PD4437
PD4437
    AMSOSRAM(艾迈斯半导体)
    插件
    DISPLAY PROGR 4CHAR 5X7 BRT GRN
PD4437 数据手册
4-Character 5 x 7 Dot Matrix Alphanumeric Programmable DisplayTM with Built-in CMOS Control Functions Lead (Pb) Free Product - RoHS Compliant PD243X, PD353X, PD443X PD243X PD353X PD443X DESCRIPTION FEATURES • Four Dot Matrix Characters in High Efficiency Red, Red, and Bright Green - PD2435/6/7, 5.08 mm (0.200") High - PD3535/6/7, 6.86 mm (0.270") High - PD4435/6/7, 11.43 mm (0.45") High • Built-in Memory, Decoders, Multiplexer and Drivers • Wide Viewing Angle, X Axis ± 55°, Y Axis ± 65° • Categorized for Luminous Intensity • 128 Character ASCII Format (Upper and Lower Case Characters) • 8 Bit Bidirectional Data BUS • READ/WRITE Capability • Dual In-Line Package Configuration, 15.2 mm (0.600") Wide, 2.54 mm (0.100") Pin Centers • End-Stackable Package • Internal or External Clock • Built-in Character Generator ROM • TTL Compatible • Easily Cascaded for Multidisplay Operation • Less CPU Time Required • Software Controlled Features: - Programmable Highlight Attribute (Blinking, Non-Blinking) - Asynchronous Memory Clear Function - Lamp Test - Display Blank Function - Single or Multiple Character Blinking Function - Programmable Intensity (Three Brightness Levels) • Extended Operating Temperature Range: • PD243X, PD353X: –40°C to +85°C • PD443X: –40°C to +70°C These Programmable Displays are four digit display system modules. The characters are 5.08 mm by 3.56 mm (0.20" by 0.14") (PD243X), 6.86 mm by 5.08 mm (0.27" by 0.20") (PD353X), and 11.43 mm by 6.86 mm (0.45" by 0.27") (PD443X) 5 x 7 dot matrix arrays constructed with the latest solid state technology in light emitting diodes. Driving and controlling the LED arrays is a silicon gate CMOS integrated circuit. This integrated circuit provides all necessary LED drivers and complete multiplexing control logic. Additionally, the IC has the necessary ROM to decode 128 ASCII alphanumeric characters and enough RAM to store the display’s complete four digit ASCII message with special attributes. These attributes, all software programmable at the user’s discretion, include a lamp test, brightness control, displaying cursors, alternating cursors and characters, and flashing cursors or characters. The CMOS IC also incorporates special interface control circuitry to allow the user to control the module as a fully supported microprocessor peripheral. The module, under internal or external clock control, has asynchronous read, write, and memory clear over an eight bit parallel, TTL compatible, bi-directional data bus. Each module is fully encapsulated within a package 25.4 x 17.8 x 5.08 mm (1.0" x 0.7" x 0.2") (PD253X), 35.6 x 18.3 x 7.24 mm (1.4" x 0.72" x 0.285") (PD353X), and 38.1 x 20.8 x 7.24 mm (1.5" x 0.82" x 0.285") (PD443X). The standard 20 pin DIP construction with two rows spaced at 15.2 mm (0.6") on 2.54 mm (0.1") centers is wave solderable. See the end of this data sheet or refer to Appnotes 18, 19, 22, and 23 for further details on handling and assembling OSRAM Programmable Displays. 2006-01-23 1 PD243X, PD353X, PD443X Ordering Information Type 2006-01-23 Color of Emission Character Height mm (inch) Ordering Code PD2435 PD2436 PD2437 high efficiency red red bright green 5.08 (0.200) Q68000A3561 Q68000A8366 Q68000A3562 PD3535 PD3536 PD3537 high efficiency red red bright green 6.86 (0.270) Q68000A7964 Q68000A8365 Q68000A7965 PD4435 PD4436 PD4437 high efficiency red red bright green 11.43 (0.450) Q68000A8367 Q68000A8368 Q68000A8369 2 PD243X, PD353X, PD443X Maximum Ratings Top Storage temperature range Tstg Viewing angle (off normal axis) 2ϕ hor. (typ.) ver. (typ.) – 40 … + 85 –40…+70 °C – 40 … +100 ± 55 ± 65 ± 55 ± 65 DC Supply Voltage Input Voltage Relative to GND (all inputs) Solder temperature 1.59 mm (0.063“) below seating plane, t < 5.0 s Unit PD443X Operating temperature range Values PD353X Symbol PD243X Parameter °C ± 40 ± 65 deg deg. -0.5 to + 7.0 Vdc -0.5 to VCC +0.5 Vdc Ts 260 °C Values Unit Wavelength at peak emission IF = 50 mA (typ.) Character Height PDx437 Symbol PDx435 Parameter PDx436 Characteristics (TA = 25 °C) high red efficiency red green λpeak 630 660 565 nm h 0.145 3.7 0.145 3.7 0.145 3.7 inch mm µcd/LED Time averaged luminous intensity1) (min.) 90 30 90 LED to LED intensity matching (max.) 1.8:1.0 1.8:1.0 1.8:1.0 Device to Device (one bin) (max.) 1.5:1.0 1.5:1.0 1.5:1.0 Bin to Bin (adjacent bins) (max.) 1.9:1.0 1.9:1.0 1.9:1.0 1) Peak luminous intensity values can be calculated by multiplying these values by 7. 2006-01-23 3 PD243X, PD353X, PD443X PD243X Z OSRAM YYWW EIA Date Code Luminous Intensity V Code 2.54 (0.100) typ. 0.46 (0.018) x 0.31 (0.012) typ. 1.27 (0.050) 5.08 (0.200) Dimensions in mm (inch) Pin 1 Indicator 4.06 (0.160) ±0.51 (0.020) PD243X 15.24 (0.600) At Seating Plane and centered on package 1.78 (0.070) typ. ±0.1 (0.004) 25.4 (1.000) max. 6.35 (0.250) 3.56 (0.140) 5.08 (0.200) 17.78 (0.700) 3.18 (0.125) Pin 1 Location Tolerance: 0.51 (0.020) IDOD5016 Dimensions in mm (inch) 2.54 (0.100) typ. 0.46 (0.018) x 0.31 (0.012) typ. 11.43 (0.450) 7.24 (0.285) Pin 1 Identifier and ESD Warning EIA Date Code Part No. Luminous Intensity PD353X Z Code OSRAM YYWW V 4.06 (0.160) ±0.51 (0.020) PD353X 15.24 (0.600) At Seating Plane and centered on package 6.35 (0.250) 35.56 (1.400) max. 8.89 (0.350) typ. 5.08 (0.200) typ. 6.86 (0.270) typ. 18.29 (0.720) max. 4.45 (0.175) Tolerance: 0.25 (0.010) unless max. IDOD5017 2006-01-23 4 PD243X, PD353X, PD443X Dimensions in mm (inch) PD443X Z OSRAM EIA Date Code Luminous Intensity Code YYWW V 2.54 (0.100) typ. 0.46 (0.018) x 0.31 (0.012) typ. ±0.05 (0.002) 15.24 (0.600) 7.24 (0.285) Pin 1 Indicator Part No. 4.06 (0.160) ±0.51 (0.020) PD443X 15.24 (0.600) typ. At seating plane and centered on package 7.62 (0.300) 38.1 (1.500) max. 9.53 (0.375) typ. 1.27 (0.050) 20.83 (0.820) max. 11.43 (0.450) ±0.25 (0.010) 6.86 (0.270) typ. Tolerance: 0.51 (0.020) IDOD5018 Top View 20 Digit 3 11 Digit 2 Digit 1 1 Digit 0 10 20 11 Digit 3 Digit 2 Digit 1 1 20 Digit 0 10 11 Digit 3 Digit 2 Digit 1 1 Digit 0 10 IDPA5109 2006-01-23 5 PD243X, PD353X, PD443X Timing Characteristics—Data “Write” Cycle Timing Characteristics—Data “Read” Cycle 2.0 V 0.8 V * CE0, CE1 TCES TCEH TAS TAH 2.0 V 0.8 V * A0, A1 TDS TCES TCEH TAS TAH 2.0 V 0.8 V * A0–A3 2.0 V 0.8 V * D0–D6 2.0 V 0.8 V * CE0, CE1 TRS TDH TRI TDD 2.0 V 0.8 V * RD TRH WR WR 2.0 V 0.8 V * 2.0 V 0.8 V * DATA OUT D0–D6 TDH TWS 2.0 V 0.8 V * TWH RD 2.0 V 0.8 V * TW TR TRACC TACC Notes: 1. Wait 1.0 µs between any Reads or Writes after writing a Control Word with a Clear (D7=1). Wait 1.0 µs between any Reads or Writes after Clearing a Control Word with a Clear (D7=0). All other Reads and Writes can be back to back. 2. All input voltages are VIL=0.8 V, VIH=2.0 V. 3. These waveforms are not edge triggered. 4. Data out voltages are measured with 100 pF on the data bus and the ability to source = –40 mA and sink=1.6 mA The rise and fall times are 60 ns. VOL=0.4 V, VOH=2.4 V. Switching Specifications (VCC=4.5 V) Switching Specifications (VCC=4.5 V) Write Cycle Timing Parameter Description TCLR(1) Read Cycle Timing Specification Minimum Parameter Description –40°C 25°C 85°C Units µs TAS Address Setup 0 0 0 ns 1.0 µs TCES Chip Enable 0 0 0 ns 10 10 ns TWS Write Enable Setup 20 30 40 ns 0 0 0 ns TDD Data Delay Time 100 150 175 ns Read Enable Setup 10 10 10 ns TR Read Pulse 150 175 200 ns TDS Data Setup 20 30 50 ns TAH Address Hold 0 0 0 ns TW Write Pulse 60 70 90 ns TDH Data Hold 0 0 0 ns TAH Address Hold 20 30 40 ns TTRI 30 40 50 ns TDH Data Hold 20 30 40 ns Time to Tristate (Max. time) TCEH Chip Enable Hold 0 0 0 ns TCEH Chip Enable Hold 0 0 0 ns TWH Write Enable Hold 30 40 50 ns TACC Total Access Time = Setup Time + Read Time + Time to Tristate 200 245 290 ns TWAIT (1) Wait Time between Reads 0 0 0 ns –40°C 25°C 85°C Units Clear RAM 1.0 1.0 1.0 TCLRD(1) Clear RAM Disable 1.0 1.0 TAS Address Setup 10 TCES Chip Enable Setup TRS TRH TACC Read Enable Hold Total Access Time = Setup Time + Write Time + Hold Time 2006-01-23 20 90 30 110 40 140 ns ns 6 Specification Minimum PD243X, PD353X, PD443X DC Characteristics at 25°C Parameter Limits Conditions Min. Typ. Max. Units VCC 4.5 5.0 5.5 Volts Nominal ICC (Blank) — 2.5 3.5 mA VCC=5.0 V, A2 = 1, all other inputs low. ICC 80 LEDs/unit (100% Bright) PD243X PD353X PD443X — 115 145 150 130 165 170 mA mA mA VCC=5.0 V VCC=5.0 V VCC=5.0 V VIL — — 0.8 Volts VCC=4.5 V to 5.5 V VIH 2.0 — — Volts VCC=4.5 V to 5.5 V IIL (except D0 to D7) (1) 25 — 100 µA VCC=4.5 V to 5.5 V, VIN =0.8 V VOL — — 0.4 Volts VCC=4.5 V to 5.5 V VOH 2.4 — — Volts VCC=4.5 V to 5.5 V IOH –8.9 — — mA VCC=4.5 V, VOH=2.4 V IOL 1.6 — — mA VCC=4.5 V, VOL=0.4 V Data I/O Bus Loading — — 100 pF — Clock I/O Bus Loading — — 240 pF — 1) D0 to D7 have no pull-up resistors so current is negligible. Pin Assignments and Definitions Pin Function Definition Pin Function Definition 1 RD Active low, will enable a processor to read all registers in the display. 11 WR Write. Active low. If the device is selected, a low on the write input loads the data into memory. 2 CLK I/O If CLK SEL (pin 3) is low, then expect an external clock source into this pin. If CLK SEL is high, then this pin will be the master or source into this pin. If CLK SEL is high, then this pin will be the master or source for all other devices which have CLK SEL low. 12 D7 Data Bus bit 7 (MSB). 3 CLKSEL CLOCK SELECT determines the action of pin 2. CLK I/O, see the section on Cascading for an example. 13 D6 Data Bus bit 6. 4 RST Reset. Used to synchronize blinking. Will not clear the display. The reset pulse should be less than 1 ms 14 D5 Data Bus bit 5. 5 CE1 Chip enable (active high). 15 D4 Data Bus bit 4. 6 CE0 Chip enable (active low). 16 D3 Data Bus bit 3. 7 A2 Address input (MSB). 17 D2 Data Bus bit 2. 8 A1 Address input. 18 D1 Data Bus bit 1. 9 A0 Address input (LSB). 19 D0 Data Bus bit 0 (LSB). 10 GND Ground. 20 VCC Positive power pin. 2006-01-23 7 PD243X, PD353X, PD443X Functional Description The block diagram includes 5 major blocks and internal registers (indicated by dotted lines). Display Memory consists of a 5 x 8 bit RAM block. Each of the four 8-bit words holds 7-bits of ASCII data (bits D0–D6) and an attribute select bit (Bit D6). The fifth 8-bit memory word is used as a control word register. A detailed description of the control register and its functions can be found in the Control Word section. Each 8-bit word is addressable and can be read from or written to. The Control Logic dictates all of the features of the display device and is discussed in the Control Word section of this data sheet. The Character Generator converts the 7-bit ASCII data into the proper dot pattern for the 128 characters shown in the character set chart. The Clock Source can originate either from the internal oscillator clock or from an external source—usually from the output of another display in a multiple module array. The Display Multiplexer controls all display output to the digit drivers so no additional logic is required for a display system. The Column Drivers are connected directly to the display. The Display has four digits. Each of the four digits is com-prised of 35 LEDs in a 5 x 7 dot array which makes up the alphanumeric characters. The intensity of the display can be varied by the Control Word in steps of 0% (Blank), 25%, 50%, and full brightness. The Reset pin when activated clears the internal counter. A reset is usually done after power up and is of very short duration-nanoseconds or microseconds. If the reset pin is held low for a longer time (milliseconds) some or all LEDs in the bottom row may light up. The appearance of lit LEDs during a “reset” is not an indication of a malfunctioning part. It is advisable to keep the reset pulse as short as possible to avoid displaying a row of lit LEDs. Input Buffering If a cable length of 6 inches or more is used, all inputs to the display should be buffered with a tri-state non-inverting buffer mounted as close to the display as conveniently possible. Recommended buffers are: 74LS245 for the data lines and 74LS244 for the control lines. Block Diagram 8 D0-D7 14 Control Reg 1x8 Display Memory (RAM) 4 x 8 128 Char ROM 128 x 5 8 4 15 1 CE0, CE1 A0-A2 RD, WR Decode and Mux 7 5 Output Control Logic Output Latch 1 CLK SEL XCLK RST 3 OSC Logic 3 20 Column Drivers Display Multiplexer 3 20 Row Drivers Display IDBD5065 Mode Selection Microprocessor Interface The interface to the microprocessor is through the address lines. (A0–A2), the data bus (D0–D7), two chip select lines (CE0, CE1), and read (RD) and write (WR) lines. The CE0 should be held low when executing a read, or write operation. CE1 must be held high. The read and write lines are both active low. During a valid read the data input lines (D0–D7) become outputs. A valid write will enable the data as input lines. CEO CE1 RD WR Operation 0 1 0 0 None 1 X X X None X 0 X X None X X 1 1 None 0=Low logic level, 1=High logic level, X=Don’t care Data Input Commands CEO CE1 RD WR A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 Operation 1 0 X X X X X X X X X X X X X No Change 0 1 0 1 1 0 0 X X X X X X X X Read Digit 0 Data to Bus 0 1 1 0 1 0 0 0 0 1 0 0 1 0 0 ($) Written to Digit 0 0 1 1 0 1 0 1 0 1 0 1 0 1 1 1 (W) Written to Digit 1 0 1 1 0 1 1 0 0 1 1 0 0 1 1 0 (f) Written to Digit 2 0 1 1 0 1 1 1 0 0 1 1 0 0 1 1 (3) Written to Digit 3 0 1 1 0 1 0 0 1 X X X X X X X Char. Written to Digit 0 and Cursor Enabled 2006-01-23 8 PD243X, PD353X, PD443X There are five registers within the display. Four of these registers are used to hold the ASCII/attribute code of the four display characters. The fifth register is the Control Word, which is used to blink, blank, clear, or dim the entire display, or to change the presentation (attributes) of individual characters. Control Word When address bit A2 is taken low, the Control Word is accessed. The same Control Word appears in all four of the lower address spaces of the display. Through the Control Word, the display can be cleared, the lamps can be tested, display brightness can be selected, and attributes can be set for any characters which have been loaded with their most significant bit (D7) set high. Brightness (D0, D1): The state of the lower two bits of the Control Word are used to set the brightness of the entire display, from 0% to 100%. The table below shows the correspondence of these bits to the brightness. Adressing The addresses within the display device are shown below. Digit 0 is the rightmost digit of the display, while digit 3 is on the left. Although there is only one Control Word, it is duplicated at the four address locations 0–3. Data can be read from any of these locations. When one of these locations is written to, all of them will change together. Address Contents D7 D6 D5 D4 D3 D2 D1 D0 Operation 0 0 X X X X 0 0 Blank 0 0 X X X X 0 1 25% brightness A2 A1 A0 0 X X Control Word 0 0 X X X X 1 0 50% brightness 1 0 0 Digit 0 (rightmost) 0 0 X X X X 1 1 Full brightness 1 0 1 Digit 1 X = don't care 1 1 0 Digit 2 1 1 1 Digit 3 (leftmost) Attributes (D2–D4): Bits D2, D3, and D4 control the visual attributes (i.e., blinking) of those display digits which have been written with bit D7 set high. In order to use any of the four attributes, the Cursor Enable bit (D4 in the Control Word) must be set. When the Cursor Enable bit is set, and bit D7 in a character location is set, the character will take on one of the following display attributes. Bit D7 of any of the display digit locations is used to allow an attribute to be assigned to that digit. The attributes are discussed in the next section. If Bit D7 is set to a one, that character will be displayed using the attribute. If bit D7 is cleared, the character will display normally. Control Word Format D7 D6 D5 D4 Clear Lamp Test Blink Attribute Enable D3 D2 Attributes D1 D0 Brightness D1 0 0 D3 D2 Attributes 1 0 0 Display cursor instead 1 of character 0 1 Blink character 1 0 Display blinking cursor instead of character 1 1 Alternate character with cursor D0 0 1 0 1 Brightness 0% (blank) 25% 50% 100% D4 Attribute Enable 0 Disable above attributes 1 Enable above attributes D5 Blink 0 Blink attribute disabled 1 Blink entire display D6 Lamp Test 0 Standard operation 1 Display all dots at 50% brightness D7 Clear 0 Standard operation 1 Clear entire display IDCW5163 2006-01-23 9 PD243X, PD353X, PD443X D7 D6 D5 D4 D3 D2 D1 D0 Operation D7 D6 D5 D4 D3 D2 D1 D0 Operation 0 0 0 0 X X B B Disable highlight attribute 0 0 1 X X X B B Blinking display 0 0 0 1 0 0 B B Display cursor* instead of character 0 0 0 1 0 1 B B Blink single character 0 0 0 1 1 0 B B Display blinking cursor* instead of character 0 0 0 1 1 1 B B Lamp Test (D6): When the Lamp Test bit is set, all dots in the entire display are lit at half brightness. When this bit is cleared, the display returns to the characters that were showing before the lamp test. D7 D6 D5 D4 D3 D2 D1 D0 Operation 0 1 0 X X X X X Lamp test Clear Data (D7): When D7 is set (D7=1) in the Control Word, all (display) memory bits are reset to zero and the display goes blank. Alternate character with cursor* *“Cursor”= all dots in a single character space lit to half brightness X = Don't care B = Depends on the selected brightness. D7 D6 D5 D4 D3 D2 D1 D0 Operation 1 0 X X X X X X Clear A second control word must be written into the chip with D7 reset (D7=0) to set up attributes and brightness levels. Attributes are non-destructive. If a character with bit D7 set is replaced by a cursor (Control Word bit D4 is set, and D3=D2=0) the character will remain in memory and can be revealed again by clearing D4 in the Control Word. Blink (D5): The entire display can be caused to blink at a rate of approximately 2.0 Hz by setting bit D5 in the Control Word. This blinking is independent of the state of D7 in all character locations. To synchronize the blink rate in a bank of these devices, it is necessary to tie all devices' clocks and resets together as described in a later section of this data sheet. The SMC- 4740 oscillator is designed to drive up to 16 displays with input loading of 15 pF each. The general requirements for cascading 16 displays are: 1.Determine the correct address for each display. 2.Tie CE0 to ground and use CE1 from an address. 3.Select one of the displays to provide the clock for the other displays. 4.Tie CLKSEL to ground on other displays. 5.Use RST to synchronize the blinking between the displays. Cascading Diagram RST RD WR VCC WR RD RST CLK CLK I/O SEL Programmable Display D0-D7 A0-A2 CE0 WR 14 more displays in between CE1 RST CLK CLK I/O SEL Programmable Display RD D0-D7 A0-A2 CE0 CE1 Data I/O Address A4 A5 Address Decoder Address Decode Chip 1 to 14 A6 IDCD5032 2006-01-23 10 PD243X, PD353X, PD443X How to Load Information Into the Display Information loaded into the display can be either ASCII data or Control Word data. The following procedure (see also Typical Loading Sequence) will demonstrate a typical loading sequence and the resulting visual display. The word STOP is used in all of the following examples. Set Brightness Step 1 Set the brightness level of the entire display to your preference (example: 100%) Load Four Characters Step 2 Load an “S” in the left hand digit. Step 3 Load a “T” in the next digit. Step 4 Load an “O” in the next digit. Step 5 Load a “P” in the right hand digit. If you loaded the information correctly, the display now should show the word “STOP.” Blink a Single Character Step 6 Into the digit, second from the right, load the hex code “CF,” which is the code for an “O” with the D7 bit added as a control bit. Add Another Blinking Character Into the left hand digit, load the hex code “D3” which gives an “S” with the D7 bit added as a control bit. The display should show “STOP” with flashing “O” and a flashing “S.” Alternate Character/Cursor Enable Load enable alternate character/cursor into the control word register. The display now should show “STOP” with the “O” and the “S” alternating between the letter and cursor (all dots lit). Initiate Four Character Blinking (Regardless of Control Bit setting) Load enable display blinking. The display now should show the entire word “STOP” blinking. Step 8 Step 9 Step 10 Note: The “O” is the only digit which has the control bit (D7) added to normal ASCII data. Load enable blinking character into the control word register. The display should show “STOP” with a flashing “O”. Step 7 Typical Loading Sequence CEO CE1 RD WR A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 1. L H H L L X X 0 0 0 0 0 0 1 1 2. L H H L H H H 0 1 0 1 0 0 1 1 S 3. L H H L H H L 0 1 0 1 0 1 0 0 ST 4. L H H L H L H 0 1 0 0 1 1 1 1 STO 5. L H H L H L L 0 1 0 1 0 0 0 0 STOP 6. L H H L H L H 1 1 0 0 1 1 1 1 STOP 7. L H H L L X X 0 0 0 1 0 1 1 1 STO*P 8. L H H L H H H 1 1 0 1 0 0 1 1 S*TO*P 9. L H H L L X X 0 0 0 1 1 1 1 1 S†TO†P 10. L H H L L X X 0 0 1 0 0 0 1 1 S*T*O*P* * Blinking character † Character alternating with cursor (all dots lit) 2006-01-23 11 Display PD243X, PD353X, PD443X Electrical and Mechanical Considerations The CMOS IC of the display is designed to provide resistance to both Electrostatic Discharge Damage and Latch Up due to voltage or current surges. Several precautions are strongly recommended to avoid overstressing these built-in safeguards. Power Down Sequence 1.Float all active signals by tri-stating the inputs to the display. 2.Turn off the power to the display. Soldering Considerations These displays can be hand soldered with SN63 solder using a grounded iron set to 260°C. Wave soldering is also possible following these conditions: Preheat that does not exceed 93°C on the solder side of the PC board or a package surface temperature of 85°C. Water soluble organic acid flux (except carboxylic acid) or rosin-based RMA flux without alcohol can be used. Wave temperature is 245°C ±5°C with a dwell between 1.5 sec to 3.0 sec. Exposure to the wave should not exceed temperatures above 260°C, for 5 sec at 1.59 mm (0.063") below the seating plane. The packages should not be immersed in the wave. ESD Protection Display users should be careful to handle the devices consistent with Standard ESD protection procedures. Operators should wear appropriate wrist, ankle or feet ground straps and avoid clothing that collects static charges. Work surfaces, tools and transport carriers that come into contact with unshielded devices or assemblies should also be appropriately grounded. Latch up Protection Latch up is a condition that occurs in CMOS ICs after the input protection diodes have been broken down. These diodes can be reversed through several means: VIN < GND, VIN > VCC + 0.5 V, or through excessive currents forced on the inputs. When these situations exist, the IC may develop the response of an SCR and begin conducting as much as one amp through the VCC pin. This destructive condition will persist (latched) until device failure or the device is turned off. Voltage Transient Suppression It has become common practice to provide 0.01 µF bypass capacitors liberally in digital systems. Like other CMOS circuitry, the Intelligent Display controller chip has very low power consumption and the usual 0.01 µF would be adequate were it not for the LEDs. To prevent power supply transients, capacitors with low inductance and high capacitance at high frequencies are required. This suggests a solid tantalum or ceramic disc for high frequency bypass. For multiple display module systems distribute the bypass capacitors evenly, keeping capacitors as close to the power pins as possible. Use a 0.01 µF capacitor for each display module and a 22 µF for every third display module. The Voltage Transient Suppression Techniques and buffer interfaces for longer cable runs help considerably to prevent latch conditions from occurring. Additionally, the following Power Up and Power Down sequence should be observed. Power up Sequence 1. Float all active signals by tri-stating inputs to displays. 2. Apply VCC and GND to the display. 3. Apply active signals to the displays by enabling all input signals per application. Notes: 1. A2 must be held high for ASCII data. 2. Bit D7=1 enables attributes for the assigned digit. Character Set D0 D1 D2 D3 D6 D5 D4 HEX ASCII CODE 0 0 0 0 0 0 1 1 0 1 0 2 0 1 1 3 1 0 0 4 1 0 1 5 1 1 0 6 1 1 1 7 0 0 0 0 0 1 0 0 0 1 0 1 0 0 2 1 1 0 0 3 0 0 1 0 4 1 0 1 0 5 0 1 1 0 6 1 1 1 0 7 0 0 0 1 8 1 0 0 1 9 0 1 0 1 A 1 1 0 1 B 0 0 1 1 C 1 0 1 1 D 0 1 1 1 E 1 1 1 1 F IDCS5087 2006-01-23 12 PD243X, PD353X, PD443X Revision History: 2006-01-23 Previous Version: 2004-12-09 Page Subjects (major changes since last revision) Date of change all Lead free device 2006-01-23 Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components1) may only be used in life-support devices or systems2) with the express written approval of OSRAM OS. 1) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. 2) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2006-01-23 13 PD243X, PD353X, PD443X Post Solder Cleaning Procedures The least offensive cleaning solution is hot D.l. water (60 °C) for less than 15 minutes. Addition of mild saponifiers is acceptable. Do not use commercial dishwasher detergents. For faster cleaning, solvents may be used. Carefully choose the solvents as some may chemically attack the package. Maximum exposure should not exceed two minutes at elevated temperatures. Acceptable solvents are: TF (trichlorotrifluoroethane), TA, 111 Trichloroethane, and unheated acetone. (1) Optical Considerations The character heights of these displays allows readability up to eight feet. Proper filter selection allows the user to build a display that can be used over this distance. Filters allow the user to enhance the contrast ratio between a lit LED and the character background. This will maximize discrimination of different characters as perceived by the display user. The only limitation is cost. So first consider the ambient lighting environment to maximize the cost benefit ratio for using filters. Incandescent (with almost no green) or fluorescent (with almost no red) lights do not have the flat spectral response of sunlight. Plastic band-pass filters are inexpensive and effective in optimizing contrast ratios. The PD2435/3535/4435 is high efficiency red display and should be matched with a long wavelength pass filter in the 570 nm to 590 nm range. The PD2436/3536/4436 is a standard red display and should be matched with a long wavelength pass filter in the 600 nm to 620 nm range. The PD2437/3537/4437 should be matched with a yellow-green band-pass filter that peaks at 565 nm. For displays of multiple colors, neutral density grey filters offer the best compromise. Additional contrast enhancement can be gained through shading the displays. Plastic band-pass filters with built-in louvers offer the “next step up” in contrast improvement. Plastic filters can be further improved with anti-reflective coatings to reduce glare. The trade-off is “fuzzy” characters. Mounting the filters close to the display reduces this effect. Care should be taken not to overheat the plastic filters by allowing for proper air flow. Note: 1) Acceptable commercial solvents are: Basic TF Arklone P. Genesolv D, Genesolv DA, BlacoTron TF and Blaco-Tron TA. Do not use solvents containing alcohol, methanol, methylene chloride, ethanol, TP35, TCM, TMC, TMS+, TE, and TES. Since many commercial mixtures exist, you should contact your preferred solvent vendor for chemical composition information. Some major solvent manufacturers are: Allied Chemical Corporation, Specialty Chemical Division, Morristown, NJ; Baron-Blakeslee, Chicago, IL; Dow Chemical, Midland, Ml; E.l. DuPont de Nemours & Co., Wilmington, DE. For further information refer to Appnotes 18 and 19. An alternative to soldering and cleaning the display modules is to use sockets. Naturally, 20 pin DIP sockets 15.24 mm (0.600") wide with 2.54 mm (0.100") centers work well for single displays. Multiple display assemblies are best handled by longer SIP sockets or DIP sockets when available for uniform package alignment. Socket manufacturers include: Aries Electronics, Inc., Frenchtown, NJ; Garry Manufacturing, New Brunswick, NJ; Robinson-Nugent, New Albany, IN; and Samtec Electronic Hardware, New Albany, IN. Optimal filter enhancements for any condition can be gained through the use of circular polarized, anti-reflective, band-pass filters. The circular polarizing further enhances contrast by reducing the light that travels through the filter and reflects back off the display to less than 1%. Proper intensity selection of the displays will allow 10,000 foot candle sunlight viewability. Several filter manufacturers supply quality filter materials. Some of them are: Panelgraphic Corporation, W. Caldwell, NJ; SGL Homalite, Wilmington, DE; 3M Company, Visual Products Division, St. Paul, MN; Polaroid Corporation, Polarizer Division, Cambridge, MA; Marks Polarized Corporation, Deer Park, NY; Hoya Optics, Inc., Fremont, CA. One last note on mounting filters: recessing display and bezel assemblies is an inexpensive way to provide a shading effect in overhead lighting situations. Several Bezel manufacturers are: R.M.F. Products, Batavia, IL; Nobex Components, Griffith Plastic Corp., Burlingame, CA; Photo Chemical Products of California, Santa Monica, CA; I.E.E.Atlas, Van Nuys, CA. See Appnote 23. For further information refer to Appnote 22. Published by OSRAM Opto Semiconductors GmbH Wernerwerkstrasse 2, D-93049 Regensburg www.osram-os.com © All Rights Reserved. 2006-01-23 14
PD4437 价格&库存
很抱歉,暂时无法提供与“PD4437”相匹配的价格&库存,您可以联系我们找货
