GEN4-ULCD-28DT
GEN4-ULCD-28DT
    4DSYSTEMS
    GEN4-ULCD-28DT
GEN4-ULCD-28DT 数据手册
gen4-uLCD-28D Series gen4-uLCD-28D (Non-touch) gen4-uLCD-28D-CLB (Non-touch w/CLB) gen4-uLCD-28DT (Resistive touch) Datasheet Revision 1.10 Copyright © 2023 4D Systems Content may change at any time. Please refer to the resource centre for latest documentation. Contents 1. Description 4 2. Features 5 3. Hardware Overview 6 4. Hardware Interface - Pins 8 4.1. Serial Ports - TTL Level Serial 8 4.2. General Purpose I/O 11 4.3. System Pins 13 4.4. Alternate Pin Function Overview 14 4.5. SPI 17 4.6. I2C 18 4.7. Pulse Out 19 4.8. PWM Out 20 4.9. Pin Counter 21 4.10. Quadrature In 22 4.11. Analog Inputs 23 5. Module Features 24 5.1. DIABLO16 Processor 24 5.2. Audio 24 5.3. SD/SDHC Memory Cards 25 5.4. FAT16 26 5.5. Application PCB Support 26 5.6. RF / EMI Shielding Support 27 6. Display/Module Precautions 28 7. Hardware Tools 29 7.1. 4D-UPA Programming Cable/Adaptor 29 8. Programming Language 31 9. Workshop4 IDE 32 9.1. PmmC Programming 4D Systems 33 DATASHEET Page 2 of 44 10. Display Module Part Numbers 35 11. Cover Lens Bezel - Tape Spec 35 12. FFC Cable 36 13. Starter Kit 37 14. Mechanical Details (Resistive Touch & Non-Touch without Cover Lens Bezel) 38 15. Mechanical Details (Non-Touch & with Cover Lens Bezel) 39 16. Schematic Details 40 17. Specifications 41 18. Revision History 4D Systems 44 DATASHEET Page 3 of 44 gen4-uLCD-28D Series Description 1. Description The gen4 2.8" Diablo16 Integrated Display Module is part of the latest gen4 series of modules Designed and Manufactured by 4D Systems. The gen4 series was designed specifically for ease of integration and use, with careful consideration for space requirements and functionality. This specific gen4 module features a 2.8" colour TFT LCD, with optional resistive touch. It is powered by the feature-rich 4D Systems Diablo16 Graphics Processor, which offers an array of functionality and options for any Designer / Integrator / User. The Diablo16 processor features include 16 customisable GPIO, capable of PWM, Serial, I2C, SPI, Pulse Out, Quadrature Input, and Analog Input. The 2.8" Diablo16 Integrated Display Module features a TFT LCD Display and is capable of Touch Detection, microSD memory Storage, GPIO and Communications, along with multiple millisecond resolution timers, and Audio Generation. The gen4 series is 100% compatible with the Workshop4 IDE and its 4 different development environments, providing the User with a wealth of options for programming and controlling their system. Anything designed to run on other 4D Systems displays modules featuring Picaso or Diablo16 Graphic Processors can be run on this gen4 Integrated Display Module, with little or no required modifications. Please contact 4D Systems Support Team for assistance if migrating from a previous model. The gen4 series of Integrated Display Modules features a 30-pin ZIF socket, designed for a 30-pin FPC cable, for easy and simple connection to an application or mother board, or for connecting to accessory boards for a range of functionality advancements. The gen4 series of modules has been designed to minimise the impact of display-related circuitry and provide a platform suitable for integration into a product. Application boards can sit flush on the back of the gen4 if required, as the display-related electronics sit inside the plastic mounting base, leaving the application board surface clear for User circuitry. 4D Systems DATASHEET Page 4 of 44 gen4-uLCD-28D Series Features 2. Features • Powerful 2.8" Intelligent LCD-TFT display module powered by DIABLO16. • 240 x 320 Resolution, RGB 65K true-to-life colours, TFT Screen with non-touch, or integrated 4wire Resistive Touch Panel (on RTP model only). • 6 banks of 32750 bytes of Flash memory for User Application Code and Data. • 32Kb of SRAM purely for the User. • 16 General Purpose I/O pins for user interfacing, which include 4 configurable Analog Inputs. • The GPIO is variously configurable for alternative functions such as: • 3x I2C channels available. • 1x SPI dedicated for SD Card and 3x configurable SPI channels > available. • 1x dedicated and 3x configurable TTL Serial comm ports > available. • Up to 6 GPIO can be used as Pin Counters. • Up to 6 GPIO for PWM (simple and Servo). • Up to 10 GPIO for Pulse Output. • Up to 14, GPIO can be configured for Quadrature Encoder Inputs (2 > channels). • 30pin FPC connection, for all signals, power, communications, GPIO and programming. • On-board latch-type micro-SD memory card connector for multimedia storage and data logging purposes. • DOS-compatible file access (FAT16 format) as well as low-level access to card memory. • A dedicated PWM Audio pin is driven by WAV files from micro-SD cards, and for sound generation, for an external amplifier. • Display full colour images, animations, icons and video clips. • Supports all available Windows fonts. • 4.0V to 5.5V range operation (single supply). • 4x mounting tabs with 3.2mm holes for mechanical mounting using M3 screws. • RoHS, REACH and CE compliant. • Module dimensions: • Weighing: • (D): 87.3 x 52.1 x 6.2mm • (D): ~ 30g • (D-CLB): 87.6 x 67.2 x 7.3mm • (D-CLB): ~ 40g • (DT): 87.3 x 52.1 x 7.3mm • (DT): ~ 36g 4D Systems DATASHEET Page 5 of 44 gen4-uLCD-28D Series Hardware Overview 3. Hardware Overview FPC Pinout Pin Symbol I/O 1 GND P 2 PA3 I/O/A General Purpose I/O pin with Analog Capability. This pin has a range of 0-3.3V when used as an Analog Input, and is 3.3V tolerant only. Also used for Bus Read. 3 PA2 I/O/A General Purpose I/O pin with Analog Capability. This pin has a range of 0-3.3V when used as an Analog Input, and is 3.3V tolerant only. Also used for Bus Write. 4 PA1 I/O/A General Purpose I/O pin with Analog Capability. This pin has a range of 0-3.3V when used as an Analog Input, and is 3.3V tolerant only. 5 PA0 I/O/A General Purpose I/O pin with Analog Capability. This pin has a range of 0-3.3V when used as an Analog Input, and is 3.3V tolerant only. 6 PA9 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 7 PA8 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 8 PA7 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 9 PA6 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 10 PA5 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 11 PA4 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 12 PA10 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 13 PA11 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant 14 PA12 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant. 15 PA13 I/O General Purpose Input/Output, 3.3V Level - 5V Tolerant. 16 PA14 I/O General Purpose Input/Output, 3.3V Tolerant only. Special I2C Pin. 17 PA15 I/O General Purpose Input/Output, 3.3V Tolerant only. Special I2C Pin. 18 NC - Not Connected 19 AUDIO_OUT O Audio Output, PWM, to feed into external amplifier via filter network 20 AUDENB O Audio Amplifier Enable, to enable/disable external amplifier 4D Systems Description Supply Ground DATASHEET Page 6 of 44 gen4-uLCD-28D Series Hardware Overview Pin Symbol I/O Description 21 GND P Supply Ground 22 RESET I Master Reset signal. Internally pulled up to 3.3V via a 10K resistor. An active Low pulse greater than 2 micro-seconds will reset the module. If the module needs to be reset externally, only use open collector-type circuits. This pin is not driven low by any internal conditions. The host should control this pin via one of its port pins using an open collector/drain arrangement. 23 RX0 I Asynchronous Serial Receive pin, TTL level. Connect this pin to the Transmit (Tx) signal of other serial devices. Used in conjunction with the TX pin for programming this module. This pin is tolerant up to 5.0V levels. 24 TX0 O Asynchronous Serial Transmit pin, TTL level. Connect this pin to the Receive (Rx) signal of other serial devices. Used in conjunction with the RX pin for programming this module. This pin is tolerant up to 3.3V level output. 25 GND P Supply Ground 26 5V IN P Main Voltage Supply +ve input pin. Reverse polarity protected. The range is 4.0V to 5.5V, nominal 5.0V. 27 5V IN P Main Voltage Supply +ve input pin. Reverse polarity protected. The range is 4.0V to 5.5V, nominal 5.0V. 28 NC - Not Connected 29 NC - Not Connected 30 GND P Supply Ground Note I = Input, O = Output, P = Power 4D Systems DATASHEET Page 7 of 44 gen4-uLCD-28D Series Hardware Interface - Pins 4. Hardware Interface - Pins This section describes in detail the hardware interface pins of the device. 4.1. Serial Ports - TTL Level Serial The DIABLO16 Processor has three hardware asynchronous serial ports (COM1 - COM3) that can be configured on a variety of processor GPIO pins. TX/RX0 (COM0) is dedicated and its pins are fixed. All of the DIABLO16's serial ports can be used to communicate with external serial devices. TX/RX0 are referred to as COM0 and is the only one used for programming the DIABLO16 itself. The primary features are: • Full-Duplex 8-bit data transmission and reception. • Data format: 8 bits, No Parity, 1 Stop bit. • Independent Baud rates from 300 baud up to 600K baud. • Single byte transmits and receives a fully buffered service. The buffered service feature runs in the background capturing and buffering serial data without the user application having to constantly poll any of the serial ports. This frees up the application to service other tasks. A single-byte serial transmission consists of the start bit, 8 bits of data followed by the stop bit. The start bit is always 0, while a stop bit is always 1. The LSB (Least Significant Bit, Bit 0) is sent out first following the start bit. The figure below shows a single-byte transmission timing diagram. 4D Systems DATASHEET Page 8 of 44 gen4-uLCD-28D Series Serial Ports - TTL Level Serial COM0 is also the primary interface for User program downloads and configuration PmmC /Driver programming. Once the compiled 4DGL application program (EVE byte-code) is downloaded and the user code starts executing, the serial port is then available to the user application. TX0 pin (Serial Transmit COM0): Dedicated Asynchronous Serial port COM0 transmit pin, TX0. Connect this pin to the external serial device receive (Rx) signal. This pin is 5.0V tolerant. RX0 pin (Serial Receive COM0): Dedicated Asynchronous Serial port COM0 receive pin, RX0. Connect this pin to an external serial device transmit (Tx) signal. This pin is 5.0V tolerant. TX1 pin (Serial Transmit COM1): Asynchronous Serial port COM1 transmit pin, TX1. Connect this pin to the external serial device receive (Rx) signal. This can be configured to one of the GPIO pins, see the table below. RX1 pin (Serial Receive COM1): Asynchronous Serial port COM1 receive pin, RX1. Connect this pin to an external serial device transmit (Tx) signal. This can be configured to one of the GPIO pins, see the table below. TX2 pin (Serial Transmit COM2): Asynchronous Serial port COM2 transmit pin, TX2. Connect this pin to the external serial device receive (Rx) signal. This can be configured to one of the GPIO pins, see the table below. RX2 pin (Serial Receive COM2): Asynchronous Serial port COM2 receive pin, RX2. Connect this pin to an external serial device transmit (Tx) signal. This can be configured to one of the GPIO pins, see the table below. TX3 pin (Serial Transmit COM3): Asynchronous Serial port COM3 transmit pin, TX3. Connect this pin to the external serial device receive (Rx) signal. This can be configured to one of the GPIO pins, see the table below. 4D Systems DATASHEET Page 9 of 44 gen4-uLCD-28D Series Serial Ports - TTL Level Serial RX3 pin (Serial Receive COM3): Asynchronous Serial port COM3 receive pin, RX3. Connect this pin to an external serial device transmit (Tx) signal. This can be configured to one of the GPIO pins, see the table below. DIABLO16 Serial TTL Comm Port Configuration Options TX1 PA0 PA1 RX1 TX2 Yes Yes PA2 Yes RX2 TX3 Yes Yes Yes Yes RX3 Yes Yes Yes Yes Yes PA3 Yes Yes Yes Yes Yes Yes PA4 Yes Yes Yes Yes Yes Yes PA5 Yes Yes Yes Yes Yes Yes PA6 Yes Yes Yes Yes Yes Yes PA7 Yes Yes Yes Yes Yes Yes PA8 Yes Yes Yes Yes Yes Yes PA9 Yes Yes Yes Yes Yes Yes PA10 Yes Yes Yes PA11 Yes Yes Yes PA12 Yes Yes Yes Yes Yes Yes PA13 Yes Yes Yes Yes Yes Yes PA14 PA15 As per the table, not all GPIO can be configured to be every serial port, or RX/TX. Note Pins PA4-PA13 are 5.0V tolerant, while pins PA0-PA3, PA14, PA15 are 3.3V tolerant only. All pins output at 3.3V levels. Please refer to the Diablo16 Internal Functions Manual for information on how to set the DIABLO16 pin mappings. 4D Systems DATASHEET Page 10 of 44 gen4-uLCD-28D Series General Purpose I/O 4.2. General Purpose I/O There are 16 general-purpose Input/Output (GPIO) pins available to the user. These provide flexibility for individual bit operations along with serving collectively for byte-wise operations using the BUS functions DIABLO16 Alternate Pin Configurations GPIO Digital Input Digital Output Bus Read Bus Write Analog Read PA0 Yes Yes Yes Yes Yes PA1 Yes Yes Yes Yes Yes PA2 Yes Yes Yes Yes Yes PA3 Yes Yes Yes Yes Yes PA4 Yes Yes Yes Yes PA5 Yes Yes Yes Yes PA6 Yes Yes Yes Yes PA7 Yes Yes Yes Yes PA8 Yes Yes Yes Yes PA9 Yes Yes Yes Yes PA10 Yes Yes Yes Yes PA11 Yes Yes Yes Yes PA12 Yes Yes Yes Yes PA13 Yes Yes Yes Yes PA14 Yes Yes Yes PA15 Yes Yes Yes Please refer to the Diablo16 Internal Functions Manual for information on how to set the DIABLO16 pin mappings. PA0-PA3: General purpose I/O pins, or can serve as Analog Input pins. Each pin can be individually set for INPUT or OUTPUT or ANALOG. Power-Up Reset default is all INPUTS. Digital GPIO can source/sink 10mA. For more information, the Specifications section. These pins have a 0 to 3.3V range and have a 12-bit resolution. For more information, refer to the Analog Inputs section. 4D Systems DATASHEET Page 11 of 44 gen4-uLCD-28D Series General Purpose I/O PA4-PA11: General purpose I/O pins. Each pin can be individually set for INPUT or OUTPUT. Power-Up Reset default is all INPUTS. When set as Digital Inputs, the pins are 5V tolerant. Digital GPIO can source/sink 10mA. For more information, see the Specifications Section. PA12-PA13: PA12 and PA13 are reserved and are used exclusively for the resistive touch controller, or the capacitive touch controller (DT/DCT models). These pins should not be connected else Touch performance may be degraded. There are 4.7K pullup resistors on each of the GPIO. Avoid these pins in normal situations. However, using these pins on non-touch (D model) is OK, or in situations where touch is not required. These pins are 5V tolerant PA14-PA15: General purpose I/O pins. Each pin can be individually set for INPUT or OUTPUT. Power-Up Reset default is all INPUTS. When set as Digital Inputs, the pins are 3.3V tolerant. Digital GPIO can source/sink 10mA. Under special situations, these pins can be used for a highspeed I2C interface. Please refer to the table under the Alternate Pin Function Overview section and the information under the I2C section. Note Digital GPIO pins are 5.0V tolerant, except PA14-PA15, which are 3.3V tolerant only. PA0-PA3 are 3.3V tolerant only. All pins output at 3.3V levels. 4D Systems DATASHEET Page 12 of 44 gen4-uLCD-28D Series System Pins 4.3. System Pins +5V IN (Module Voltage Input): Module supply voltage input pins. Both of these pins should be connected to a stable supply voltage in the range of 4.0 Volts to 5.5 Volts DC. The nominal operating voltage is 5.0 Volts. Note backlight brightness will be lower for voltages under 5.0V. GND (Module Ground): Device ground pins. At least two pins should be connected to the ground. RESET (Module Master Reset): Module Master Reset pin. An active low pulse of greater than 2μs will reset the module. Internally pulled up to 3.3V via a 10K resistor. Only use open collector-type circuits to reset the device if an external reset is required. AUDENB (Audio Enable Output): Output dedicated to enabling or disabling an external amplifier, where required. AUDIO (PWM Audio Output): Output specifically for Audio. This pin is a PWM output from the DIABLO16 Processor. This pin is a 3.3V level PWM output to drive an external amplifier with DIABLO16 generated Audio, via an external filtering circuit to turn digital PWM into Analog. Note that AUDENB must be enabled in DIABLO16 for any input signal to be heard. 4D Systems DATASHEET Page 13 of 44 gen4-uLCD-28D Series Alternate Pin Function Overview 4.4. Alternate Pin Function Overview Most of the GPIO pins have an alternate function other than being for General Purpose I/O. GPIO pins can be configured to be SPI, I 2C, Serial or a range of other functions. Note Not all pins can be configured to be any of the alternate pin functions. Please refer to the tables. Refer to the tables below that illustrate the GPIO pins you can associate with alternative functions. DIABLO16 Alternate Pin Configurations I/O Support Functions Pulse Out PWM Out Pin Counter Quadrature In PA0 Yes Yes PA1 Yes Yes PA2 Yes Yes PA3 Yes Yes PA4 Yes Yes Yes Yes PA5 Yes Yes Yes Yes PA6 Yes Yes Yes Yes PA7 Yes Yes Yes Yes PA8 Yes Yes Yes Yes PA9 Yes Yes Yes Yes PA10 Yes PA11 Yes PA12 Yes PA13 Yes PA14 PA15 Note • Once you allocate a pin to an alternate function, you can't allocate another pin to the same alternate function. • Quadrature In requires 2 Pins 4D Systems DATASHEET Page 14 of 44 gen4-uLCD-28D Series Alternate Pin Function Overview The table above illustrates the GPIO pins you can use for the 4 different I/O Support Functions. Please refer to the Diablo16 Internal Functions Manual for more information on how to set the alternate pin configurations. The Alternate pin functions have been broken up into a few tables for simplification. There are communication-based functions and I/O support-based functions. Further information is available in the next sections for each of the alternative pin functions. The table below illustrates the GPIO pins you can use for the three different SPI channels available. DIABLO16 Alternate Pin Configurations SPI Communications SPI1 SDO PA0 PA1 SPI1 SDI SPI1 SCK SPI2 SDO Yes Yes PA2 Yes SPI2 SDI SPI2 SCK SPI3 SDO Yes Yes Yes Yes Yes Yes Yes Yes Yes PA4 Yes Yes Yes PA5 Yes Yes PA6 Yes PA7 Yes SPI3 SCK Yes Yes Yes Yes PA3 SPI3 SDI Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes PA8 Yes Yes Yes Yes Yes Yes Yes Yes PA9 Yes Yes Yes Yes Yes Yes Yes Yes PA10 Yes Yes Yes PA11 Yes Yes Yes PA12 Yes Yes Yes Yes Yes Yes Yes Yes PA13 Yes Yes Yes Yes Yes Yes Yes Yes PA14 PA15 4D Systems DATASHEET Page 15 of 44 gen4-uLCD-28D Series Alternate Pin Function Overview The table below illustrates the GPIO pins you can use for the three different I 2C channels available. DIABLO16 Alternate Pin Configurations I2C Communication I 2C1 SDA I 2C1 SCL I 2C2 SDA I 2C2 SCL I 2C3 SDA I 2C3 SCL PA0 Yes Yes Yes Yes Yes Yes PA1 Yes Yes Yes Yes Yes Yes PA2 Yes Yes Yes Yes Yes Yes PA3 Yes Yes Yes Yes Yes Yes PA4 Yes Yes Yes Yes Yes Yes PA5 Yes Yes Yes Yes Yes Yes PA6 Yes Yes Yes Yes Yes Yes PA7 Yes Yes Yes Yes Yes Yes PA8 Yes Yes Yes Yes Yes Yes PA9 Yes Yes Yes Yes Yes Yes PA10 Yes Yes Yes Yes Yes Yes PA11 Yes Yes Yes Yes Yes Yes PA12 Yes Yes Yes Yes Yes Yes PA13 Yes Yes Yes Yes Yes Yes PA14 PA15 SPECIAL SPECIAL SPECIAL SPECIAL SPECIAL SPECIAL Note SPECIAL - please see I2C section. 4D Systems DATASHEET Page 16 of 44 gen4-uLCD-28D Series SPI 4.5. SPI There are 3 user-configurable SPI channels available for mapping to GPIO, for use by the user for the target application. All 3 SPI channels are Master only, and cannot be configured to be slaves at this time. The SPI Bus speed is configurable using the SPIx_Init() Function in 4DGL and allows various speeds from 78.125Khz to 17.5Mhz. Please refer to the table for details on which GPIO can be configured for SPI. Note The additional SPI channel (SPI0) is dedicated to the memory cards and cannot be reconfigured for alternate uses. To map an SPI channel to a set of GPIO pins, the following 4DGL functions are used: • SPIx_SCK_pin(pin); // Map the SCK pin • SPIx_SDI_pin(pin); // Map the SDI pin • SPIx_SDO_pin(pin); // Map the SDO pin where: 'SPIx' is substituted with SPI1, SPI2 or SPI3 accordingly, and 'pin' is the target GPIO pin compatible with that particular pin function. Chip Select for use with SPI can be any other unused GPIO pin, configured as a Digital Output. The lowering and raising of the selected CS (GPIO) pin is done manually by the user in the 4DGL application. Please refer to the Diablo16 Internal Functions Manual for more information on how to use the SPI functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 17 of 44 gen4-uLCD-28D Series I2C 4.6. I2C There are 3 user-configurable I2C channels available for mapping to GPIO, for use by the user for the target application. All 3 I 2C channels are Master only, and cannot be configured to be slaves at this time. Please refer to the table for details on which GPIO can be configured for I 2C. To map an I 2C Channel to a set of GPIO pins, the following 4DGL function is used: • I2Cx_Open(Speed, SCLpin, SDApin); where: 'I2Cx' is substituted with I2C1, I2C2 or I2C3 accordingly, 'Speed' is the desired I2C Bus speed, and 'SCLpin' and 'SDApin' are the target GPIO pins compatible with that particular pin function. Note The normal I 2C pins are PA0 to PA13, however, the use of these pins has a few limitations. 1. There is no slew rate control at I2C_MED. 2. I2C_FAST is not truly 1MHz. If either of these restrictions needs to be addressed, a special case of SCLpin = PA14 and SDApin = PA15 exists ONLY for speeds I2C_MED (which uses slew rate control) and I2C_FAST (which is truly 1MHz) Please refer to the Diablo16 Internal Functions Manual for more information on how to use the I 2C functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 18 of 44 gen4-uLCD-28D Series Pulse Out 4.7. Pulse Out Pulse Out is used to create a single pulse of set duration on the selected pin of choice, which is inverted in polarity to the current state of the pin. This 'inversion of polarity' means if a Pin is currently held HI, and Pulse Out is executed on that Pin, the pin will pulse LO and then return to HI. Same with vice versa, if currently LO and Pulse Out are executed on that Pin, it will pulse HI and then return to LO. This is available in both blocking and non-blocking versions. Please refer to the table for details on which GPIO can be configured to Pulse Out. Note Each Pulse Out request needs at least a 1ms lead time due to the scheduling of the event with the internal 1ms timer. To enable the Pulse Out function on a GPIO pin, the following 4DGL functions are used: • pin_Pulseout(pin, value); //Non-Blocking • pin_PulseoutB(pin, value); //Blocking where: 'pin' is the target GPIO pin compatible with that particular pin function, and 'value' is the length of the pulse in milliseconds. Please refer to the Diablo16 Internal Functions Manual for more information on how to use the Pulse Out functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 19 of 44 gen4-uLCD-28D Series PWM Out 4.8. PWM Out There are 6 PWM channels available to be configured by the user, with 4-time bases available for selection. The PWM can be configured to be used in Servo Mode, or Simple Mode. Please refer to the table for details on which GPIO can be configured to PWM. Servo Mode allows a millisecond input value with 0.01ms resolution, which runs at a frequency of approximately 50Hz or 50pps (20ms). The position of the servo is determined by the width of the pulse. Generally, 1.5ms is 90 degrees, 1ms is 0 degrees and 2ms is 180 degrees. Servos however vary, and the DIABLO16 PWM control can be adjusted to suit most applications. Simple Mode allows a percentage input value with a resolution of 0.1%, which runs at a frequency of approximately 70KHz. To enable the PWM output on a GPIO pin, the following 4DGL function is used: • PWM_Init(pin, mode, value); where: 'pin' is the GPIO compatible with the particular pin function, 'mode' is the type of PWM to generate, and 'value' is the parameter that defined the PWM pulse itself. Please refer to the Diablo16 Internal Functions Manual for more information on how to use the PWM functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 20 of 44 gen4-uLCD-28D Series Pin Counter 4.9. Pin Counter There are 6 Pin Counter channels available to be configured by the user, used to count incoming pulses with the ability to call a user function on overflow. The Pin Counter function is available for use in a variety of modes. The counters can be read and written at any time. Please refer to the table for details on which GPIO can be configured to Pin Counter. To enable the Pin Counter function on a GPIO pin, the following 4DGL function is used: • pin_Counter(pin, mode, OVFfunction); where: 'pin' is the GPIO pin compatible with this particular function, 'mode' is the type of trigger used to count on such as Rising/Falling/Edge, and 'OVFfunction' is the user function to call when the counter overflows if desired. Please refer to the Diablo16 Internal Functions Manual for more information on how to use the Pin Counter functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 21 of 44 gen4-uLCD-28D Series Quadrature In 4.10. Quadrature In There are two Quadrature Input channels available on the DIABLO16 processor, which requires 2 GPIO pins each. Please refer to the table for details on which GPIO can be configured for Quadrature Input. Quadrature Input allows a quadrature encoder to be connected, and the position counter and delta counter can be read at any time. To enable the Quadrature Input function on a set of GPIO pins (2 pins required), the following 4DGL function is used: • Qencoderx(PHApin, PHBpin, mode); where: 'Qencoderx' is substituted for Quencoder1 or Quencoder2 accordingly, 'PHApin' is the pin connected to the A Phase of the Encoder, 'PHBpin' is the pin connected to the B Phase of the Encoder, and 'mode' is not currently used so is to be set to zero (0). Please refer to the Diablo16 Internal Functions Manual for more information on how to use the Quadrature Input functions, along with the DIABLO16-Processor datasheet. 4D Systems DATASHEET Page 22 of 44 gen4-uLCD-28D Series Analog Inputs 4.11. Analog Inputs Please refer to the table under the General Purpose I/O section for details about pins you can configure to analog inputs. The analog inputs on the DIABLO16 have a range of 0V to 3.3V, each with a max resolution of 12 bits. You can read the analog inputs using either the standard mode, averaged mode or high-speed mode. • Standard Mode results are immediately read in a sample. Standard Mode can read over 40000 values per second. Operates at 12-bit. • Averaged Mode results are immediately read in 16 samples and their average is returned. Averaged Mode can read ~20000 values per second. Operates at 12-bit. • Highspeed Mode collects a user-specified number of samples at a user-specified rate/frequency and can execute a user function when complete. The updated value updates ~250000 times across 1-4 channels. Operates at 10-bit. To enable a GPIO as an Analog Input for Standard or Averaged modes, you must use the following 4DGL function to set the pin: • pin_Set(mode, pin); where: 'mode' is the desired mode defined above, either Standard or Averaged, and 'pin' is the GPIO compatible with this function which is to become an Analog Input. For highspeed mode, you must the following 4DGL function to set the pin and define the parameters: • ana_HS(rate, samples, 1buf, 2buf, 3buf, 4buf, func); where: 'rate' is the number of samples per second, 'samples' is the number of samples to collect per channel, '1buf' to '4buf' are the buffer addresses for the 4 channels, and 'func' is the user function to call when the number of samples specified has been collected. Please refer to the Diablo16 Internal Functions Manual for more information on how to use the Analog Input functions, along with the DIABLO16-Processor datasheet. Note Analog Inputs are 0V-3.3V tolerant only. Do not apply voltages outside of this range as you will damage Diablo16. 4D Systems DATASHEET Page 23 of 44 gen4-uLCD-28D Series Module Features 5. Module Features The gen4 series of Integrated Display Modules are designed to accommodate most applications. Some of the main features of the module are listed below. 5.1. DIABLO16 Processor The module is designed around the DIABLO16 Graphics Controller from 4D-Labs. The DIABLO16 is a smart Controller and the interface to the TFT- LCDs is almost plug-n-play. All of the data and control signals are provided by the chip to interface directly with the display. Powerful graphics, text, images, animation and countless more features are built right inside the chip. You can refer to the DIABLO16 graphics processor datasheet for more information. 5.2. Audio Audio playback support in the DIABLO16 Processor enables this module to play audio WAV files stored in the micro-SD memory card. Filtered PWM audio is generated and made available on the AUDIO pin of the 30-way ZIF connector, ready to interface with an audio amplifier on your application board. A simple instruction enables the user to play/pause/stop audio files while continuing the execution of the user application code, such as display updates, touch recognition, communications, etc. The audio system also allows real-time pitch change of audio samples. For a complete list of audio commands please refer to the separate document titled: • DIABLO16 4DGL Internal Functions 4D Systems DATASHEET Page 24 of 44 gen4-uLCD-28D Series SD/SDHC Memory Cards 5.3. SD/SDHC Memory Cards The Diablo16 processor uses off-the-shelf standard SDHC/SD/microSD memory cards with up to 2GB capacity usable with FAT16 formatting. For any FAT file-related operations, before the memory card can be used it must first be formatted to FAT16. The formatting of the card can be done on any PC system with a card reader. Select the appropriate drive and choose the FAT16 (or just FAT in some systems) option when formatting. The card is now ready to be used in the Diablo16-based application. The Diablo16 processor also supports high-capacity HC memory cards (4GB and above). The available capacity of SD-HC cards varies according to the way the card is partitioned and the commands used to access it. The FAT partition is always first (if it exists) and can be up to the maximum size permitted by FAT16. Windows 7 will format FAT16 up to 4GB. Windows XP will format FAT16 up to 2GB and the Windows XP command prompt will format FAT16 up to 4GB. RMPET, a 4D Systems Tool found in the Workshop4 IDE, is capable of repartitioning and formatting microSD cards to be the appropriate type and format for 4D Systems processors. This tool should be used for all cards. Note 1. An SPI Compatible SDHC/SD/microSD card MUST be used. Diablo16 along with other 4D Systems Processors requires SPI mode to communicate with the SD card. If a non-SPI compatible SD card is used, then the processor will not be able to mount the card. 2. Read disturbance is a well-known issue with flash memory devices, such as microSD cards, where reading data from a flash cell can cause the nearby cells in the same memory block to change over time. This issue can be prevented by using industrial-grade microSD cards with read disturb protection. Industrialgrade microSD cards have firmware that actively monitors the read operation and refreshes areas of memory that have high traffic and even move data around to prevent read disturb error from occurring. Furthermore, manufacturers may choose to implement read disturb protection on a specific part of the flash memory only, such that the beginning part of the memory might not be protected. The RMPET utility in Workshop4 is designed to create the first partition at an offset from the start of the microSD card to account for this situation. It is therefore recommended to always partition and format an industrial microSD card using the RMPET utility before using it with 4D Systems processors. Many commercial grade cards designed for Cameras etc, do not handle read disturb well at all, and therefore it is always recommended to use an Industrial grade microSD card with 4D modules. 4D offers one that is tried and tested, on our website. 4D Systems DATASHEET Page 25 of 44 gen4-uLCD-28D Series FAT16 5.4. FAT16 All 4D Systems display modules featuring 4D Labs processors use off-the-shelf standard SDHC/SD/ micro-SD memory cards (SPI Compatible Only) with up to 4GB capacity usable with FAT16 formatting. For any FAT file-related operations, before the memory card can be used it must first be formatted correctly. Built into Workshop4 is a tool created by 4D, called RMPET (please refer to the Tools menu, in any Environment, inside the Workshop4 IDE). RMPET allows the User to easily partition and format microSD cards, to make their file system ready to be used with 4D Systems modules. The formatting of the card can be done on any PC system with a card reader. The DIABLO16 Processor also supports high-capacity HC memory cards (4GB and above). The available capacity of SD-HC cards varies according to the way the card is partitioned and the commands used to access it. Refer to the 4D Systems RMPET tool in the Workshop4 IDE. A Max of 4GB can be used by the FAT16 file system. The FAT partition is always first (if it exists). Any space larger than 4GB will be RAW, and can still be used by your 4D Systems module, using different functions. Please refer to the Application Notes. 5.5. Application PCB Support The gen4 2.8" Diablo16 Integrated Display Module is designed to accommodate a range of applications and therefore is suited for those wanting to make a customised module, without the need for piggy-back or daughter boards mounted on headers. On the back of the gen4 module, the display-related circuitry will be found, which is recessed into plastic. The level of the plastic on the back of the gen4 module is higher than the tallest component on the display circuit PCB, meaning an Application PCB can be mounted on the back of the gen4, without affecting the display-related circuitry. The image below (2.4" model depicted) shows a mock Application PCB on the back of the gen4 display (Blue area). It features a cut-out in the PCB so access to the micro-SD socket on the gen4’s display board is possible, however, this may or may not be required depending on the application and if the micro-SD socket is used or requiring access once the Application PCB is applied. 4D Systems DATASHEET Page 26 of 44 gen4-uLCD-28D Series RF / EMI Shielding Support The micro-SD socket is a latch type, so it is accessible from the top, rather than a push/push or push/ pull style which is accessible from the side. 5.6. RF / EMI Shielding Support As per what is written in the Application PCB Support section, there is an option for extended RF shielding and EMI protection on this module. On the back of the gen4's display PCB, are grounded plated 'X pads', which make contact with the metal housing of the display. Where the Application PCB is shown to sit under the [Application PCB Support section; can house a small metal shield of the same size. This shield is used instead of, or underneath an Application PCB, to aid the onboard electronics in the prevention of potential RF or EMI signals. On the top of the display, PCB is more GND pads, which can have a pogo pin or similar device mounted on them, which can make contact with this metal shield. The display electronics are then sandwiched between the display's metal housing, and the metal shield, all connected with a common ground. 4D Systems DATASHEET Page 27 of 44 gen4-uLCD-28D Series Display/Module Precautions Note There are no guarantees these steps will increase chances or grant access to EMI-related certifications. However, the gen4 can use shielding of the module's electronics, should the need arise. This may or may not assist the User with protecting the device against EMI/EMF/RF type noise, depending on the source, strength and type of noise present, but it should aid in the protection. The metal shield is not made or available from 4D Systems to buy, it is to illustrate a concept only. 6. Display/Module Precautions • Avoid having to display the same image/object on the screen for lengthy periods. This can cause a burn-in which is a common problem with all types of display technologies. Blank the screen after a while or dim it very low by adjusting the contrast. Better still; implement a screen saver feature. • Moisture and water can damage the display. Moisture on the surface of a powered display should not cause any problems, however, if water is to enter the display either from the front or from the rear, or come in contact with the PCB, it will damage. Wipe off any moisture gently or let the display dry before usage. If using this display module in an environment where it can get wet, ensure an appropriate enclosure is used. • Dirt from fingerprint oil and fat can easily stain the surface of the display. Gently wipe off any stains with a soft lint-free cloth. • The performance of the display will degrade under high temperatures and humidity. Avoid such conditions when storing. • Do not tamper with the display flex cable that is connected to the control board. This may affect the connection between the display and the driving circuitry and cause failure. • Displays are susceptible to mechanical shock and any force exerted on the module may result in deformed zebra stripes, a cracked display cell and a broken backlight • Always use the mounting holes on the module's corner plates to mount the display where possible. • Display modules have a finite life, which is typically dictated by the display itself, more specifically the backlight. The backlight contains LEDs, which fade over time. In the Specifications section is a figure for the typical life of the display, and the criteria are listed. • The resistive Touch model features a touch-sensitive film over the display which is sensitive to pressure. When mounting the display module in an enclosure, you should not apply pressure to the surface of the display by the enclosure. It could result in false touches or the touch will simply not function at all. 4D Systems DATASHEET Page 28 of 44 gen4-uLCD-28D Series Hardware Tools 7. Hardware Tools The following hardware tools are required for full control of the gen4 Integrated Display Modules. 7.1. 4D-UPA Programming Cable/Adaptor The 4D programming interfaces are used to program a new Firmware/PmmC, Display Driver and for downloading compiled 4DGL code into the processor. They even serve as an interface for communicating serial data to the PC. The 4D Programming Cable is a USB to Serial-TTL UART converter cable incorporating the Silabs CP2102 USB to Serial UART bridge IC. 4D Programming Cable Note In conjunction with a Programming Cable or a Programming Adaptor, the gen4 series of Display Modules require a simple interface board (gen4-IB), as there is no 5-way male header on gen4 modules like other 4D Systems modules. gen4 Interface boards (gen4-IB) ship with each gen4 Display Module unless otherwise stated. Simply connect the supplied 30-way FPC cable to the ZIF connector on the gen4 Interface Board, and connect the Programming Cable or Adaptor to the 5-way header on the Interface Board. You are now ready to program using a 4D Programming Cable. This can also be used to interface with other devices such as a 4D Arduino Adaptor Shield, breadboard etc. 4D Systems DATASHEET Page 29 of 44 gen4-uLCD-28D Series 4D-UPA Programming Cable/Adaptor An alternative to using a gen4-IB and a 4D Programming Cable is a single all-in-one board called the 4D-UPA (4D Universal Programming Adaptor). 4D-UPA The 4D-UPA minimizes the connections and modules required for programming - creating a single module with a micro USB interface, and DIP style pads for GPIO breakout of all the signals used on the gen4 Display interface, which is useful for development or final product use. The GPIO naming convention on the 4D-UPA does not reflect the GPIO naming of the actual display module, due to the 4D-UPA being universal and able to be used with many 4D Products. Please review the 4D-UPA datasheet for information on mapping the GPIO naming from this module, with the GPIO naming on the 4D-UPA, to ensure you connect to the correct pins you desire. Note In addition to these modules, the gen4-PA and uUSB-PA5/uUSB PA5-II can still be used. Please be reminded though that the uUSB-PA5/PA5-II still needs a gen4-IB to be used for programming. Using a non-4D programming interface could damage your processor, and void your warranty. 4D Systems DATASHEET Page 30 of 44 gen4-uLCD-28D Series Programming Language 8. Programming Language The DIABLO16 processor belongs to a family of processors powered by a highly optimised softcore virtual engine called EVE (Extensible Virtual Engine). EVE was designed and created by 4D Systems in the early 2000s, and should not be confused with FTDI's solution of EVE, which was developed a decent decade or so later. EVE is a proprietary, high-performance virtual machine with an extensive byte-code instruction set optimised to execute compiled 4DGL programs. 4DGL (4D Graphics Language) was specifically developed from the ground up for the EVE engine core. It is a high-level language that is easy to learn and simple to understand yet powerful enough to tackle many embedded graphics applications. 4DGL is a graphics-oriented language allowing rapid application development, and the syntax structure was designed using elements of popular languages such as C, Basic, Pascal and others. Programmers familiar with these languages will feel right at home with 4DGL. It includes many familiar instructions such as IF..ELSE..ENDIF, WHILE..WEND, REPEAT..UNTIL, GOSUB..ENDSUB, GOTO, PRINT as well as some specialised instructions SERIN, SEROUT, GFX_LINE, GFX_CIRCLE and many more. For detailed information about the 4DGL language, please refer to the following documents: • 4DGL Programmers Reference Manual • Diablo16 Internal Functions Manual To assist with the development of 4DGL applications, the Workshop4 IDE combines a full-featured editor, a compiler, a linker and a downloader into a single PC-based application. It's all you need to code, test and run your applications. 4DGL is available to be written in two of the four environments offered by the Workshop4 IDE, Designer and ViSi. The other two environments, Serial and ViSi-Genie do not directly use 4DGL by the User (Except in Workshop4 Pro, for ViSi-Genie), however, it is present in the background. Serial is an application that runs, and that is written in 4DGL. ViSi-Genie automatically generates 4DGL itself based on what is configured in the GUI. More information about each follows. 4D Systems DATASHEET Page 31 of 44 gen4-uLCD-28D Series Workshop4 IDE 9. Workshop4 IDE Workshop4 is a comprehensive software IDE that provides an integrated software development platform for all of the 4D family of processors and modules. The IDE combines the Editor, Compiler, Linker and Downloader to develop complete 4DGL application code. All user application code is developed within the Workshop4 IDE. The Workshop4 IDE supports multiple development environments for the user, to cater to different user requirements and skill levels. • The Designer environment enables the user to write 4DGL code in its natural form to program the range of 4D System's intelligent displays. • A visual programming experience, suitably called ViSi, enables drag-and-drop type placement of objects to assist with 4DGL code generation and allows the user to visualise how the display will look while being developed. • An advanced environment called ViSi-Genie doesn't require any 4DGL coding at all, it is all done automatically for you. Simply lay the display out with the objects you want, set the events to drive them and the code is written for you automatically. This can be extended with additional features when a Workshop4 PRO license is purchased from the 4D Systems website. Extended Advanced features for Visi-Genie are available in the PRO version of WS4. Further details are explained in the Visi Genie section of the Workshop4 documentation. • A Serial environment is also provided to transform the display module into a slave serial module, allowing the user to control the display from any host microcontroller or device with a serial port. For more information regarding these environments, refer to the Workshop4 manuals. The Workshop4 IDE is available from the 4D Systems website. 4D Systems DATASHEET Page 32 of 44 gen4-uLCD-28D Series PmmC Programming 9.1. PmmC Programming The DIABLO16 processor is a custom graphics processor. All functionality including the high-level commands is built into the chip. This chip-level configuration is available as a PmmC (Personalitymodule-micro-Code) file, which can be likened to traditional Firmware. There is also a Display Driver file, which separates specific display settings from the PmmC, unlike on the PICASO processor where everything is combined. A PmmC file contains all of the low-level micro-code information (analogy of that of a soft silicon) which defines the characteristics and functionality of the device. The ability to program the device with a PmmC file provides an extremely flexible method of customising as well as upgrading it with future enhancements. The Display Driver contains the initialisation and parameters associated with the particular display that is to be connected to the DIABLO16 processor, along with product-specific settings and parameters which are required over and above what is found in the PmmC. The PmmC file and Display Driver file can only be programmed into the device via the COM0 serial port with the aid of Workshop4, the 4D Systems IDE software. Solutions, which remove the need to use Workshop4 to program the display modules, are available for commercial customers requiring batch programming or production line programming. These solutions are practical for production staff and minimize the chance of unwanted or unauthorised modifications on the production line. Three solutions come with the Workshop4 IDE, which can be separated for production line computers if required, ScriptC, PmmC Loader and Program Loader. ScriptC is a command line interface that can be controlled from a Batch Script or similar, useful for repetitive loading or when controlled from an external application. Example scripts are provided, showing how to load PmmC, Display Drivers and Applications using a batch script. Program Loader is a GUI interface designed to download Applications to either Flash or RAM, useful for testing or production loading, without the need for Workshop4 itself. 4D Systems DATASHEET Page 33 of 44 gen4-uLCD-28D Series PmmC Programming PmmC Loader is a GUI interface designed to download PmmC's and Drivers to 4D Systems Processors. It can automatically update existing PmmC's and Drivers present on a module, or manually change or force download to a blank processor or module, overwriting anything written in previously. Please contact our Support Team for more information on what we can provide. Some solutions also exist for external processor-based loading, if there is a requirement for that. This solution is available under NDA. Using a non-4D programming interface could damage your module, and void your warranty. 4D Systems DATASHEET Page 34 of 44 gen4-uLCD-28D Series Display Module Part Numbers 10. Display Module Part Numbers The following is a breakdown of the part numbers and what they mean. Example: • gen4-uLCD-28DT-CLB where: gen4 - gen4 Display Range uLCD - microLCD Display Family 28 - Display size (2.8") D - Diablo16 Processor T - Resistive Touch CLB - Cover Lens Bezel Note • A product without a T or CT in the part number is a non-touch variant. • Cover Lens Bezels (CLB) are glass fronts for the display module with overhanging edges, which allow the display module to be mounted directly into a panel using special adhesive on the overhanging glass. This is available for capacitive touch only. • Resistive Touch models are not available in CLB, as a CLB is made of glass and resistive touch relies on the mechanical flexing of a membrane to trigger touch. 11. Cover Lens Bezel - Tape Spec The perimeter of the CLB display modules features double-sided adhesive tape, designed to stick directly onto a panel, enclosure, box etc without the need for any mounting screws or hardware. The tape used is 3M 9495LE tape, which uses well-known and strong 3M 300LSE adhesives. The double-sided adhesive has a thickness of 0.17mm once the backing has been removed. More information on this adhesive can be found on the 3M website. 4D Systems DATASHEET Page 35 of 44 gen4-uLCD-28D Series FFC Cable 12. FFC Cable The FFC cables supplied by 4D Systems (included with products) have the following specifications: • 30 Pin Flexible Flat Cable, 150mm Long, 0.5mm (0.02") pitch • Cable Type: AWM 20624 80C 60V VW-1 • Heat Resistance 80 Degrees Celsius • Connections on the opposite side at each end (Type B) Note You can get different cable lengths by contacting the 4D Systems sales team. If you are interfacing with this module directly to your product, and wish to interface via the FFC cable directly, suitable connectors are readily available from many electronics suppliers, such as Digikey, Mouser, Farnell, RS, etc. A standard 30-pin, 0.5mm pitch, 0.3mm thick FFC, FFC connector. They are available in Top Contact and Bottom Contact, so depending how you orientate the cable on your product, will determine which one you need. Please however take care of the pinout and how it flows from the display module, through the FFC and into your product, to ensure Pin1 and Pin30 are where you expect them to be. 4D Systems DATASHEET Page 36 of 44 gen4-uLCD-28D Series Starter Kit 13. Starter Kit 4D Systems highly recommends all first-time buyers of 4D Systems' displays, to purchase the Starter Kit when purchasing their first 4D Systems display solution. The Starter Kit provides all the hardware that is required to get the User up and running. Not all development environments and features will be needed by every User. However, purchasing the display solution in a Starter Kit allows you to take full advantage of all of the features of the 4D Systems Display Solution and try out each of the 4D Woskshop4 Environments before settling with the preferred feature set. The Designer environment can use every feature of the display, however, depending on the user requirements, a micro-SD (uSD) card may not be required. The uSD card is used when displaying images/video/sound, along with data logging to uSD, and a programming cable or adaptor is required for downloading compiled code and PmmC/Firmware updates. The ViSi environment is the same as Designer in terms of feature utilisation, but is image based so requires a uSD card, along with a programming cable. The ViSi-Genie environment is also image-based, and therefore requires a uSD card and programming cable also. The Serial environment does not require either a uSD or Programming cable to be used once the module has been configured as a Serial device, however, can use both depending on the user's requirements. The uSD card can be used for such things as storage and display of multimedia files, data logging, and the Programming cable for PmmC/Firmware updates, or changing to one of the other three programming environments. Starter Kits typically include: • gen4 Integrated Display Module • gen4 Interface Module (gen4-IB) • 4D Universal Programming Adaptor (4D-UPA) • 4GB micro-SD Card • 5-way cable for easy connection to a breadboard or host via the gen4-IB • 150mm 30-way FFC cable for connecting gen4 display to gen4-IB or 4D-UPA Please refer to the 4D Systems website for the current components included in the Starter Kit. Simply select the Starter Kit option when purchasing the chosen display module on the 4D Systems shopping cart, or from your local distributor. 4D Systems DATASHEET Page 37 of 44 gen4-uLCD-28D Series Mechanical Details (Resistive Touch & Non-Touch without Cover Lens Bezel) 14. Mechanical Details (Resistive Touch & Non-Touch without Cover Lens Bezel) 4D Systems DATASHEET Page 38 of 44 gen4-uLCD-28D Series Mechanical Details (Non-Touch & with Cover Lens Bezel) 15. Mechanical Details (Non-Touch & with Cover Lens Bezel) 4D Systems DATASHEET Page 39 of 44 gen4-uLCD-28D Series Schematic Details 16. Schematic Details 4D Systems DATASHEET Page 40 of 44 gen4-uLCD-28D Series Specifications 17. Specifications Absolute Maximum Ratings Operating ambient temperature -20°C to +70°C Storage temperature -30°C to +80°C Voltage on any digital input pin with respect to GND -0.3V to 6.0V Voltage on VCC with respect to GND -0.3V to 6.0V Maximum current sunk/sourced by any pin 10.0mA Maximum current sunk/sourced by all ports 200.0mA Note Stresses above those listed here may cause permanent damage to the device. This is for stress rating only and functional operation of the device at those or any other conditions above those indicated in the recommended operation listings of this specification is not implied. Exposure to maximum rating conditions for extended periods may affect device reliability. Recommended Operating Conditions Parameter Conditions Min Typ Max Units Supply Voltage (VCC) Stable external supply required 4.0 5.0 5.5 V -- 3.3 -- V -10 -- +60 °C 0 -- 0.2VP V Processor voltage (VP) Operating Temperature Input Low Voltage (VIL) all pins Input High Voltage (VIH) non 5V tolerant pins 0.8VP -- 3.3 V Input High Voltage (VIH) PA4-PA13, RX0 and TX0 pins 0.8VP -- 5.5 V Reset Pulse External Open Collector 2.0 -- -- µs Operational Delay Power-Up or External Reset 500 -- 3000 ms 4D Systems DATASHEET Page 41 of 44 gen4-uLCD-28D Series Specifications Global Characteristics Based on Operating Conditions Parameter Conditions Min Typ Max Units Supply Current (ICC) 5V Supply - gen4-uLCD-28D -- 150 -- mA 5V Supply - gen4-uLCD-28D-CLB -- 150 -- mA 5V Supply - gen4-uLCD-28DT -- 160 -- mA Display Endurance Hours of operation, measured to when the display is 50% original brightness 30000 -- -- H Touch Screen Endurance Number of touches/hits with a 12.5mm tip at a rate of 2x per second with 250gf force -- 1M -- Touches Slide stylus on screen, 100gf force, 60mm/s the speed with a 0.8mm polyacetal tip stylus pen -- 100K -- Slides 80 -- -- % Touch Screen Transparency Touch Screen Operational Force Only use Finger or Stylus, do not use anything sharp or metal 20 -- 100 Gf CLB Display Hardness Cover Lens Bezel Glass Hardness -- 6 -- H 4D Systems DATASHEET Page 42 of 44 gen4-uLCD-28D Series Specifications LCD DISPLAY INFORMATION Parameter Conditions Specification Display Type TFT Transmissive LCD Display Size 2.8" Diagonal Display Resolution 240 x 320 (Portrait View) Display Brightness 5V Supply, gen4-uLCD-28D 175 cd/m2 (typical) 5V Supply, gen4-uLCD-28DCLB 170 cd/m2 (typical) 5V Supply, gen4-uLCD-28DT 140 cd/m2 (typical) Display Contrast Ratio Typical 250:1 Display Viewing Angles Above Centre 35 Degrees Below Centre 55 Degrees Left of Centre 55 Degrees Right of Centre 55 Degrees Display Viewing Direction Display Backlighting 6 O'clock Display (Optimal viewing is from below when in Portrait mode) White LED Backlighting 1x4 Parallel LED's Pixel Pitch Pixel Density 0.18 x 0.18 mm (Square pixels) Number of pixels in 1 row in 25.4mm 141 DPI/PPI Note The Displays used are of the highest rated 'Grade A', which allows for 0-4 defective pixels. A defective pixel could be solid Black (Dead), White, Red, Green or Blue. 4D Systems DATASHEET Page 43 of 44 gen4-uLCD-28D Series Revision History 18. Revision History Datasheet Revision Revision Number Date Description 0.1 01/01/2015 Internal Use Only 1.0 09/12/2015 Initial Public Release Version 1.1 22/12/2015 Cosmetic Changes to gen4 Datasheet range 1.2 15/03/2016 Updates to display specs following initial production samples, and the addition of the CLB model, and drawing 1.3 08/06/2016 Drawing and Specification updates, other minor changes 1.4 09/04/2018 Addition of 4D-UPA 1.6 04/03/2019 Cosmetic Changes to gen4 Datasheet range 1.7 11/11/2019 1.8 24/06/2021 General updates/information. Addition of FFC cable/connector information. FFC Cable section. 1.9 07/09/2021 Addition to display information/specs Specifications section. 1.10 03/01/2023 Modified datasheet for web-based documentation. Updated details regarding Serial Port voltage tolerance Hardware Revision 4D Systems Revision Number Date 1.2 31/05/2015 DATASHEET Description Initial Public Release Version Page 44 of 44
GEN4-ULCD-28DT 价格&库存
很抱歉,暂时无法提供与“GEN4-ULCD-28DT”相匹配的价格&库存,您可以联系我们找货
GEN4-ULCD-28DT
  • 1+378.03270
  • 10+370.47226
库存:26
