4D SYSTEMS
TURNING TECHNOLOGY INTO ART
DATASHEET
4D Raspberry Pi Serial Adaptor
4D-Serial-Pi-Adaptor
Document Date: 21st August 2014
Document Revision: 1.2
Uncontrolled Copy when printed or downloaded.
Please refer to the 4D Systems website for the latest Revision of this document
4D Pi Serial Adaptor
Contents
1. Description ............................................................................................................................. 3
2. Specifications and Ratings ....................................................................................................... 4
3. Legal Notice............................................................................................................................ 5
4. Contact Information ............................................................................................................... 5
4D SYSTEMS
1. Description
The 4D Pi Serial Adaptor (4D-Serial-Pi-Adaptor) is a
simple Raspberry Pi* adaptor designed to provide
a convenient interface to attach 4D Systems
display modules to the Raspberry Pi platform,
without having to use jumper wires on the
Raspberry Pi headers.
For information regarding the modules which
connect to this 4D Pi Serial Adaptor, please refer
to their product pages and Datasheets.
The 4D Pi Serial Adaptor is included in various 4D
Systems -PI Module Packs, but can be purchased
separately if a 4D Display Module is not required
or is owned already.
Communication to the 4D Systems Display
Modules is performed via the Raspberry Pi’s serial
port (RX and TX), and is provided to the user in a
simple 5-pin interface, where a 5 way cable
(included in the -PI Module Packs) can be attached
between the adaptor and the Display Module.
Power for the display is supplied from the
Raspberry Pi’s 5V bus. No external power is
required for the Display Module as all power is
supplied from the Raspberry Pi, via the Adaptor.
Please ensure the Raspberry Pi is powered with a
suitably powered 5V power pack.
4D Pi Serial Adaptor attached to a Raspberry Pi
The 4D Serial Pi Adaptor is compatible with
versions A, B and B+ Raspberry Pi’s.
essentially all 4D Systems Intelligent Displays,
primarily the following:
uLCD-24PT
uLCD-28PT
uLCD-32PT
uOLED-96-G1/G2
uOLED-128-G1/G2
uOLED-160-G1/G2
uLCD-144-G1/G2
uLCD-43 (All versions)
uLCD-24-PTU
uLCD-28-PTU
uLCD-32-PTU
uLCD-32W-PTU
uLCD-35DT
uLCD-70DT
uLCD-220RD
4D Pi Display Module Pack
(4D Pi Serial Adaptor is one part of this pack)
The 4D Raspberry Pi Library is available to
download from the 4D Systems website,
www.4dsystems.com.au
© 2014 4D SYSTEMS
NOTE (*): Raspberry Pi remains the property of the
Raspberry Pi Foundation. All references to the
words ‘Raspberry Pi’ are Trademarks of the
Raspberry Pi Foundation, and all references to 4D
Systems modules/adaptors with the Raspberry Pi
are based on compatibility with the Raspberry Pi
Hardware, and do not indicate ownership of or to
the Raspberry Pi in any way.
Page 3 of 5
4D SYSTEMS
RECOMMENDED OPERATING CONDITIONS
Parameter
Supply Voltage (VCC)
Operating Temperature
UART Voltage
Conditions
Raspberry Pi is 3.3V only.
4D System modules are 3.3V also
but are 5V tolerant
Min
4.5
-10
Typ
--3.3
Max
5.5
+70
Units
V
°C
V
ORDERING INFORMATION
Order Code: 4D-Serial-Pi-Adaptor
Package: 65mm x 50mm x 30mm
Packaging: Module sealed in antistatic foam padded 4D Systems Box
© 2014 4D SYSTEMS
Page 4 of 5
4D SYSTEMS
3. Legal Notice
Proprietary Information
The information contained in this document is the property of 4D Systems Pty. Ltd. and may be the subject of
patents pending or granted, and must not be copied or disclosed without prior written permission.
4D Systems endeavours to ensure that the information in this document is correct and fairly stated but does
not accept liability for any error or omission. The development of 4D Systems products and services is
continuous and published information may not be up to date. It is important to check the current position with
4D Systems. 4D Systems reserves the right to modify, update or makes changes to Specifications or written
material without prior notice at any time.
All trademarks belong to their respective owners and are recognised and acknowledged.
Disclaimer of Warranties & Limitation of Liability
4D Systems makes no warranty, either expressed or implied with respect to any product, and specifically
disclaims all other warranties, including, without limitation, warranties for merchantability, non-infringement
and fitness for any particular purpose.
Information contained in this publication regarding device applications and the like is provided only for your
convenience and may be superseded by updates. It is your responsibility to ensure that your application meets
with your specifications.
Images and graphics used throughout this document are for illustrative purposes only. All images and graphics
used are possible to be displayed on the 4D Systems range of products, however the quality may vary.
In no event shall 4D Systems be liable to the buyer or to any third party for any indirect, incidental, special,
consequential, punitive or exemplary damages (including without limitation lost profits, lost savings, or loss of
business opportunity) arising out of or relating to any product or service provided or to be provided by 4D
Systems, or the use or inability to use the same, even if 4D Systems has been advised of the possibility of such
damages.
4D Systems products are not fault tolerant nor designed, manufactured or intended for use or resale as on line
control equipment in hazardous environments requiring fail – safe performance, such as in the operation of
nuclear facilities, aircraft navigation or communication systems, air traffic control, direct life support machines
or weapons systems in which the failure of the product could lead directly to death, personal injury or severe
physical or environmental damage (‘High Risk Activities’). 4D Systems and its suppliers specifically disclaim
any expressed or implied warranty of fitness for High Risk Activities.
Use of 4D Systems’ products and devices in 'High Risk Activities' and in any other application is entirely at the
buyer’s risk, and the buyer agrees to defend, indemnify and hold harmless 4D Systems from any and all
damages, claims, suits, or expenses resulting from such use. No licenses are conveyed, implicitly or otherwise,
under any 4D Systems intellectual property rights.
For Technical Support: support@4dsystems.com.au
For Sales Support: sales@4dsystems.com.au
Website: www.4dsystems.com.au
Copyright 4D Systems Pty. Ltd. 2000-2014.
© 2014 4D SYSTEMS
Page 5 of 5
