CU22042-Y100
CU22042-Y100
    NORITAKE
    VFD CHARACTER 22X4 2.35MM
CU22042-Y100 数据手册
Y SERIES RoHS compliant http://www.noritake-elec.com/y-series.htm 16 x 2 LCD footprint CU22042-Y1A / 100 ISO 9001 and ISO 14000 Certified Character number comparison CU22042-Y1A 88 16x2 32 25 50 20 x 2 LCD footprint Brightness comparison (Cd/m2) CU20027-YX1A CU20027-Y1A / Y100 CU20027-YX1A 100 400% CU20027-Y1A 200% CU22043-Y1A 200% CU24043-Y1A 200% CU24063-Y1A 200% U Version CU24043-Y1A / Y100 1000 2000 4000 Character number comparison CU24043-Y1A 96 20x2 20 x 4 LCD footprint CU24063-Y1A / Y100 40 25 50 100 Character number comparison CU24063-Y1A 144 20x4 80 50 100 150 New to the Y Series Available interfaces CU22042-Y1A 22x4 characters in 16x2 LCD footprint. 8 bit parallel interface (i80 type) Data 8 WR Busy Host Y Series Async serial interface Sync serial interface Data CU20027-YX1A 20x2 LCD footprint and brightest Vacuum Fluorescent Display (VFD) module from Noritake Itron. Host Y Series Busy Data SCK Busy Host Y Series Block Diagram Features - Easy command set - 2x the brightness with the brightness boost - Highlight character - 16 UDF and 1 custom font table - 14 International font tables and 10 extended ASCII - Select from 1x1, 1x2, and 2x2 character sizes - More characters in compact display size - 1U rack height models available - Available in i80 8-bit parallel, asynchronous serial, synchronous serial, and async RS232 interfaces - Reliability in all environmental conditions - Wide temperature range of -40°C up to +85°C Parallel IF Connector Parallel IF Circuit Controller Serial IF Connector Serial IF Circuit Flash Memory Custom Fonts Flash memory has approximately 10,000 write-erase-cycles. VFD Firmware Font Table + 5V DC Jumper DC/DC Converter GND Value Added Services Let us pre-assemble the connectors, cables, color filter, and/or conformal coating with your VFD. Evaluation kits available Visit our online shop for Y Series evaluation kits: noritake-vfd.com/yseries.aspx VFD module with color filter Part Number Number of Characters Character Height (mm) Display Size (mm) PCB Size (mm) Interface i80 8-bit Parallel (5V CMOS) Async Serial (5V CMOS) Sync Serial (5V CMOS) Power Supply Typical CU20027-Y1A 20 x 2 7 73.4 x 15.0 116.0 x 37.0 New CU22042-Y1A 22 x 4 2 52.5 x 11.5 80.0 x 36.0 CU24043-Y1A 24 x 4 3 73.4 x 15.0 116.0 x 37.0 CU24063-Y1A 24 x 6 3 70.4 x 22.7 98.0 x 47.0 5 V / 320 mA New CU20027-YX1A 20 x 2 7 73.4 x 15.0 116.0 x 37.0 5 V / 230 mA New CU200211-Y1A 20 x 2 11 159.0 x 23.6 190.0 x 55.0 5 V / 720 mA 5 V / 180 mA 5 V / 220 mA CU20027-Y100 20 x 2 7 73.4 x 15.0 116.0 x 37.0 New CU22042-Y100 22 x 4 2 52.5 x 11.5 80.0 x 36.0 CU24043-Y100 24 x 4 3 73.4 x 15.0 116.0 x 37.0 5 V / 220 mA CU24063-Y100 24 x 6 3 70.4 x 22.7 98.0 x 47.0 5 V / 320 mA New CU200211-Y100 20 x 2 11 159.0 x 23.6 190.0 x 55.0 5 v / 720 mA Noritake Co., Inc. Electronics Division Headquarter 2635 Clearbrook Drive Arlington Heights, IL 60005 Toll free: (800) 779 - 5846 Phone: (847) 439 - 9020 support.ele@noritake.com www.noritake-elec.com i80 8-bit Parallel (5V CMOS) Async Serial (RS232) 5 V / 240 mA East Coast Midwest, Canada, and Mexico West Coast 15-22 Fair Lawn Ave. Fair Lawn, NJ 07410 Toll free: (888) 296 - 3423 Phone: (201) 475 - 5200 Fax: (201) 796 - 2269 2635 Clearbrook Dr. Arlington Heights, IL 60005 Toll free: (800) 779 - 5846 Phone: (847) 439 - 9020 Fax: (847) 593 - 2285 21081 S. Western Ave. Ste 180 Torrance, CA 90501 Toll free: (888) 795 - 3423 Phone: (310) 320 - 1700 Fax: (310) 320 - 2900 New Jersey Branch Chicago Branch 5 V / 240 mA 5 V / 180 mA Los Angeles Branch E-M1-0001-09
CU22042-Y100 价格&库存
很抱歉,暂时无法提供与“CU22042-Y100”相匹配的价格&库存,您可以联系我们找货
