PLT5510
PLT5510
    AMSOSRAM(艾迈斯半导体)
    DIP
    METALCANTO56
PLT5510 数据手册
Green Laser Diode in TO56 Package Version 1.1 PLT5 510 Features • Optical output power (continuous wave): 10 mW (Tcase = 25 °C) • Typical emission wavelength: 515 nm • Efficient radiation source for cw and pulsed operation • Single transverse mode semiconductor laser • High modulation bandwidth • TO56 package with photo diode Applications Laser projection Laser shows Presenter Biomedical Applications Metrology • • • • • Safety Advice Depending on the mode of operation, these devices emit highly concentrated visible light which can be hazardous to the human eye. Products which incorporate these devices have to follow the safety precautions found in IEC 60825-1 “Safety of laser products”. ATTENTION – Observe Precautions For Handling – Electrostatic Sensitive Device 04.04.2016 1 Version 1.1 PLT5 510 Ordering Information Type: Optical Output Power Ordering Code Popt (Tcase = 25°C) PLT5 510_B1-3 10 mW Q65111A6310 Maximum Ratings Operation outside these conditions may damage the device. Operation at the maximum ratings influences lifetime. Parameter Symbol Values Unit min. max. Operating Current IF 120 mA Operating Temperature Tcase -20 +60 °C Storage Temperature Tstg -40 +85 °C Reverse Voltage VR 2 V Soldering Temperature max. 10 sec. Tsolder 260 °C Junction temperature Tj 120 °C Laser Characteristics (Tcase = 25 °C) Parameter Emission Wavelength 1) Symbol λpeak B1 B2 B3 Values Unit min. typ. max. 510 515 520 – – – 515 520 530 nm – nm Spectral Width (FWHM) 1) Δλ – 2 Threshold Current Ith – 30 60 mA Operating Current 1) IF – 60 100 mA Operating Voltage 1) VF Beam Divergence (FWHM) 1) θ∥ x θ⊥ Polarization 1) Modulation Frequency – 5.4 7.0 V 5x 19 6.6 x 21.4 9x 25 deg Pgr – 100:1 – f – >100 – Thermal resistance (junction to case) Rth – 34 – K/W Monitor current 1) 2) Im – 150 – µA 1) 2) Standard operating conditions refer to a continuous wave output power of Popt = 10 mW. Photo current refers to a reverse voltage of VR = 5 V. 04.04.2016 2 MHz Version 1.1 PLT5 510 Optical Output Power Popt = ƒ (IF) Operating Voltage VF = ƒ (IF) 14 Tcase = 0 °C Tcase = 0 °C 6 12 Tcase = 20 °C Tcase = 20 °C 10 VF [V] Popt [mW] Tcase = 40 °C 8 Tcase = 40 °C 6 4 Tcase = 60 °C Tcase = 60 °C 2 4 2 0 0 20 40 60 80 0 100 0 20 40 IF [mA] 60 80 100 IF [mA] Spectra (B2) Popt = ƒ (λ) Threshold Current Ith = ƒ (Tcase) 45 Tcase = 40 °C 1.0 Tcase = 60 °C 40 0.8 Popt [a. u.] Tcase = 20 °C Ith [mA] 35 30 0.6 0.4 25 20 0.2 0 20 40 0.0 514 60 Tcase [°C] 04.04.2016 516 518  [nm] 3 520 522 Version 1.1 PLT5 510 Beam Divergence Popt = ƒ (θ), Tcase = 25 °C 1.0 0.8 Popt [a. u.]  || 0.6 ⊥ 0.4 0.2 0.0 -40 -20 0 20 40  [deg] 04.04.2016 4 Version 1.1 PLT5 510 Package Outline Dimensions in mm Pin Connection 3 1 LD PD Pin 1: LD Cathode Pin 2: LD Anode, PD Cathode (case) Pin 3: PD Anode 2 04.04.2016 5 Version 1.1 PLT5 510 Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e. g. decide at its sole discretion to stop developing and/or finalizing the underlying design at any time. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. Important notes of operation for laser diode a) Electrical operation OSRAMs laser diodes are designed for maximum performance and reliability. Operating the laser diode above the maximum rating even for very short periods of time can damage the laser diode or reduce its lifetime. The laser diode must be operated with a suitable power supply with minimized electrical noise. The laser diode is very sensitive to electrostatic discharge (ESD). Proper precautions must be taken. b) Mounting instructions In order to maintain the lifetime of the laser diode proper heat management is essential. Due to the design of the laser diode heat is dissipated only through the base plate of the diode‘s body. A proper heat conducting interconnection between the diodes base plate and the heat sink must be maintained. 04.04.2016 6 Version 1.1 PLT5 510 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 04.04.2016 Eu RoHS compliant product 7
PLT5510 价格&库存
很抱歉,暂时无法提供与“PLT5510”相匹配的价格&库存,您可以联系我们找货
