share awesome hardware
0.95inch RGB OLED User Manual
0.95inch RGB OLED
User Manual
1.
2.
Key Parameters
Driver Chip
SSD1331
Interface
SPI
Resolution
96x64
Display Size
0.95inch
Dimension
31.7mm*37mm
Colors
RGB, 65K colorful
Visible Angle
>160°
Operating Temp. (℃)
-20~70
Storage Temp. (℃)
-30~80
Operation Description
We will illustrate the usage of the module with an example by connecting Waveshare Open103R
development board (STM32F103R MCU on board).
2.1. Hardware connections
Connect module to the SPI2 interface of Open103R development board, power up. OLED displays
information shows as below.
Figure 1: OLED information display
1
nd
Rev 2.4.2, October 22 2015
2.2. Software configuration
Open the project file .\IDE\ OLED.uvproj in Keil. After compiling successfully, download the project to
Open103R development board.
3.
Pin descriptions
Table 1: Pin descriptions
Pin No.
Symbol
Descriptions
1
VCC
Positive power supply (3.3~5V input voltage)
2
GND
Ground
3
NC
NC
4
DIN
Data
5
CLK
Clock
6
CS
Chip
7
D/C
This is Data/Command control pin. When it is pulled HIGH (i.e. connect to VDD),
the data at D[7:0] is treated as data. When it is pulled LOW, the data at D[7:0] will
be transferred to the command register.
8
RES
Reset signal input pin (active LOW)
SSD1331 RGB OLED SPI interface.
The serial interface consists of serial clock CLK, serial data DIN, DC and CS. DIN is shifted into an 8-bit
shift register on every rising edge of CLK in the order of Bit7, Bit6… Bit0. DC is sampled on every
eighth clock and the data byte in the shift register is written to the Display Data RAM or command
register in the same clock.
Under serial mode, only write operations are allowed.
Table 2: Control pins of Serial interface
Function
CS
DC
Write command
L
L
Write data
L
H
2
nd
Figure 2: Write procedure in SPI mode
Please refer to SSD1331-Revision 1.2.pdf for more detail about SSD1331.
3
nd
很抱歉,暂时无法提供与“28087”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+371.020441+48.09132
