4D Serial Pi Adaptor
Datasheet
Revision 1.3
Copyright © 2023 4D Systems
Content may change at any time. Please refer to the resource centre for latest documentation.
Contents
1. Description
3
2. Specifications
5
4D Systems
DATASHEET
Page 2 of 5
Description
1. Description
The 4D Pi Serial Adaptor (4D-Serial-Pi-Adaptor) is a simple Raspberry Pi* adaptor designed to
provide a convenient interface to attach 4D Systems display modules to the Raspberry Pi platform,
without having to use jumper wires on the Raspberry Pi headers.
The 4D Pi Serial Adaptor is included in various 4D Systems PI Module Packs but can be purchased
separately if a 4D Display Module is not required or is owned already.
Communication to the 4D Systems Display Modules is performed via the Raspberry Pi's serial port
(RX and TX) and is provided to the user in a simple 5-pin interface, where a 5-way cable (included in
the -PI Module Packs) can be attached between the adaptor and the Display Module.
Power for the display is supplied from the Raspberry Pi's 5V bus. No external power is required for
the Display Module as all power is supplied from the Raspberry Pi, via the Adaptor. Please ensure the
Raspberry Pi is powered with a suitably powered 5V power pack.
The 4D Serial Pi Adaptor is compatible with versions A, B and B+ Raspberry Pi's.
The 4D Serial Pi Adaptor is compatible with essentially all 4D Systems Intelligent Displays, primarily
the following:
• uLCD-24PT
• uLCD-28PT
• uLCD-32PT
• uOLED-96-G1/G2
• uOLED-128-G1/G2
• uOLED-160-G1/G2
• uLCD-144-G1/G2
• uLCD-43 (All versions)
• uLCD-24-PTU
• uLCD-28-PTU
• uLCD-32-PTU
• uLCD-32W-PTU
• uLCD-35DT
• uLCD-70DT
• uLCD-220RD
The 4D Raspberry Pi Library is available to download from the 4D Systems website.
4D Systems
DATASHEET
Page 3 of 5
Description
4D Pi Serial Adaptor attached to a Raspberry Pi
4D Pi Display Module Pack
(4D Pi Serial Adaptor is one part of this pack)
Note
Raspberry Pi remains the property of the Raspberry Pi Foundation. All references to the words 'Raspberry Pi'
are Trademarks of the Raspberry Pi Foundation, and all references to 4D Systems modules/adaptors with the
Raspberry Pi are based on compatibility with the Raspberry Pi Hardware and do not indicate ownership of or
to the Raspberry Pi in any way.
4D Systems
DATASHEET
Page 4 of 5
Specifications
2. Specifications
Recommended Operating Conditions
Parameter
Min
Typ
Max
Units
Supply Voltage
(VCC)
4.5
5.5
V
Operating
Temperature
-10
+70
°C
3.3
V
UART Voltage
Conditions
Raspberry Pi is 3.3V only. 4D System
modules are 3.3V also but are 5V
tolerant
Ordering Information
Order Code: 4D-Serial-Pi-Adaptor
Package: 65mm x 50mm x 30mm
Packaging: Module sealed in antistatic foam padded 4D Systems Box
4D Systems
DATASHEET
Page 5 of 5
很抱歉,暂时无法提供与“ULCD-24PTU-PI”相匹配的价格&库存,您可以联系我们找货
