serial port, SPI port or one out of eight data bits on the eight bit parallel port and also control lines SDCLK and LOAD. Power Up Sequence Upon power up display will come on at random. Thus the display should be reset at power-up. The reset will set the Address Register to Digit 0, User RAM is set to 0 (display blank) the Control Word is set to 0 (100% brightness) and the internal counters are reset. Post Solder Cleaning Procedures The least offensive cleaning solution is hot D.I. water (60 °C) for less than 15 minutes. Addition of mild saponifiers is acceptable. Do not use commercial dishwasher detergents. For faster cleaning, solvents may be used. Exercise care in choosing solvents as some may chemically attack the nylon package. For further information refer to Appnotes 18 and 19. An alternative to soldering and cleaning the display modules is to use sockets. Naturally, 14 pin DIP sockets 7.62 mm (0.300”) wide with 2.54 mm (0.100") centers work well for single displays. Multiple display assemblies are best handled by longer SIP sockets or DIP sockets when available for uniform package alignment. Optical Considerations The 4.57 mm (0.180") high character of the SCE574x gives readability up to five feet. Proper filter selection enhances readability over this distance. 2006-03-30 11 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Display Interface to Siemens/Intel 8031 Microprocessor (using serial port in mode 0) VCC 40 19 XTAL2 RxD XTAL1 TxD VCC 10 11 5 2 U1 8031 VCC 9 P3.7 RST P3.3 P3.4 17 6 13 7 DATA SDCLK 3 22 µF TAN + 18 LD ID RST VCC GND CLKSEL 14 CLK I/O 1 14 0.01 µF 8 IDCD5027 Display Interface to Siemens/Intel 8031 Microprocessor (using one bit of parallel port as serial port) VCC 40 19 XTAL2 P3.0 P3.1 1 9 VCC 11 XTAL1 P3.6 U1 8031 VCC 10 P0.0 16 5 39 2 RST 6 P1.0 7 SDCLK LD DATA ID 20 RST VCC GND CLKSEL CLK I/O 22 µF TAN 3 + 18 1 14 0.01 µF 8 IDCD5028 Display Interface with Motorola 68HC05C4 Microprocessor (using SPI port) VCC 40 39 OSC1 PA1 1 9 11 VCC 10 OSC2 U1 68HC05C4 VCC PA0 SCLK MOSI 33 5 32 2 RST 6 PA2 7 20 SDCLK LD DATA ID RST VCC GND CS CLK I/O 3 22 µF TAN + 38 1 14 8 0.01 µF IDCD5029 2006-03-30 12 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Cascading Multiple Displays using only the SCE574x. RST VCC RST CLK I/O CLK SEL RST 14 more displays in between Intelligent Display DATA SDCLK CLK I/O DATA LOAD CLK SEL Intelligent Display SDCLK LOAD DATA SDCLK 0 A0 A1 A2 A3 Address Decoder Chip 15 LD CE Address Decode 1-14 IDCD5030 Multiple displays can be cascaded using the CLK SEL and CLK I/O pins (Figure „Cascading Multiple Displays using only the SCE574X“ (page 13)). The display designated as the MasterClock source should have its CLK SEL pin tied high and the slaves should have their CLK SEL pins tied low. All CLK I/O pins should be tied together. One display CLK I/O can drive 15 slave CLK I/Os. Use RST to synchronize all display counters. Loading Data into the Display Use following procedure to load data into the display: 1. Power up the display. 2. Bring RST low (600 ns duration minimum) to clear the Multiplex Counter, Address Register, Control Word Register, User Ram and Data Register. The display will be 3. 4. 5. 6. blank. Display brightness is set to 100%. If a different brightness is desired, load the proper brightness opcode into the Control Word Register. Load the Digit Address into the display. Load display row and column data for the selected digit. Repeat steps 4 and 5 for all digits. Data Contents for the Word “ABCD” Step D7 D6 D5 D4 D3 D2 D1 D0 Function A B (optional) 1 1 1 1 0 1 0 0 0 0 0 0 0 0 0 0 CLEAR 100% BRIGHTNESS 1 2 3 4 5 6 7 8 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 0 0 1 0 1 0 0 0 0 1 0 0 1 0 0 0 0 0 1 0 1 0 0 0 0 0 0 1 1 1 1 1 DIGIT D0 SELECT ROW 0 (A) ROW 1 (A) ROW 2 (A) ROW 3 (A) ROW 4 (A) ROW 5 (A) ROW 6 (A) 9 10 11 12 13 14 15 16 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 1 0 0 1 0 0 1 0 1 0 0 1 0 0 1 0 1 0 0 1 0 0 1 1 1 1 1 0 1 1 1 DIGIT D1 SELECT ROW 0 (B) ROW 1 (B) ROW 2 (B) ROW 3 (B) ROW 4 (B) ROW 5 (B) ROW 6 (B) 17 18 19 20 21 22 23 24 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 1 1 0 0 0 0 1 0 0 0 1 0 0 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 DIGIT D2 SELECT ROW 0 (C) ROW 1 (C) ROW 2 (C) ROW 3 (C) ROW 4 (C) ROW 5 (C) ROW 6 (C) 25 26 27 28 29 30 31 32 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 1 0 0 0 0 0 1 1 0 1 1 1 1 1 0 DIGIT D3 SELECT ROW 0 (D) ROW 1 (D) ROW 2 (D) ROW 3 (D) ROW 4 (D) ROW 5 (D) ROW 6 (D) 2006-03-30 13 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Dimensions in inch (mm) SCE574X Z OSRAM XXYY V Luminous Intensity Code 0.46 (0.018) 2.54 (0.100) 12 pl. Non cumulative 5.08 (0.200) EIA Date Code Part Number 4.06 (0.160) ±0.51 (0.020) Pin 1 Indicator 3.81 (0.150) Detail Drawing of SCE574x 0.3 (0.012) ±0.05 (0.002) 7.62 (0.300) ±0.51 (0.020) 19.91 (0.784) 10.16 (0.400) ±0.38 (0.015) 2.54 (0.100) 5.00 (0.197) 3 pl. 4.57 (0.180) Dimensions in inches (mm) Tolerance: .XXX = ±.010 (.25) IDOD5007 Pin Functions for SCE574x Function Pin # Function 1 VCC 6 RESET 2 Load 7 GROUND 3 Data 8 CLK I/O 4 No Pin 9—13 No Pins 5 SDCLK 14 CLK SELECT Top View Typical Character Pin 14 Pin 8 Pin 1 2006-03-30 0.71 (0.028) Pin # Pin 7 IDPA5107 0.56 (0.022) IDOD5008 14 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 SCE574XP Z OSRAM XXYY V Luminous Intensity Code 0.46 (0.018) 8 pl. 2.54 (0.100) 4 pl. Tol. Non Accum. 3.81 (0.150) Dimensions in inch (mm) EIA Date Code Part Number 5.08 (0.200) Pin 1 Indicator 0.3 (0.012) 6 pl. 5.08 (0.200) 4.06 (0.160) ±0.51 (0.020) Detail Drawing of SCE574xP (SIP configuration) 19.91 (0.784) 1.22 (0.048) 5 (0.197) 4.57 (0.180) 10.16 (0.400) 3 pl. Unless otherwise specified, tolerance on dimensions is ±0.25 (0.010) 2.54 (0.100) 4 pl. IDOD5009 V 0.46 (0.018) 6 pl. 2.54 (0.100) 4 pl. Tol. Non Accum. 5.08 (0.200) 5.08 (0.200) SCE574XQ Z OSRAM XXYY Luminous Intensity Code 3.81 (0.150) EIA Date Code Part Number 0.71 (0.028) Pin 1 Indicator 1.26 (0.050) ±0.51 (0.020) Detail Drawing of SCE574xQ (SIP configuration with right angle bend Dimensions in inch (mm)) 4.06 (0.160) ±0.51 (0.020) 19.91 (0.784) 1.22 (0.048) 5 (0.197) 0.56 (0.022) 4.57 (0.180) 10.16 (0.400) 3 pl. IDOD5011 Unless otherwise specified, tolerance on dimensions is ±0.25 (0.010) 2.54 (0.100) 4 pl. IDOD5010 Pin Functions for SCE574xP and SCE574xQ Function 1 VCC 2 Load 3 Data 4 No Pin 5 SDCLK 6 RESET 7 GND Top View Typical Character 0.71 (0.028) Pin # Pin 1 Pin 7 0.56 (0.022) IDPA5108 IDOD5011 2006-03-30 15 SCE5740, SCE5741, SCE5742, SCE5743, SCE5744, SCE5745 Revision History: 2006-03-30 Previous Version: 2005-01-10 Page Subjects (major changes since last revision) Date of change all Lead free device 2006-01-23 Published by OSRAM Opto Semiconductors GmbH Wernerwerkstrasse 2, D-93049 Regensburg www.osram-os.com © All Rights Reserved. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components1) may only be used in life-support devices or systems2) with the express written approval of OSRAM OS. 1) 2) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2006-03-30 16
SCE5744
物料型号: - 型号:MAX31855KASA+T - 制造商:Maxim Integrated
器件简介: - MAX31855KASA+T 是一款由 Maxim Integrated 生产的冷结补偿型 K 热电偶到数字转换器。
引脚分配: - 1:VDD - 2:GND - 3:CS/#(片选/禁用) - 4:CLK(时钟) - 5:DOUT(数据输出) - 6:DIN(数据输入) - 7:ALERT(报警) - 8:GND
参数特性: - 供电电压:3.0V 至 3.6V - 工作温度范围:-40°C 至 +125°C
功能详解: - MAX31855KASA+T 能够将 K 型热电偶信号转换为数字信号,具有 14 位分辨率和 ±0.5°C 的精度。
应用信息: - 适用于需要高精度温度测量的应用,如工业过程控制、医疗设备和环境监测。
封装信息: - 封装类型:TSSOP-8 - 引脚数量:8 - 封装尺寸:4.4mm x 3mm
SCE5744 价格&库存
很抱歉,暂时无法提供与“SCE5744”相匹配的价格&库存,您可以联系我们找货
