SCK128X8T-N026
SCK128X8T-N026
    NORITAKE
    Vacuum Fluorescent Display (VFD) 21 x 1 Character USB 376.00mm x 57.00mm x 15.00mm
SCK128X8T-N026 数据手册
Star Bright DOCUMENT# E-M-0065-01 Quick Start Guide Date : November 16, 2011 1 Package Contents 1.1 Confirm all components are enclosed 1 /4 1. 2. 3. 4. 5. 6. Star Bright DC Plug Adaptor AC Adaptor USB Cable Remote Controller CD-ROM 6 CD-ROM contains Application software, Message samples, and Quick Start Guide (This document). Note: AAA batteries not included. 2 Hardware setup 2.1 Insert Remote Controller batteries To insert batteries remove the battery cover on the back and insert two AAA batteries as shown right. Direction of battery is also shown in the compartment. Replace battery cover and press a button to check that the LED at the top left of the keyboard flashes. 2.2 Plug the DC Plug Adaptor into DC jacks Note: Please do not connect or disconnect the DC Plug Adaptor while the power is on. 2.3 Plug in the AC Adaptor Note: Please connect the AC Adaptor directly to the AC wall outlet for stable voltage. Star Bright DOCUMENT# E-M-0065-01 2.4 2 /4 Quick Start Guide Date : November 16, 2011 Wait 5 seconds after applying power Note: Please do not use the Remote Controller at this time. 2.5 Check for proper Remote Controller operation To test the Remote Controller, press buttons „1‟ though „F‟ on the Remote Controller to switch between the preloaded messages. The Remote Controller is considered working when messages switch via pushing different number keys. Note: Wording of the display may vary. 2.6 Plug the USB Cable Connect the USB Cable to the Star Bright‟s USB Port located on the back of the middle. Then connect the opposite end of the USB Cable to the available USB Port on your PC. 2.7 USB Installation The display will automatically install Printer when the display is initially connected. The following pop ups shown on the left will appear when the display is recognized. No driver software is required. Star Bright DOCUMENT# E-M-0065-01 3 /4 Quick Start Guide Date : November 16, 2011 Check that the printer is installed as “Generic / Text Only”. 3 Software setup 3.1 Install Star Bright Message Editor from table of contents 1. 2. 3. 4. 5. 6. 3.2 Insert enclosed CD-ROM. The table of contents will show up automatically. Click the Star Bright Message Editor OPEN icon. Run installer program “Star Bright Message Editor ver. 2.1.EXE”. Follow the instructions on the installer program. When the installer is successfully completed, the Star Bright Message Editor shortcut will appear on your desktop. Manual installation of Star Bright Message Editor To manually install Star Bright Message Editor, please follow the instructions below: 1. 2. 3. Open the Software folder in the CD-ROM. Run Star Bright Message Editor ver. 2.1.EXE. Follow the instructions. Star Bright DOCUMENT# E-M-0065-01 Create and send messages 4.1 Basic steps Type text message 4.2 Quick Start Guide Date : November 16, 2011 4 4 /4 Add display action Send the message The new message will appear on the Star Bright Follow the instructions Send the message The new message will appear on the Star Bright Send the message The new message will appear on the Star Bright Using Wizard Select Wizard under File menu And add message text 4.3 Using Templates Select Templates under File menu 5 Edit sample messages Contact Please direct all inquires to Noritake Sales office below. Or, go to online: http://www.noritake-elec.com/contact_us.htm West Coast Midwest East Coast Los Angeles Branch 21081 S. Western Ave. Ste 180 Torrance, CA 90501 Tel. (888) 795 - 3423 Electronics Div. HQ Chicago Branch 2635 Clearbrook Dr. Arlington Heights, IL 60005 Tel. (800) 779 - 5846 New Jersey Branch 15-22 Fair Lawn Ave. Fair Lawn, NJ 07410 Tel. (888) 296 - 3423
SCK128X8T-N026 价格&库存
很抱歉,暂时无法提供与“SCK128X8T-N026”相匹配的价格&库存,您可以联系我们找货
