SPECIFICATION FOR APPROVAL
※This is a RoHS and REACH compliant product whose related documents are available on request.
※Graphic is only for dimensionally application.
1. PART NUMBER IDENTIFICATION
CSME
0315 D - □□□ □ - LRH
RoHS+H.F.
TOLERANCE
INDUCTANCE
TERMINAL TYPE
DIMENSION
PRODUCT CODE
2. MECHANICAL DIMENSION
UNIT : mm
DIM.
TOL.
M1
3.0
±0.2
M2
3.0
±0.2
M3
1.5
MAX.
M4
2.7
±0.2
M5
0.75
±0.2
M6
1.5
±0.2
3. STRUCTURE
4. MATERIAL LIST
NO
Rev.B
PARTS
MATERIAL
1
DRUM CORE
Ni-Zn FERRITE CORE
2
WIRE
POLYURETHANE ENAMELED COPPER WIRE
3
ADHESIVE
EPOXY RESIN MAGNETIC POWDER
4
PLATING ELECTRODES
PLATING: Ag 10-20 um Ni 1-3 um Sn 3-7 um
5
OUTER ELECTRODES
TOP SURFACE SOLDER COATING Sn99%、
Ag0.3%、Cu0.7%
P3
Prosperity Dielectrics Co., Ltd.
5. ELECTRICAL CHARACTERISTICS
Part Number.
Inductance
(uH)
DCR
(mΩ)
±30%
Isat
(A)
MAX.
Irise
(A)
MAX.
CSME0315D-1R0N-LRH
1.0
30
2.10
2.10
CSME0315D-1R5N-LRH
1.5
38
1.80
1.82
CSME0315D-2R2M-LRH
2.2
58
1.48
1.50
CSME0315D-3R3M-LRH
3.3
78
1.21
1.23
CSME0315D-4R7M-LRH
4.7
120
1.02
1.04
CSME0315D-6R8M-LRH
6.8
160
0.87
0.88
CSME0315D-100M-LRH
10
220
0.70
0.71
CSME0315D-220M-LRH
22
520
0.47
0.47
□TOLERANCE:M:±20%、N:±30%
※ INDUCTANCE:@100KHz,0.25V
※ TEST MACHINE: HIOKI3532-50 OR EQUIVALENT
※ DC RESISTANCE: HIOKI 3540 OR EQUIVALENT
※ ISAT / IRISE: HP4284+42841A OR EQUIVALENT
※ OPERATING TEMPERATURE: -40℃ ~ +125℃.
※ INDUCTANCE DROPS NO MORE THAN 30% OF INITIAL VALUE AT ISAT.
※ TEMPERATURE RISES:△ t< 40℃ AT IRMS.
※ MSL:LEVEL 1.
Rev.B
P4
6. RELIABILITY PERFORMANCE
6-1.Storage Temperature range:-40℃~ +105℃
6-2.Operating temperature range:-40℃ ~ +125℃ (Including coil’s self temperature rise)
6-3.External appearance:No external defects can be found in the visual inspection.
6-4.Electrode strength:No electrode detachment should be found when the device is pushed in two
directions of X and Y with the force of 10.0N for 60±2 seconds after soldering
between copper plate and the electrodes. (Refer to figure at right)
6-5.Vibration test:Inductance deviation is within ±10.0% after 1 hour sweeping vibration in each three
directions, namely, forward and backward, up and down,right and left. The frequency is
10~55~10Hz and the amplitude of 1 minute cycle is 1.5mm PP.
6-6.Humidity test:Inductance deviation is within ±5.0% after 96±4 hours test under the condition of relative
humidity of 90~95% and temperature of 60±2℃,and 1 hour storage under room ambient
conditions after the device is wiped with dry cloth.
Rev.B
P5
7. TYPICAL RoHS REFLOW PROFILE
*Temperature on
surface of circuit board
The products may be exposed to reflow soldering process of above profile up to two times.
Rev.B
P6
8. PACKAGING
8-1 OUTER PACKING
2 KPCS/REEL;20 KPCS/INNER BOX;80 KPCS/OUTER BOX
8-2 CARRIER TAPE DIMENSIONS
UNIT : mm
ITEM
W
P
F
E
D0
P0
P2
T
A0
B0
K0
DIM
8.00
4.00
3.50
1.75
1.50
4.00
2.00
0.25
3.3
3.3
1.9
TOLE
±0.3
±0.1
±0.05
±0.1
+0.1
±0.1
±0.05
±0.05
±0.05
±0.05
±0.05
8-3 CARRIER REEL DIMENSIONS
UNIT : mm
Rev.B
Type
A
B
C
G
N
T
8mm
178
20±0.8
13±0.4
9
60
10.8
P7
很抱歉,暂时无法提供与“CSME0315D-100M-LRH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.24800
- 50+0.22940
- 200+0.21390
- 600+0.19840
- 1500+0.18600
- 3000+0.17825
- 国内价格
- 10+0.54200
- 50+0.43290
- 200+0.38730
- 600+0.36450
- 1500+0.31890
- 3000+0.22780
