4DLCD-144
4DLCD-144
    4DSYSTEMS
    4DLCD-144
4DLCD-144 数据手册
4DLCD-144 Datasheet Revision 1.3 Copyright © 2023 4D Systems Content may change at any time. Please refer to the resource centre for latest documentation. Contents 1. General Specification 3 2. TFT LCD Display Drawing 4 3. Absolute Maximum Ratings 5 4. Electrical Characteristics 5 5. Backlight Characteristics 5 6. Electro-Optical Characteristics 6 7. Interface Descriptions 9 8. Initialisation Codes 10 8.1. ST7735 Driver IC Version 10 8.2. ST7735R Driver IC Version 12 8.3. ILI9163C Driver IC Version 13 8.4. ST7735S Driver IC Version 14 8.5. Reading Driver IC 15 9. LCD Timing Details 16 9.1. Timing Chart 16 9.2. Reset Timing 18 9.3. Power On Sequence 19 9.3.1. Case 1 - RES line is held High or Unstable by Host at Power ON 19 9.3.2. Case 2 - RES line is held Low by Host at Power ON 19 9.4. Power-off Sequence - Uncontrolled Power Off 19 10. Reliability Test 20 11. Precautions for Using LCD Modules 21 11.1. Handing Precautions 21 11.2. Storage Precautions 23 12. Revision History 4D Systems 24 DATASHEET Page 2 of 24 4DLCD-144 General Specification 1. General Specification 4DLCD-144ST is a colour active matrix LCD module incorporating amorphous silicon TFT (Thin Film Transistor). It is composed of a colour TFT-LCD panel, driver IC, Solder Type FPC and a back light unit. The module display area contains 128x128 pixels. This product accords with RoHS environmental criterion. ITEM CONTENTS UNIT LCD Type TFT / Transmissive / Normally white Size 1.44 Inch Viewing Direction 12:00 (without image inversion) O'Clock Gray Scale InversionDirection 6:00 O'Clock LCD (W × H x D) 30.9 x 36.51 x 2.9 mm Active Area (W × H) 25.5 × 26.5 mm Dot Pitch (W × H) 0.199 × 0.207 mm Number of Dots (Pixels) 128 (RGB) × 128 Driver IC ST7735S Backlight Type 1 LED Surface Luminance 120 (typical) Interface Type MCU-8bit Color Depth 262K Pixel Arrangement RGB Vertical Stripe Surface Treatment AG Weight 4 Physical Connection Type Solder Type FPC - 0.8mm pitch, see drawing (Solders direct to PCB, no connector) cd/m2 g Part Number Details 4DLCD - 4DLCD LCD Display 144ST - 1.44 inch, 128 x 128 Resolution, Standard Model Note 1. RoHS compliant 2. LCD weight tolerance: ± 5%. 4D Systems DATASHEET Page 3 of 24 4DLCD-144 TFT LCD Display Drawing 2. TFT LCD Display Drawing 4D Systems DATASHEET Page 4 of 24 4DLCD-144 Absolute Maximum Ratings 3. Absolute Maximum Ratings Absolute Maximum Ratings PARAMETER SYMBOL MIN MAX UNIT VDD -0.3 4.6 V IF - 25 mA Operating Temperature TOP -20 70 °C Storage Temperature TST -30 80 °C Humidity RH 10% 90% (Max 60°C) RH Supply Voltage for LCD Logic LED forward current (each LED) 4. Electrical Characteristics Electrical Characteristics PARAMETER SYMBOL MIN TYP MAX UNIT Power Voltage VDD 2.6 2.8 3.3 V Input Current (Logic) IVDD - 10 - mA Input Voltage ‘H’ Level VIH 0.7VDD - VDD V Input Voltage ‘L’ Level VIL 0 - 0.2VDD V SYMBOL MIN TYP MAX UNIT Voltage for LED backlight Vl - 2.8 3.1 V Current for LED backlight Il - 20 25 mA LED Life Time - 30000 - - Hrs 5. Backlight Characteristics Backlight Characteristics PARAMETER Note The LED life time is defined as the module brightness decrease to 50% of original brightness at Ta=25°C. 4D Systems DATASHEET Page 5 of 24 4DLCD-144 Electro-Optical Characteristics 6. Electro-Optical Characteristics Electro-Optical Characteristics ITEM SYM CONDITION MIN TYP MAX UNIT REMARK Response Time Tr+Tf θ=0 - 25 - ms see figure Contrast Ratio Cr ° - 350 - - see figure ∅=0 75 80 - % see figure Luminance Uniformity δ WHITE Surface Luminance Lv 20mA - 120 - cd/m2 see figure Viewing Angle Range θ ∅ = 90° - 35 - deg see figure ∅ = 270° - 15 - deg ∅ = 0° - 45 - deg ∅ = 180° - 45 - deg x 0.558 0.608 0.628 y 0.296 0.316 0.336 CIE (x,y) Cromacity Red Green Blue White Transmittance 4D Systems x θ=0° 0.285 0.305 0.325 y ∅=0° 0.536 0.556 0.576 x Ta=25 0.115 0.135 0.155 y 0.117 0.137 0.157 x 0.285 0.305 0.325 y 0.314 0.334 0.354 T - 6 - DATASHEET see figure % Page 6 of 24 4DLCD-144 Electro-Optical Characteristics The definition of response time Measuring method for Contrast ratio, surface luminance, Luminance uniformity, CIE (x, y) chromaticity The definition of viewing angle 4D Systems DATASHEET Page 7 of 24 4DLCD-144 Electro-Optical Characteristics Note 1. Contrast Ratio(CR) is defined mathematically as below, for more information see figure. 2. Surface luminance is the LCD surface from the surface with all pixels displaying white. For more information, see figure. 3. The uniformity in surface luminance δ WHITE is determined by measuring luminance at each test position 1 through 5, and then dividing the maximum luminance of 5 points luminance by the minimum luminance of 5 points luminance. For more information, see figure. 4. Response time is the time required for the display to transition from white to black (Rise Time, Tr) and from black to white (Decay Time, Tf). For additional information see Figure 1. The test equipment is the Autronic-Melchers ConoScope series. 5. CIE (x, y) chromaticity, the x and y value is determined by measuring luminance at each test position 1 through 5, and then making the average value. 6. Viewing angle is the angle at which the contrast ratio is greater than 2. For the TFT module, the contrast ratio is greater than 10. The angles are determined for the horizontal or x-axis and the vertical or y-axis to the z-axis which is normal to the LCD surface. For more information, see figure. 7. For viewing angle and response time testing, the testing data is based on the Autronic-Melchers ConoScope series. Instruments for Contrast Ratio, Surface Luminance, Luminance Uniformity, and CIE the test data is based on TOPCONs BM-5 photodetector. 4D Systems DATASHEET Page 8 of 24 4DLCD-144 Interface Descriptions 7. Interface Descriptions LCD Interface PIN NO. 4D Systems SYMBOL DESCRIPTION 1 VDD Logic Power Supply 2 GND Logic Power GND 3 NC Not Connected Can tie to GND 4 TE-NC Not Connected Can tie to GND 5 CS Chip select input pin (Active Low) 6 RS Data/Command selection pin 7 RD Read Select signal (Active Low) 8 WR Write Select signal (Active Low) 9 RESET LCD Reset Pin (Active Low) 10 D0 Databus Bit 0 11 NC Not Connected 12 D0 Databus Bit 1 13 NC Not Connected 14 D0 Databus Bit 2 15 NC Not Connected 16 D0 Databus Bit 3 17 NC Not Connected 18 D0 Databus Bit 4 19 NC Not Connected 20 D0 Databus Bit 5 21 NC Not Connected 22 D0 Databus Bit 6 23 NC Not Connected 24 D0 Databus Bit 7 25 NC Not Connected 26 LEDK (-) Backlight LED Supply -ve 27 LEDA (+) Backlight LED Supply +ve DATASHEET REMARK Leave Open  Leave Open   Leave Open  Leave Open  Leave Open   Leave Open  Leave Open  Leave Open   Page 9 of 24 4DLCD-144 Initialisation Codes 8. Initialisation Codes There are 4 versions of the 4DLCD-144, as the Driver IC has been changed over the years and new init codes are required. ST7735, ST7735R, ST7735S and ILI9163C 8.1. ST7735 Driver IC Version Sold approximately early 2010 (Initial batch sold only) Value Remarks NVCTR1 0xD9 unique to ST7735 COLMOD 0x3a PWCTR6 0xFC unique to ST7735 FRMCTR1 0xB1 VCOM4L 0xFF unique to ST7735 FRMCTR2 0xB2 SWRESET 0x01 FRMCTR3 0xB3 RDDID 0x04 INVCTR 0xB4 SLPIN 0x10 DISSET5 0xB6 SLPOUT 0x11 PWCTR1 0xC0 PTLON 0x12 PWCTR2 0xC1 DISPOFF 0x28 PWCTR3 0xC2 DISPON 0x29 PWCTR4 0xC3 CASET 0x2A PWCTR5 0xC4 RASET 0x2B VMCTR1 0xC5 RAMWR 0x2C GAMCTRP1 0xE0 RAMRD 0x2E GAMCTRN1 0xE1 PTLAR 0x30 F0new 0xF0 MADCTL 0x36 F6new 0xF6 4D Systems Value DATASHEET Remarks Page 10 of 24 4DLCD-144 ST7735 Driver IC Version Init Code: (Command, Data1, Data2...DataN) SWRESET, Delay 10ms, SLPOUT, Delay 120ms, VCOM4L, 0x40, 0x03, 0x1a, NVCTR1, 0x60, 0xc7, 0x90, Delay 200ms, FRMCTR1, 0x04, 0x25, 0x18, FRMCTR2, 0x04, 0x25, 0x18, FRMCTR3, 0x04, 0x25, 0x18, 0x04, 0x25, 0x18, INVCTR, 0x03, DISSET5, 0x15, 0x02, PWCTR1, 0x02, 0x70, PWCTR2, 0x07, PWCTR3, 0x01, 0x01, PWCTR4, 0x02, 0x07, PWCTR5, 0x02, 0x04, PWCTR6, 0x11, 0x17, VMCTR1, 0x3c, 0x4f, MADCTL, 0xc8, COLMOD, 0x05, GAMCTRP1, 0x08, 0x19, 0x16, 0x36, 0x38, 0x2d, 0x25, 0x2a, 0x28, 0x26, 0x33, 0x3d, 0x04, 0x06, 0x03, 0x0e, GAMCTRN1, 0x09, 0x1f, 0x17, 0x36, 0x37, 0x33, 0x2c, 0x32, 0x2f, 0x2c, 0x33, 0x3c, 0x06, 0x06, 0x03, 0x0f, DISPON, Delay 10ms, RAMWR 4D Systems DATASHEET Page 11 of 24 4DLCD-144 ST7735R Driver IC Version 8.2. ST7735R Driver IC Version Sold approximately 2011 to 2013 Value Value Value SWRESET 0x01 RAMRD 0x2E PWCTR2 0xC1 RDDID 0x04 PTLAR 0x30 PWCTR3 0xC2 SLPIN 0x10 MADCTL 0x36 PWCTR4 0xC3 SLPOUT 0x11 COLMOD 0x3a PWCTR5 0xC4 PTLON 0x12 FRMCTR1 0xB1 VMCTR1 0xC5 DISPOFF 0x28 FRMCTR2 0xB2 GAMCTRP1 0xE0 DISPON 0x29 FRMCTR3 0xB3 GAMCTRN1 0xE1 CASET 0x2A INVCTR 0xB4 F0new 0xF0 RASET 0x2B DISSET5 0xB6 F6new 0xF6 RAMWR 0x2C PWCTR1 0xC0 Init Code: (Command, Data1, ... DataN) SWRESET, delay 10ms, SLPOUT, //Sleep Out delay 120ms, FRMCTR1, 0x02, 0x35, 0x36, //Setup Frame Rate Control (In FRMCTR2, 0x02, 0x35, 0x36, //Setup Frame Rate Control (In FRMCTR3, 0x02, 0x35, 0x36, 0x02, 0x35, 0x36, //Frame Rate INVCTR, 0x07, DISSET5, 0xB4, 0xF0, PWCTR1, 0xA2, 0x02, 0x84, PWCTR2, 0xC5, PWCTR3, 0x0A, 0x00, PWCTR4, 0x8A, 0x2A, PWCTR5, 0x8A, 0xEE, VMCTR1, 0x06, MADCTL, 0xC8, GAMCTRP1, 0x12, 0x1C, 0x10, 0x18, 0x33, 0x2C, 0x25, 0x28, 0x03, 0x10, GAMCTRN1, 0x12, 0x1C, 0x10, 0x18, 0x2D, 0x28, 0x23, 0x28, 0x03, 0x10, F0new, 0X01, F6new, 0X00, COLMOD, 0X05, CASET, 0x00, 0x02, 0x00, 0x81, RASET, 0x00, 0x03, 0x00, 0x82, DISPON, delay 10ms, RAMWR 4D Systems DATASHEET Normal Mode/ Full Colours) Idle Mode/ 8-Colors) Control (Partial Mode/ Full Colours) 0x28, 0x27, 0x2F, 0x3C, 0x00, 0x03, 0x28, 0x26, 0x2F, 0x3B, 0x00, 0x03, Page 12 of 24 4DLCD-144 ILI9163C Driver IC Version 8.3. ILI9163C Driver IC Version Sold approximately 2013 to late 2019 Value Value SWRESET 0x01 FRMCTR1 0xB1 SLPOUT 0x11 SDDC 0xB7 GAMMASET 0x26 PWCTR1 0xC0 DISPOFF 0x28 PWCTR2 0xC1 DISPON 0x29 VMCTR1 0xC5 CASET 0x2A VOC 0xC7 RASET 0x2B GAMCTRP1 0xE0 RAMWR 0x2C GAMCTRN1 0xE1 RAMRD 0x2E UNDOC 0xEC MADCTL 0x36 GRSEL 0xF2 IPF 0x3A Init Code: (Command, Data1, ... DataN) SWRESET, delay 10ms, DISPON, delay 100ms, SLPOUT, delay 20ms, GAMMASET, 0x04, FRMCTR1, 0x0B, 0x14, PWCTR1, 0x10, 0x00, PWCTR2, 0x03, VMCTR1, 0x46, 0x40, VOC, 0xBD, UNDOC, 0x0C, IPF, 0x05, CASET, 0x00, 0x00, 0x00, 0x7F, PASET, 0x00, 0x00, 0x00, 0x7F, MADCTL, 0xC8, SDDC, 0x00, GRSEL, 0x01, GAMCTRP1, 0x3F, 0x29, 0x27, 0x2C, 0x27, 0x0C, 0x54, 0xC7, 0x40, 0x19, 0x17, 0x1E, 0x02, 0x01, 0x00, GAMCTRN1, 0x00, 0x16, 0x18, 0x13, 0x18, 0x13, 0x2B, 0x38, 0x3F, 0x06, 0x18, 0x21, 0x3D, 0x3E, 0x3F, DISPON 4D Systems DATASHEET Page 13 of 24 4DLCD-144 ST7735S Driver IC Version 8.4. ST7735S Driver IC Version Sold approximately late 2019 to present Value Value Value SWRESET 0x01 RAMRD 0x2E PWCTR2 0xC1 RDDID 0x04 PTLAR 0x30 PWCTR3 0xC2 SLPIN 0x10 MADCTL 0x36 PWCTR4 0xC3 SLPOUT 0x11 COLMOD 0x3a PWCTR5 0xC4 PTLON 0x12 FRMCTR1 0xB1 VMCTR1 0xC5 DISPOFF 0x28 FRMCTR2 0xB2 GAMCTRP1 0xE0 DISPON 0x29 FRMCTR3 0xB3 GAMCTRN1 0xE1 CASET 0x2A INVCTR 0xB4 F0new 0xF0 RASET 0x2B DISSET5 0xB6 F6new 0xF6 RAMWR 0x2C PWCTR1 0xC0 Init Code: (Command, Data1, ... DataN) SWRESET, delay 10ms, SLPOUT, //Sleep Out delay 120ms, FRMCTR1, 0x02, 0x35, 0x36, //Setup Frame Rate Control (In FRMCTR2, 0x02, 0x35, 0x36, //Setup Frame Rate Control (In FRMCTR3, 0x02, 0x35, 0x36, 0x02, 0x35, 0x36, //Frame Rate INVCTR, 0x07, DISSET5, 0xB4, 0xF0, PWCTR1, 0xA2, 0x02, 0x84, PWCTR2, 0xC5, PWCTR3, 0x0A, 0x00, PWCTR4, 0x8A, 0x2A, PWCTR5, 0x8A, 0xEE, VMCTR1, 0x06, MADCTL, 0xC8, GAMCTRP1, 0x12, 0x1C, 0x10, 0x18, 0x33, 0x2C, 0x25, 0x28, 0x03, 0x10, GAMCTRN1, 0x12, 0x1C, 0x10, 0x18, 0x2D, 0x28, 0x23, 0x28, 0x03, 0x10, F0new, 0X01, F6new, 0X00, COLMOD, 0X05, CASET, 0x00, 0x02, 0x00, 0x81, RASET, 0x00, 0x03, 0x00, 0x82, DISPON, delay 10ms, RAMWR 4D Systems DATASHEET Normal Mode/ Full Colours) Idle Mode/ 8-Colors) Control (Partial Mode/ Full Colours) 0x28, 0x27, 0x2F, 0x3C, 0x00, 0x03, 0x28, 0x26, 0x2F, 0x3B, 0x00, 0x03, Page 14 of 24 4DLCD-144 Reading Driver IC 8.5. Reading Driver IC The following application (written in 4DGL for 4D Systems Processors) can be used to identify which driver IC is used. This program can be ported to another language if not using a 4D Processor. Essentially it reads 3 bytes from the display at a specified address, and those 3 bytes dictate which driver IC is being used. #platform "GOLDELOX" #inherit "4DGL_16bitColours.fnc" #constant RDDID 0x04 func main() var ID1, ID2, ID3, msg ; disp_WriteControl(RDDID); disp_ReadByte(); // dummy read ID1 := disp_ReadByte(); ID2 := disp_ReadByte(); ID3 := disp_ReadByte(); gfx_MoveTo(0,0); gfx_Rectangle(0, 0, peekB(SYS_X_MAX), peekB(SYS_Y_MAX), BLUE) ; // decide which device if (ID1 == 0x5C && ID2 == 0x88 msg := "ST7735" ; else if (ID1 == 0x5C && ID2 == msg := "ST7735R" ; else if (ID1 == 0x7C && ID2 == msg := "ST7735S" ; else if (ID1 == 0x54 && ID2 == msg := "ILI9163C" ; else msg := 0 ; endif && ID3 == 0x35) // "ST7735" 0x89 && ID3 == 0xF0) // "ST7735R" 0x89 && ID3 == 0xF0) // "ST7735S" 0x80 && ID3 == 0x66) // "ILI9163C" gfx_MoveTo(10, 10); if (msg == 0) print("Unknown Driver IC,\nID bytes:-\n"); print([HEX2]ID1, " " , [HEX2]ID2, " " , [HEX2]ID3); to (COM0); print("Unknown Driver IC, ID bytes:- "); to (COM0); print([HEX2]ID1, " " , [HEX2]ID2, " " , [HEX2]ID3, "\n") ; else print("Driver IC is\n", [STR] msg) ; to (COM0); print("Driver IC is ", [STR] msg, "\n") ; endif repeat forever endfunc 4D Systems DATASHEET Page 15 of 24 4DLCD-144 LCD Timing Details 9. LCD Timing Details 9.1. Timing Chart SIGNAL DCX CSX WRX 4D Systems SYMBOL PARAMETER MIN MAX UNIT DESCRIPTION tast Address setup time 10 - ns - taht Address hold time (Write/Read) 10 - ns - tchw CSX “H” pulse width 0 - ns - tcs Chip Select setup time 15 - ns - trcs Chip Select setup time (Read ID) 45 - ns - trcsfm Chip Select setup time (Read FM) 350 - ns - tcsf Chip Select Wait time (Write/Read) 10 - ns - tcsh Chip Select Hold time 10 - ns - twc Write cycle 100 - ns - twrh Write Control Pulse H duration 30 - ns - twrl Write Control Pulse L duration 30 - ns - DATASHEET Page 16 of 24 4DLCD-144 Timing Chart SIGNAL SYMBOL RDX(FM) trcfm RDX(ID) D[7:0] PARAMETER MIN MAX UNIT Read cycle (FM) 450 - ns trdhfm Read Control Pulse H duration (FM) 90 - ns trdlfm Read Control Pulse L duration (FM) 355 - ns Read cycle (ID) 160 - ns trdh Read Control Pulse H duration 90 - ns trdl Read Control Pulse L duration 45 - ns tdst Write data setup time 10 - ns tdht Write data hold time 10 - ns trat Read access time - 40 ns Tratfm Read access time - 340 ns 20 80 ns trc trod Read output disable time DESCRIPTION When read ID Data When read from frame memory Note Timing parameter (VDD=3.3V, GND=0V, Ta=25˚C) 4D Systems DATASHEET Page 17 of 24 4DLCD-144 Reset Timing 9.2. Reset Timing SIGNAL SYMBOL PARAMETER MIN MAX UNIT RESET (RESX) T RESW Reset pulse duration 10 - us T REST Reset cancel - 5 ms - 120 ms Note • The reset cancel includes the time required for loading ID bytes, VCOM setting and other settings from the EEPROM (or similar device) to register. This loading is done every time when there is HW reset cancel time (trest) within 5 ms after a siring edge of RESX. • Spike due to an electrostatic discharge on RESX line does not cause irregular system reset according to the table below 4D Systems RESX Pulse Action Shorter than 5us Reset rejected Longer than 9us Reset Between 5us and 9us Reset starts DATASHEET Page 18 of 24 4DLCD-144 Power On Sequence 9.3. Power On Sequence 9.3.1. Case 1 - RES line is held High or Unstable by Host at Power ON 9.3.2. Case 2 - RES line is held Low by Host at Power ON 9.4. Power-off Sequence - Uncontrolled Power Off Uncontrolled power off is a situation where power is removed unexpectedly, e.g. a battery powering a device is disconnected without using the controlled power off sequence. There will not be any da mage to the display module, nor will the display module cause any damage to the host. During an uncontrolled power off event, ST7735S causes the display to blank its content and there will not be any further abnormal visible effects on the display after 1 second of the power being removed. The display will remain blank until the Power On Sequence occurs. 4D Systems DATASHEET Page 19 of 24 4DLCD-144 Reliability Test 10. Reliability Test Reliability Test No. SYMBOL TEST CONDITION 1 High Temperature Storage 80˚C±2˚C 96H Restore 2H at 25˚C Power off 2 Low Temperature Storage -30˚C±2˚C 96H Restore 2H at 25˚C Power off 3 High Temperature Operation 70˚C±2˚C 96H Power on 4 Low Temperature Operation -20˚C±2˚C 96H Power on 5 High Temperature & Humidity Operation 60˚C±2˚C 90%RH 96H Power on REMARK After test cosmetic and electrical defects should not happen. -20˚C25˚C70˚C 30min 5min 30min 6 Temperature Cycle 7 Vibration Test 10Hz~150Hz, 100m/s 2, 120min 8 Shock Test Half-sinewave, 300m/s 2, 11ms After 10 cycles, restore 2H at 25˚C Power off Note The Displays are of the highest rated ‘Grade A’, which allows for 0-4 defective pixels. A defective pixel could be solid Black (Dead), White, Red, Green or Blue. 4D Systems DATASHEET Page 20 of 24 4DLCD-144 Precautions for Using LCD Modules 11. Precautions for Using LCD Modules 11.1. Handing Precautions • The display panel is made of glass and a polarizer. The glass is fragile. It tends to be chipped during handling, especially on the edges. Please avoid dropping or jarring. Please be careful not subject it to a mechanical shock by dropping it on impact. • If the display panel is damaged and the liquid crystal substance leaks out, be sure not to get any of it in your mouth. If the substance contacts your skin or clothes, wash it off using soap and water. • Do not apply excessive force to the display surface or the adjoining areas since this may cause the color tone to vary. Do not touch the display with bare hands. This will stain the display area and degrade insulation between terminals (some cosmetics are determined by the polarizer). • The polarizer covering the display surface of the LCD module is soft and easily scratched. Handle this polarizer carefully. Do not touch, push or rub the exposed polarizer with anything harder than an HB pencil lead (e.g., glass, tweezers, etc.). Do not put or attach anything to the display area to avoid leaving marks on it. Condensation on the surface and contact with terminals due to cold temperatures will damage, stain or contaminate the polarizer. After products are tested at low temperatures they must be warmed up in a container before coming into contact with room-temperature air. • If the display surface becomes contaminated, breathe on the surface and gently wipe it with a soft dry cloth. If it is heavily contaminated, moisten the cloth with one of the following solvents • Isopropyl alcohol • Ethyl alcohol Do not scrub hard as it might damage the display surface. • Solvents other than those mentioned above may damage the polarizer. Especially the following. • Water • Ketone • Aromatic solvents Wipe off saliva or water drops immediately, contact with water over a long period may cause deformation or color fading. Avoid contact with oil and fat. • Take necessary precautions to minimize corrosion of the electrode. Corrosion of the electrodes is accelerated by water droplets, moisture condensation or current flow in a high-humidity environment. • Install the LCD Module by using the mounting holes. When mounting the LCD module, make sure it is free of twisting, warping and distortion. In particular, do not forcibly pull or bend the I/O cable or the backlight cable. • Do not attempt to disassemble or process the LCD module. • NC terminal should be open. Do not connect anything to it. • If the logic circuit power is off, do not apply input signals. 4D Systems DATASHEET Page 21 of 24 4DLCD-144 Handing Precautions • Control Electro-Static Discharge. Since this module uses a CMOS LSI, the same careful attention should be paid to electrostatic discharge as for an ordinary CMOS IC. To prevent the destruction of the elements by static electricity, ensure that an optimum work environment is maintained. • Before removing the LCM from its packing case or incorporating it into a set, be sure that the module and your body have the same electric potential. Be sure to ground your body when handling the LCD modules. • To reduce the amount of static electricity generated, do not conduct assembly and other work under dry conditions. To reduce the generation of static electricity, please ensure that the air in the work environment is not too dry. Relative humidity of 50%-60% is recommended. As much as possible, make the electric potential of your work clothes and that of the workbench the ground potential. • The LCD module is coated with a film to protect the display surface. Be careful when peeling off this protective film since static electricity may be generated. • Since the LCM has been assembled and adjusted with a high degree of precision, avoid applying excessive shocks to the module or making any alterations or modifications to it. • Do not alter, modify or change the shape of the tab on the metal frame. • Do not make extra holes on the printed circuit board, modify its shape or change the positions of the components to be attached. • Do not damage or modify the pattern writing on the printed circuit board. • Do not modify the zebra rubber strip (conductive rubber) or heat seal connector. • Do not drop, bend or twist the LCM. 4D Systems DATASHEET Page 22 of 24 4DLCD-144 Storage Precautions 11.2. Storage Precautions When storing the LCD modules, the following precautions are necessary. • Store them in a sealed polyethylene bag. If properly sealed, there is no need for the desiccant. • Store them in a dark place. Do not expose to sunlight or fluorescent light, keep the temperature between 0℃ and 35℃, and keep the relative humidity between 40%RH and 60%RH. • The polarizer surface should not come in contact with any other objects. (We advise you to store them in an anti-static electricity container in which they were shipped. Some Liquid crystals solidify under low temperatures (below the storage temperature range) leading to defective orientation or the generation of air bubbles (black or white). Air bubbles may also be generated if the module is subjected to low temperatures. • If the LCD modules have been operating for a long time showing the same display patterns, the display patterns may remain on the screen as ghost images and a slight contrast irregularity may also appear. A normal operating status can be regained by suspending use for some time. It should be noted that this phenomenon does not adversely affect performance reliability. • To minimize the performance degradation of the LCD modules resulting from the destruction caused by static electricity etc., please avoid holding the following sections when handling the modules’ • The exposed area of the printed circuit board • Terminal electrode sections 4D Systems DATASHEET Page 23 of 24 4DLCD-144 Revision History 12. Revision History Document Revision 4D Systems REVISION DATE COMMENT 1.0 29/01/2010 Initial Version 1.1 20/05/2012 Driver IC Change 1.2 14/01/2021 Facelift of Datasheet, updated information 1.3 20/01/2023 Modified datasheet for web-based documentation DATASHEET Page 24 of 24
4DLCD-144 价格&库存
很抱歉,暂时无法提供与“4DLCD-144”相匹配的价格&库存,您可以联系我们找货
