Datasheet
Photon Detection
Surface Mount 905 nm Pulsed Semiconductor Lasers
High Power Laser-Diode Family for Commercial Range Finding
Excelitas’ pulsed laser diodes produce very high peak optical pulses centered at a wavelength of 905 nm. The package
can emit light parallel or perpendicular to the mounting plane.
Key Features
• High Volume Reflow SMD package
• Multi-epi quantum well structure
• Excellent power stability with temperature
• Horizontal and vertical emission possibility
• 75 µm and 225 µm active laser length
• RoHS compliant
Applications
• LiDAR / ToF measurements
• Laser Range Finding
• Laser Scanning / UGV
• Infrared Night Illumination
• Laser Therapy
• Material excitation in medical and other
analytical applications
All specifications are valid for TA = 23 °C, tp = 100 ns and fp = 1 kHz, unless otherwise specified.
Table 1: Key parameters
Parameter
Peak Optical Power
Wavelength
Operating Temperature1
75 µm, 10 A
225 µm, 30 A
Symbol
P75
P225
C
Top
Minimum
18
65
895
-40
Typical
905
Maximum
Unit
W
925
85
nm
°C
Note 1: Extended temperature range specification available. Please
contact Excelitas Technologies for more information.
www.excelitas.com
TPGAD1S0XH_2023_06 Page 1 of 10
Table 2: Ordering Information
Parameter
Number of stripes
Active Area Size
Emitting width1,2
Emitting height1,2
Symbol
S
A
w
h
TPGAD1S03H
TPGAD1S09H
3
75x10
86
225x10
263
10
Unit
µm²
µm
µm
Note 1: The emitting area is defined as FWHM(w) x FWHM(h) of the nearfield size at iF.
Note 2: Parameter depending on drive current. Please contact Excelitas Technologies for more information.
Table 3: Absolute Maximum Ratings
Parameter
Peak Reverse Voltage
Pulse Duration
Duty Factor
Storage Temperature
Symbol
VRM
tW
du
TS
Value
2
100
0.1
-40 … 105
Units
V
ns
°C
Note 1: Stresses above those listed under “Absolute Maximum Ratings” may cause permanent damage to
the device.
Note 2: Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Table 4: Emission Specifications
Parameter
Spectral Width (FWHM)
Wavelength junction Temperature
Coefficient
Package Thermal Resistance1
Divergence Parallel to Junction Plane
Divergence Perpendicular to Junction Plane
Symbol
Minimum
Typical
10
Maximum
Units
nm
Tj
0.25
nm/°C
Rth
θ||
θ|
70
7.5
25
°C/W
Note 1: Simulated from the Chip Junction to the cathode PCB connection pad.
www.excelitas.com
Page 2 of 10
TPGAD1S0XH_2023_06
Table 5: Electrical Specifications
Parameter
Peak Optical Power1
Drive Current
Forward Voltage2
Threshold Current
Series Resistance
Bandgap Voltage
Drop
Package Inductance
TPGAD1S03H
TPGAD1S09H
Symbol Minimum Typical Maximum Minimum Typical Maximum Unit
P
18
70
W
iF
10
30
A
VF
11
13.5
V
iTh
0.75
1.75
A
RS
0.454
0.23
Ω
Vg
6.5
6.5
V
LP
1.6
1.6
nH
Note 1: at iF
Note 2: As estimated by 𝑉𝐹 = 𝑅𝑆 𝑖𝐹 + 𝑉𝑔 .
Figure 1: Laser Package Dimension TPGAD1S03H / TPGAD1S09H
www.excelitas.com
Page 3 of 10
TPGAD1S0XH_2023_06
Figure 2: Typical P vs. iF
Figure 3: Typical Emission Spectrum
a
la v
si y
p
la v
as a
a i
c
av l
Figure 5: Typical P vs. Tj
a
av l
p
Figure 4: Typical λ vs. Tj
c
T
c
p a
Figure 6: Typical θ|
T
p a
Figure 7: Typical θ||
si y
si y
p
www.excelitas.com
ic la
a all l
l
Page 4 of 10
l
TPGAD1S0XH_2023_06
Information
Excelitas Technologies’ pulsed semiconductor laser, emitting at 905nm in the near IR, uses a multi-layer
monolithic chip design. The laser diode is mounted on an FR4 substrate leadless laminate carrier (LLC) with
excellent thermal management. This is intended for both surface mount applications and hybrid integration.
The encapsulate material is an epoxy resin for low cost and high-volume manufacturing.
The package design and assembly processing techniques are such that the die positioning is well controlled to
the reference surfaces. This aids in the alignment of optical elements to the package and is superior to many
of the commercially available plastic lead frame TO-18 and SMD style packages in the market.
The SMD package can be mounted with laser beam propagation horizontally or vertically to the PCB surface.
The beam propagation possesses a 25° divergence in the direction perpendicular to the chip surface and 7.5°
divergence parallel to the chip surface. The output power shows an excellent stability over the full MIL
specification temperature range.
Our quantum well laser design offers rise and fall times of < 1 ns. However, the drive circuit layout and
mounting inductance play a dominant role and should be designed in accordance with the desired optical pulse
width.
The peak wavelength at 905 nm is centered near the maximum responsivity of most silicon photodiodes. The
laser wavelength matches especially well with devices from the Excelitas EPI-APD C30737 family.
The devices are ideally suited for applications where cost is a primary concern and high-volume production
capacity is required.
Unconnected laser dies as shipped cannot emit light. Light emission requires an installation into an electrical
driver circuit.
www.excelitas.com
Page 5 of 10
TPGAD1S0XH_2023_06
Principle of operation
The light output of a laser diode is proportional to the current running through the laser by pulsing it in the
forward bias direction. A simple way of allowing a large current to flow within nanoseconds through the laser
is to discharge a large capacitor into the laser by closing a GaN-FET.
Excelitas recommends the usage of a low-side driver to operate the laser. A detailed description of the circuitry
to recharge the capacitors is omitted here since many options are available on the market. The voltage on the
capacitors and discharge time will dictate the current flow in the laser.
Electrical circuits should be designed to protect the diodes from high current and reverse voltage transients.
Optimum long-term reliability will be attained with the semiconductor at or below room temperature.
Adequate heat sinking should be employed, particularly when operated at maximum duty cycle.
Package inductance
When narrow pulse widths are required, the system designer must take care that circuit inductance is kept
to a minimum. Using a low inductance package will reduce the peak voltage required to obtain the desired
drive current.
For example, to obtain approximate Gaussian pulse shapes of 40 ns and 1 ns, the below voltage should be
considered in addition to the typical forward voltage:
40 ns:
o 𝑡𝑝 = 40 ns, 𝑡𝑟 = 20 ns
o 𝐼𝐹 = 30 A, 𝐿𝑃 = 1.6 nH
o 𝑉𝑃 =
1.6 nH x 30 A
20ns
= 2.4 V
1 ns:
o 𝑡𝑝 = 1 ns, 𝑡𝑟 = 0.5 ns
o 𝑉𝑃 =
www.excelitas.com
1.6 nH x 30 A
0.5ns
= 96 V
Page 6 of 10
TPGAD1S0XH_2023_06
Testing methods
Excelitas verifies the electro optical specifications on every shipped unit.
Visual inspection during fabrication is performed as per our standard and failed lasers are removed.
Packaging and shipping
For sampling quantities, lasers are placed in Waffle Packs.
For production quantities, lasers are placed in Tape & Reel, according to Figure 8.
Orientation (vertical or horizontal) needs to be specified upon order in T&R.
MSL Rating
This series of laser diodes comply with a Moisture Sensitivity Level (MSL) rating of 3 as defined in IPC/JEDECJ-STD-033C. This allows for up to 168 hour floor life at < 30°C / 60%RH once removed from the sealed reel
packaging. For complete details refer to the IPC/JEDEC- J-STD-033C specification.
Storage and handling
This laser is a static-sensitive device. Therefore, Excelitas highly recommends following the below notes:
Keep unused devices in ESD-safe material
Protect devices from static discharge and static fields
Keep Reels inside their moisture barrier bags until assembly. Respect the MSL rating.
If a manual picking method is necessary, use a non-marring tweezer to pick the laser by the short sides
only.
Precautions should be taken to avoid reverse polarity of power supply. Reversed polarity of power
supply above the breakdown voltage listed under “Absolute Maximum Ratings” results in a destroyed
unit.
www.excelitas.com
Page 7 of 10
TPGAD1S0XH_2023_06
Figure 8: Tape and Reel Packaging Dimensions
www.excelitas.com
Page 8 of 10
TPGAD1S0XH_2023_06
Table 6: Reflow Solder Profile
T
Profile Feature
Symbol Typical Units
Minimum Sparkling Temperature
TSmin
150
°C
Maximum Sparkling Temperature TSmax
200
°C
Sparkling Time
tS
75
s
Minimum Reflow Temperature
TL
217
°C
Peak Temperature
TP
244
°C
Reflow Time
tL
65
s
Time within TP - 5°C
tP
25
s
Ramp Down Rate
ΔTc
2
°C/s
p a
The following reflow solder profile is a typical used profile for SAC305 solder alloys. Specific solder
parameters depend on the solder alloy used.
Ti
s
For Your Safety: Laser Radiation
Under operation, these devices produce invisible electromagnetic radiation that may be harmful to the human
eye. To ensure that these laser components meet the requirements of Class IIIb laser products, they must not
be operated outside their maximum ratings. Power supplies used with these components must be such that
the maximum peak forward current cannot be exceeded. It is the responsibility of the user incorporating a
laser into a system to certify the Class of use and ensure that it meets the requirements of the ANSI or
appropriate authority.
Further details may be obtained in the following publications:
21CFR 1040.10 – “Performance Standards for Light Emitting Products (Laser Products)”
ANSI Z136.1 – “American National Standard for Safe use of Lasers”
IEC 60825-1 – “Safety of Laser Products”
www.excelitas.com
Page 9 of 10
TPGAD1S0XH_2023_06
RoHS Compliance
This series of APD diodes are designed and built to be fully compliant with the European Union Directive
on restrictions of the use of certain hazardous substances in electrical and electronic equipment.
Warranty
A standard 12-month warranty following shipment applies.
About Excelitas Technologies
Excelitas Technologies is a global technology leader focused on delivering innovative, customized solutions to
meet the lighting, detection and other high-performance technology needs of OEM customers.
Excelitas has a long and rich history of serving our OEM customer base with optoelectronic sensors and
modules for more than 45 years beginning with PerkinElmer, EG&G, and RCA. The constant throughout has
been our innovation and commitment to delivering the highest quality solutions to our customers worldwide.
From aerospace and defense to analytical instrumentation, clinical diagnostics, medical, industrial, and safety
and security applications, Excelitas Technologies is committed to enabling our customers' success in their
specialty end-markets. Excelitas Technologies has approximately 7,000 employees in North America, Europe
and Asia, serving customers across the world.
22001 Dumberry Road
Vaudreuil-Dorion, Quebec
Canada J7V 8P7
Telephone: (+1) 450.424.3300
Toll-free: (+1) 800.775.6786
Fax: (+1) 450.424.3345
GmbH & Co. KG
Wenzel-Jaksch-Str. 31
D-65199 Wiesbaden
Germany
Telephone: (+49) 611 492 430
Fax: (+49) 611 492 165
Excelitas Technologies Singapore, Pte. Ltd.
8 Tractor Road
Singapore 627969
Telephone: (+65) 6775 2022 (Main number)
Telephone: (+65) 6770 4366 (Customer Service)
Fax: (+65) 6778-1752
Contact us at http://www.excelitas.com/contact
For a complete listing of our global offices, visit www.excelitas.com/locations
© 2023 Excelitas Technologies Corp. All rights reserved. The Excelitas logo and design are registered trademarks of Excelitas Technologies Corp. All other trademarks not owned by Excelitas Technologies or its subsidiaries that are
depicted herein are the property of their respective owners. Excelitas reserves the right to change this document at any time without notice and disclaims liability for editorial, pictorial or typographical errors.
www.excelitas.com
Page 10 of 10
TPGAD1S0XH_2023_06
很抱歉,暂时无法提供与“TPGAD1S09H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+251.59680
- 200+100.39680
- 500+97.03800
- 1000+95.38560
