MK-070R
MK-070R
    AMULET
    MK-070R
MK-070R 数据手册
Amulet 7” Color Module™ 7” GEMmodule™ Introduction: The MK-070R is a fully integrated 7” WVGA production color display module to support a variety of embedded control interface applications. Featuring the Amulet GEM Graphical OS Chip™ for color displays, the module can be easily programmed using GEMstudioTM, the easiest GUI design tool in the embedded space. MK-070R Data Sheet Features: • 800x480 WVGA TFT LCD • White LED backlight • Integrated resistive touch panel • Amulet GEM Graphical OS ChipTM • 24 Pin Interconnector • Royalty-free Graphical Operating SystemTM • On-Board memory - 64Mb Serial Flash for storing GUI pages • Touch Panel Controller - Built into Graphical OS Chip™ • Color Supported - Palettized 8bit (1-bit alpha) • Backlight can be controlled via the touch panel or external command • Supports Unicode - Foreign language character sets • Font Converter - Built-in MK-070R Datasheet 1.4 - 0819 General Specification ITEM Pixels (Resolution) Outline dimension Active area Pixel Size Luminance Operation Temp. STANDARD VALUE 800 X 480 164.9(H) x 100(V) x TBD(D) 154.8(H) x 85.92(V) 0.1929 x 0.179 350 Typ. 70 -20 View Angle Display Mode Backlight Backlight Control Data Flash Interface 12 OʼClock TM, NW 24 White LED PWM 64 Megabit USB /RS232 /UART UNIT dots mm mm mm Cd/m2 C Electrical Characteristic Recommended Operating Conditions 5V 5V Recommended 5V Current TBD Min DC Characteristics V core Supply Current V input Low Level V input High Level Pull Up Resistors IO Output Current Static Current Excluding Power on Reset V core = 1.2V Static Current Logic cells consumption, including Power on Reset and all input drivers V core = 1.2V 22mA @1.2V -0.3 to 0.8V 2V to (Vcc + 0.3V ) 70K to 175KOhms 8mA 600uA 30uA Pin Descriptions Pin Type I = Input O = Output P = Power Supply Pin # Signal Type Description 1 5V P 5V @ 300mA 2 5V P 5V @ 300mA 3 GND P Ground 4 GND P Ground 5 SCL O Serial Clock 6 SDA O Serial Data 7 COMMU RXD I CommU RXD UART 8 COMMU TXD O CommU TXD UART 9 PWM 1 O Programmable Clock 1 10 PWM 2 O Programmable Clock 2 11 Prog M I Program Mode - Float = Prog / GND = Run Note:1 12 PWM 0 O Programmable Clock 0 13 RS232 TXD O TXD from RS232 Transceiver 14 T_CAL I Touch Panel Cal. - Float = Cal / GND = Normal Note:1 15 PROGU RXD I PROGU RXD UART 16 PROGU TXD O PROGU TXD UART 17 SPI C3 O SPI Chip Select 3 18 RS232 RXD I RXD from RS232 Transceiver 19 SPI C2 O SPI Chip Select 2 21 MISO O SPI DATA In 22 SCLK O SPI Clock 23 RESET O System Reset by driving pin low 20 24 MOSI O SPI DATA Out Note:1 Internally pulled up. Only pull to ground Errata: For MK-070R Revision XB2, Pin 11 (Prog M) is a no-connect. Do NOT connect to this pin Table 1. Header J3 24pin, 2mm, Hirose DF-11-24DP-2DSA Mating Connectors Hirose DF11-24DS-2R26 Straight DF11-24DS-2C Right Angle DF11-24DS-2DSA Board JST PHDR-24VS MK-070R Datasheet 1.4 - 0819 MK-070R Datasheet 1.4 - 0819 J3 Wiring Connecting Project via UART Pin 1 5V Pin 2 5V Pin 3 GND Pin 4 GND Pin 7 COMMU RXD Pin 8 COMMU TXD Projects UART 3.3V Levels J3 Note: Cut Trace across SD and Jumper “D” side to C38 “8” side GND to take the RS232 Tranceiver out of circuit. Connecting Project via RS232 Pin 1 5V Pin 2 5V Pin 3 GND Pin 4 GND Pin 13 RS232 TXD PIN 18 RS232 RXD J3 Projects RS232 to COMMU RS232 Notes: MK-070R Datasheet 1.4 - 0819 MK-070R Datasheet 1.4 - 0819 Communication and Program UARTs can be used for programming as well as for communication with the application’s host processor. If you wish to program via UART make sure you can get to the Reset and the Program Mode pins. These will only be needed if a serious programming issue occurs. Pass-Through Programming information is available at our website under Field Update Utilities: http:// www.amulettechnologies.com/support/downloads/fieldupdates.html. Momentarily grounding reset with an open collector device or momentary switch will cause a reset. Reset must be applied after the Program Mode pin is changed for us to see it. MK-070R Datasheet 1.4 - 0819 MK-070R Datasheet 1.4 - 0819 Tel (408) 374-4956 Fax (408) 374-4941 http://www.AmuletTechnologies.com Sales@AmuletTechnologies.com Support@AmuletTechnologies.com 1475 S. Bascom Ave., Suite 111 Campbell, CA 95008 USA Disclaimer: The information in this document is provided in connection with Amulet Technologies, LLC (Amulet) products. No license, express or implied, to any intellectual property right is granted by this document or in connection with the sale of Amulet products. EXCEPT AS SET FORTH IN AMULET’S TERMS AND CONDITIONS OF SALE WHERE AMULET IS THE SELLER, AMULET ASSUMES NO LIABILITY WHATSOEVER AND DISCLAIMS ANY EXPRESS, IMPLIED OR STATUTORY WARRANTY RELATING TO ITS PRODUCTS INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL AMULET BE LIABLE FOR ANY DIRECT, INDIRECT, CONSEQUENTIAL, PUNITIVE, SPECIAL OR INCIDENTAL DAMAGES (INCLUDING, WITHOUT LIMITATION, DAMAGES FOR LOSS AND PROFITS, BUSINESS INTERRUPTION, OR LOSS OF INFORMATION) ARISING OUT OF THE USE OR INABILITY TO USE THIS DOCUMENT, EVEN IF AMULET HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Amulet makes no representations or warranties with respect to the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Amulet does not make any commitment to update the information contained herein. Unless specifically provided otherwise, Amulet products are not approved for use in automotive applications, medical applications (including, but not limited to, life support systems and other medical equipment), avionics, nuclear applications, or other high-risk applications (e.g., applications that, if they fail, can be reasonably expected to result in significant personal injury or death).
MK-070R 价格&库存
很抱歉,暂时无法提供与“MK-070R”相匹配的价格&库存,您可以联系我们找货
