DATASHEET
Photon Detection
PGEW Series of Single- and Multi-epi 905 nm Pulsed Semiconductor Lasers
Low-Cost High-Power Laser-Diode Family
The PGEW Series is ideal for commercial range finding applications.
Excelitas Technologies’ PGEW Series of single- and multi-epi 905 nm pulsed
semiconductor lasers consists of a series of devices having up to four active lasing
layers epitaxially grown on a single GaAs substrate chip. This multi-layer design
multiplies the output power by the number of epi-layers. For example, the QPGEW
quad laser at 225 µm active layer width, which has four epitaxially grown lasing
layers, delivers an output peak power close to 100 W.
The T1 ¾ (TO-like) plastic encapsulated package complements Excelitas' epi-cavity
lasers in hermetic metal packages and are ideally suited for high volume
applications. The lasers employ Excelitas’ novel multi-active area laser chips to
deliver high output power in a small emitting area.
The laser chips of the PGEW family feature stripe widths of 75 and 225 µm and
come as single (PGEW), double (DPGEW), triple (TPGEW), or quadruple (QPGEW)
epi-cavity version. These devices possess a 25° beam divergence in the direction
perpendicular to chip surface and a 10° beam spread within the junction plane.
The power output shows an excellent stability over the full MIL specification
temperature range. Structures are fabricated using metal organic chemical vapour
deposition (MOCVD).
Where fiber coupling applications are concerned, the transverse spacing of the
epi-cavity active area concentrates more optical power into a smaller geometry
allowing for increased optical power coupling into optical fibers.
Intensity of light is shown from
single-cavity, dual-cavity, triplecavity and quad-cavity lasers.
Key Features
Doubling, tripling or quadrupling
of the output power from a
single epi-cavity chip with a
small active area
Peak power over 100 W at 20 ns
pulse width
High reliability
Small emitting areas increase
fiber coupled output
Lower cost plastic packaging for
high volume
RoHS compliant
Applications
Laser range finding
Laser-based speed enforcement
IR-illumination
Laser skin therapy
Peak wavelength is centered near the maximum responsivity of most silicon
photodiodes. The PGEW lasers match especially well with devices from the
Excelitas epi-APD family C30737. The devices are ideally suited for applications
where cost is a primary concern and high volume production capacity is required.
www.excelitas.com
Page 1 of 6
PGEW Multi-epi series Rev.2016-05
PGEW Series of Single-epi and Multi-epi 905 nm Pulsed Semiconductor Lasers
Low-Cost High-Power Laser-Diode Family for Commercial Range Finding
Table 1: PGEW Pulsed Laser Family Selection Guide
Device
Typical peak power
Total # of
at iFM, 100 ns, 10A at iFM, 100 ns, 30A
emitting
3 mils (75 µm)
9 mils (225 µm)
stripes
stripe width
stripe width
Description
PGEW1SXXH
Single chip laser – Single epi-cavity
1
6.5 W
23 W
DPGEW1SXXH Single chip laser – Double epi-cavity
2
13 W
45 W
TPGEW1SXXH Single chip laser – Triple epi-cavity
3
20 W
70 W
QPGEW1SXXH Single chip laser – Quad epi-cavity
4
25 W
85 W
Table 2: Maximum Ratings
Parameter
Symbol
Min
Max
Units
Peak reverse voltage
VRM
2
V
Pulse duration
tW
100
ns
Duty factor
du
0.1
Storage temperature
TS
-55
105
°C
Operating temperature
TOP
-55
85
°C
+260
°C
Soldering for 5 seconds (leads only)
Table 3: Generic Electro Optical Specifications at 23°C
Parameter
Symbol Min Typ Max
Center wavelength of spectral envelope
λC
Spectral bandwidth at 50% intensity points
Δλ
5
nm
Δλ/ΔT
0.25
nm/°C
Beam spread (50% peak intensity) parallel to junction plane
Θ||
10
degrees
Beam spread (50% peak intensity) perpendicular to junction plane
Θ|
25
degrees
Wavelength temperature coefficient
895 905
Units
915
nm
Table 4: 75µm Stripe Width Family: Operating Characteristics at TOP=23°C, iFM=10A, tW=100ns, prr =1kHz
Parameter
POmin
Minimum Optical Power at iFM
POtyp
Typical Optical Power at iFM
# of Emitting stripes
Emitting area
Maximum Peak forward Current iFM
Typical lasing threshold current
iTH
2
Typical Forward voltage at iFM
VF
Typical Series Resistance
R
Typical Bandgap Voltage Drop
Vg
1.
2.
PGEW1S03H DPGEW1S03H TPGEW1S03H QPGEW1S03H1 Units
6
6.5
1
75 X 1
10
0.5
2.4
0.10
1.4
12
13
2
75 X 5
10
0.75
6.4
0.23
4.1
18
75 X 10
10
0.75
22.5
25
4
75 X 15
10
0.75
10.6
0.41
6.5
14.7
0.52
9.5
Operating pulse width for the QPGEW1S03H is 50ns
Excluding the voltage drop contribution due to the inductive element of the package, as estimated by
www.excelitas.com
Page 2 of 6
W
W
µm
A
A
V
Ω
V
Table 5: 225µm Stripe Width Family: Operating Characteristics at TOP=23ºC, iFM=30A, tW=100ns, prr =1kHz
PGEW1S09H DPGEW1S09H TPGEW1S09H QPGEW1S09H3 Units
Parameter
POmin
POtyp
Emitting area
iTH
4
VF
Rs
Vg
3.
4.
21
23
1
225 X 1
30
1.5
3.2
0.06
1.4
42
45
2
225 X 5
30
1.75
65
70
3
225 X 10
30
1.75
78
85
4
225 X 15
30
1.75
8
0.13
4.1
12.8
0.21
6.5
17.3
0.26
9.5
W
W
µm
A
A
V
Ω
V
Ordering Guide
X P G A X
Double active area
D
Triple active area
T
Quadruple active area
Q
Pulsed
X S XX H
P
G
905 nm nominal centre wavelength
E
± 10 nm centre wavelength tolerance
Plastic T1 ¾W package
W
Single chip stack
1
Stackable chip
S
0.003“ wide laser stripe (75 µm)
03
0.009“ wide laser stripe (225 µm)
09
RoHS compliance
H
100
100
90
90
Relative Radiant Intensity [%]
Total Peak Radiant Intensity as a ratio of the
Maximum Output Power at the Maximum
Rated Current [%]
Electro-Optical Characteristics
80
70
60
50
40
30
Figure 1
LEFT:
Total Peak
Radiant Intensity
vs. Peak drive
Current
80
70
60
50
RIGHT:
Spectral
Distribution Plot
40
30
40
50
60
70
80
Peak Drive Current as a ratio of the
Maximum Rated Current
www.excelitas.com
90 100
Page 3 of 6
890
900
910
Wavelength [nm]
920
930
100
90
80
70
60
50
40
30
-30
-20
-10
Angle [degrees]
LEFT:
Far field Pattern
Parallel to
Junction Plane
RIGHT:
Far field Pattern
Perpendicular to
Junction Plane
-50 -40 -30 -20 -10 0
10 20
Angle [degrees]
30
40
50
Figure 3
1000
Radiant Intensity
vs. Pulse Width
for Safe
Operation
1000
Figure 2
100
90
80
70
60
50
40
30
LEFT:
PGEW, DPGEW
and TPGEW
lasers
100
Safe Operating Region
10
RIGHT:
QPGEW lasers
10
1
10
Pulse width at FWHM [ns]
100
1
10
100
Figure 4: Package Drawings (W package)
Dimensions are in mm [inches], are for reference only and subject to change without notice.
www.excelitas.com
Page 4 of 6
Operating Conditions
The laser is operated by pulsing current in the forward bias direction.
The Excelitas warranty applies only to devices operated within the maximum rating, as specified. Exceeding these
conditions is likely to cause permanent “burn off” damage to the laser facet and consequently a significant
reduction in optical power. Operating the devices at increased duty cycles will ultimately and irreparably damage
the crystal structure due to internal heating effects.
Diodes are static sensitive and suitable precautions should be taken when removing the units from their antistatic
containers. Circuits should be designed to protect the diodes from high current and reverse voltage transients.
Voltages exceeding the reverse breakdown of the semiconductor junction are particularly damaging and have
been shown to cause degradation of power output.
Although the devices will continue to perform well at elevated temperatures for some thousands of hours, defect
mechanisms are accelerated. Optimum long term reliability will be attained with the semiconductor at or below
room temperature.
Adequate heat sinking should be employed when operated at maximum duty factor.
For Your Safety
Laser Radiation:
Under operation, these devices produce invisible electromagnetic radiation that may be harmful to the human
eye. To ensure that these laser components meet the requirements of Class IIIb laser products, they must not be
operated outside their maximum ratings. Power supplies used with these components must be such that the
maximum peak forward current cannot be exceeded. It is the responsibility of the user incorporating a laser into a
system to certify the Class of use and ensure that it meets the requirements of the ANSI or appropriate authority.
Further details can be obtained in the following publications:
21CFR 1040.10 – “Performance Standards for Light Emitting Products (Laser Products)”
ANSI Z136.1 – “American National Standard for Safe Use of lasers”
IEC 60825-1 – “Safety of Laser Products”
RoHS Compliance
This series of laser diodes are designed and built to be fully compliant with the European Union Directive
2011/65/EU – Restriction of the use of certain Hazardous Substances (RoHS) in Electrical and Electronic
equipment.
www.excelitas.com
Page 5 of 6
Warranty
A standard 12-month warranty following shipment applies. Any warranty is null and void if the package window
has been opened.
About Excelitas Technologies
Excelitas Technologies is a global technology leader focused on delivering innovative, customized solutions to
meet the lighting, detection and other high-performance technology needs of OEM customers.
Excelitas has a long and rich history of serving our OEM customer base with optoelectronic sensors and modules
for more than 45 years beginning with PerkinElmer, EG&G, and RCA. The constant throughout has been our
innovation and commitment to delivering the highest quality solutions to our customers worldwide.
From aerospace and defense to analytical instrumentation, clinical diagnostics, medical, industrial, and safety and
security applications, Excelitas Technologies is committed to enabling our customers' success in their specialty
end-markets. Excelitas Technologies has approximately 5,000 employees in North America, Europe and Asia,
serving customers across the world.
22001 Dumberry Road
Vaudreuil-Dorion, Quebec
Canada J7V 8P7
Telephone: (+1) 450 424 3300
Toll-free: (+1) 800 775 6786
Fax: (+1) 450 424 3345
detection@excelitas.com
GmbH & Co. KG
Wenzel-Jaksch-Str. 31
D-65199 Wiesbaden
Germany
Telephone: (+49) 611 492 430
Fax: (+49) 611 492 165
detection.europe@excelitas.com
Excelitas Technologies Singapore, Pte. Ltd.
8 Tractor Road
Singapore 627969
Telephone: (+65) 6775 2022 (Main number)
Telephone: (+65) 6770 4366 (Customer Service)
Fax: (+65) 6778-1752
detection.asia@excelitas.com
For a complete listing of our global offices, visit www.excelitas.com/locations
© 2013 Excelitas Technologies Corp. All rights reserved. The Excelitas logo and design are registered trademarks of Excelitas Technologies Corp. All other trademarks not owned by Excelitas Technologies or its subsidiaries that are
depicted herein are the property of their respective owners. Excelitas reserves the right to change this document at any time without notice and disclaims liability for editorial, pictorial or typographical errors.
www.excelitas.com
Page 6 of 6
很抱歉,暂时无法提供与“DPGEW1S09H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+105.921411+13.70377
