CU16029-UW1J
CU16029-UW1J
    NORITAKE
    VFD CHARACTER 16X2 8MM
CU16029-UW1J 数据手册
U VERSION RoHS compliant http://www.noritake-elec.com/uversion.htm ISO 9001 and ISO 14000 Certified Drop-in Replacement for LCD Modules VFD LCD U Version is LCD compatible Vacuum Fluorescent Display (VFD) module and available in 16×2, 20×2, 20×4, 24×2, 40×2, and 40×4 character format. Compared to LCD, U Version VFD module is a bright and vibrant emissive display which makes it easier to read from short and long distance. U version can also withstand the most demanding environmental conditions. The U version products will essentially “drop-in” to many of today’s character module application with no mechanical or wiring change. VALUE ADDED SERVICES FEATURES Value-Added-Services is available per your request. We can install a pin-header, change the jumper setting and provide a cable on each model. Color filter option available now. Please consult us for detail. • • • • • • • • • • • • • LCD Compatible interface (M68 and i80), 4bit or 8bit parallel LCD compatible footprint Emulate command-set of HD44780 LCD controller Wide viewing angle Wide operating temperature range (-40 °C to +85° C) 5V single power supply 4 levels of brightness control by command Power Save Mode is available at display-off Custom font (up to 8 user definable fonts) High brightness Serial Interface is available now The following feature is available for specific item Brightnes boost (200%) capability 3.3V power supply 16x2 Format Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes CU16025-UW30J 5 51.4 x 11.4 80.0 x 36.0 35 3.3 V / 200 mA 3.3 V power of CU16025-UW6J CU16025-UW6J 5 51.4 x 11.4 80.0 x 36.0 35 5 V / 150 mA - New CU16025-UW6A 5 51.4 x 11.4 80.0 x 36.0 35 5 V / 150 mA International Font model of CU16025-UW6J CU16025-UX6J 5 51.4 x 11.4 80.0 x 36.0 35 5 V / 180 mA Brightness Boost model of CU16025-UW6J New CU16025-UX6A 5 51.4 x 11.4 80.0 x 36.0 35 5 V / 180 mA International Font model of CU16025-UX6J CU16025-UW2J 5 51.4 x 11.4 84.0 x 44.0 36 5 V / 150 mA - New CU16029-UW1J 9 82.7 x 19.0 122.0 x 44.0 61 5 V / 340 mA Replacement for CU16029ECPB-W1J CU16029ECPB-W1J 9 82.7 x 19.0 122.0 x 44.0 61 5 V / 350 mA Will be discontinued Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes New CU20025-UX1J 5 70.8 x 11.5 116.0 x 37.0 47 5 V / 210 mA Brightness Boost model of CU20025-UW1J New CU20025-UW1J 5 70.8 x 11.5 116.0 x 37.0 47 5 V / 150 mA - CU20025ECPB-W1J 5 70.8 x 11.5 116.0 x 37.0 47 5 V / 130 mA - New CU20029-UW1J 9 102.6 x 18.8 146.0 x 43.0 70 5 V / 340 mA Replacement for CU20029ECPB-W1J CU20029ECPB-W1J 9 102.6 x 18.8 146.0 x 43.0 70 5 V / 400 mA Will be discontinued Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes CU20045-UW4J 5 70.8 x 20.9 98.0 x 60.0 67 5 V / 250 mA Font table is compatible with HD66712 20x2 Format 20x4 Format CU20045-UW5J 5 70.8 x 20.9 98.0 x 60.0 67 5 V / 250 mA - CU20045-UW5A 5 70.8 x 20.9 98.0 x 60.0 67 5 V / 250 mA International Font model of CU20045-UW5J CU20045-UW7J 5 73.6 x 30.97 100.0 x 61.0 95 5 V / 300 mA - CU20049-UW2J 9 99.6 x 37.6 146.0 x 62.5 155 5 V / 650 mA - CU20049-UW2A 9 99.6 x 37.6 146.0 x 62.5 155 5 V / 650 mA International Font model of CU20049-W2J Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes New CU24025-UW1J 5 85.2 x 11.5 125.0 x 36.0 47 5 V / 165 mA Replacement for CU24025-ECPB-W1J CU24025ECPB-W1J 5 85.2 x 11.5 125.0 x 36.0 50 5 V / 155 mA Will be discontinued Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes CU40025-UW6J 5 138.8 x 11.5 182.0 x 33.5 76 5 V / 300 mA - CU40025-UW6A 5 138.8 x 11.5 182.0 x 33.5 76 5 V / 300 mA International Font model of CU40025-UW6J Part Number Character Height (mm) Display Size (mm) PCB Size (mm) Weight (g) Power Supply Notes CU40045-UW1J 5 137.4 x 23.2 190.0 x 54.0 140 5 V / 520 mA - 24x2 Format 40x2 Format 40x4 Format Noritake Co., Inc. Electronics Division Headquarter 2635 Clearbrook Drive Arlington Heights, IL 60005 Toll free: (800) 779 - 5846 Phone: (847) 439 - 9020 support.ele@noritake.com www.noritake-elec.com East Coast Midwest, Canada, and Mexico West Coast New Jersey Branch Chicago Branch Los Angeles Branch 15-22 Fair Lawn Ave. Fair Lawn, NJ 07410 Toll free: (888) 296 - 3423 Phone: (201) 475 - 5200 Fax: (201) 796 - 2269 2635 Clearbrook Dr. Arlington Heights, IL 60005 Toll free: (800) 779 - 5846 Phone: (847) 439 - 9020 Fax: (847) 593 - 2285 21081 S. Western Ave. Ste 180 Torrance, CA 90501 Toll free: (888) 795 - 3423 Phone: (310) 320 - 1700 Fax: (310) 320 - 2900 E-M-0023-01
CU16029-UW1J
物料型号:文档列出了多种型号的真空荧光显示器(VFD)模块,包括16x2、20x2、20x4、24x2和40x2格式。
器件简介:U Version是LCD兼容的VFD模块,具有明亮且生动的发射显示,适合远近阅读,并且能够承受苛刻的环境条件。
引脚分配:文档没有明确提供引脚分配的详细信息,但提到了LCD兼容接口(M68和i80),4位或8位并行。
参数特性:包括LCD兼容的接口、LCD兼容的尺寸、HD44780 LCD控制器的命令集仿真、宽视角、宽工作温度范围(-40°C至+85°C)、5V单电源供电、4级亮度控制、显示关闭时的节能模式、自定义字体(最多8种用户可定义字体)、高亮度、现在提供串行接口。
功能详解:文档提到了亮度增强(200%)能力、3.3V电源供应等特定项目的功能。
应用信息:U Version产品可以作为许多当今字符模块应用的“即插即用”替代品,无需机械或接线更改。
封装信息:文档提供了不同型号的显示尺寸、PCB尺寸、重量和电源要求。
CU16029-UW1J 价格&库存
很抱歉,暂时无法提供与“CU16029-UW1J”相匹配的价格&库存,您可以联系我们找货
