SFH4715
SFH4715
    AMSOSRAM(艾迈斯半导体)
    SMD3
    EMITTERIR860NM1ASMD
SFH4715 数据手册
2016-01-29 OSLON Black Series (850 nm) - 90° Version 1.5 SFH 4715 Features: • IR lightsource with high efficiency • Low thermal resistance (Max. 11 K/W) • Centroid wavelength 850 nm • Superior Corrosion Robustness (see chapter package outlines) • The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification for Automotive Grade Discrete Semiconductors. Applications • Infrared Illumination for cameras • Surveillance systems • Machine vision systems • Eye tracking systems Notes Depending on the mode of operation, these devices emit highly concentrated non visible infrared light which can be hazardous to the human eye. Products which incorporate these devices have to follow the safety precautions given in IEC 60825-1 and IEC 62471. Ordering Information Type: Radiant Intensity Ordering Code Ie [mW/sr] IF=1 A, tp=10 ms SFH 4715 Note: 270 (≥ 160) Q65111A2364 measured at a solid angle of Ω = 0.01 sr 2016-01-29 1 Version 1.5 SFH 4715 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Operation and storage temperature range Top; Tstg -40 ... 125 °C Junction temperature Tj 145 °C Reverse voltage VR 1 V Forward current IF 1000 Surge current (tp = 500 µs, D = 0) IFSM 5 A Power consumption Ptot 1.8 W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2 kV Thermal resistance junction - solder point RthJS 11 K/W Note: Unit mA For the forward current and power consumption please see "maximum permissible forward current" diagram Characteristics (TA = 25 °C) Parameter Symbol Values Unit Peak wavelength (IF = 1 A, tp = 10 ms) (typ) λpeak 860 nm Centroid wavelength (IF = 1 A, tp = 10 ms) (typ) λcentroid 850 nm Spectral bandwidth at 50% of Imax (IF = 1 A, tp = 10 ms) (typ) ∆λ 30 nm Half angle (typ) ϕ ± 45 ° Dimensions of active chip area (typ) LxW 1x1 mm x mm Rise and fall times of Ie ( 10% and 90% of Ie max) (IF = 5 A, RL = 50 Ω) (typ) tr / tf 7/14 ns Forward voltage (IF = 1 A, tp = 100 µs) (typ (max)) VF 1.5 (≤ 1.8) V Forward voltage (IF = 5 A, tp = 100 µs) (typ (max)) VF 2 (≤ 2.9) V Total radiant flux (IF = 1A, tp = 100 µs) (typ) 2016-01-29 2 Φe 630 mW Version 1.5 SFH 4715 Parameter Symbol Values Unit Temperature coefficient of Ie or Φe (IF = 1 A, tp = 10 ms) (typ) TCI -0.3 %/K Temperature coefficient of VF (IF = 1 A, tp = 10 ms) (typ) TCV -1 mV / K Temperature coefficient of wavelength (IF = 1 A, tp = 10 ms) (typ) TCλ 0.3 nm / K Grouping (TA = 25 °C) Group Min Radiant Intensity Max Radiant Intensity IF=1 A, tp=10 ms IF=1 A, tp=10 ms Ie, min [mW / sr] Ie, max [mW / sr] SFH4715 - BA 160 250 SFH4715 - BB 200 320 SFH4715 - CA 250 400 SFH4715 - CB 320 500 Note: measured at a solid angle of Ω = 0.01 sr Only one group in one packing unit (variation lower 1.6:1). 2016-01-29 3 Version 1.5 SFH 4715 Relative Spectral Emission 1) page 13 Irel = f (λ), TA = 25 °C, IF =1A, tp = 10 ms Relative Total Radiant Flux 1) page 13 Φe/Φe(1A) = f (IF), TA = 25 °C, Single pulse, tp = 100 μs OHF04132 100 OHF03848 101 I rel % Φe Φe (1 A) 80 100 5 60 10-1 40 5 10-2 20 5 0 700 750 800 nm 950 850 10-3 -2 10 λ IF 5 10 0 A 10 1 IF Forward Current 1) page 13 IF = f(VF), single pulse, tp = 100 µs, TA= 25°C Max. Permissible Forward Current IF = f (TS), RthJS = 11 K/W OHF04369 1.1 A 5 10 -1 IF OHF03847 10 1 A 0.9 0.8 10 0 0.7 0.6 0.5 0.4 10 -1 0.3 0.2 0.1 0 0 20 40 60 80 10 -2 100 ˚C 130 2016-01-29 0 0.5 1 1.5 2 V 2.5 VF TS 4 Version 1.5 SFH 4715 Permissible Pulse Handling Capability IF = f (tp), TS = 85 °C, Duty cycle D = parameter IF OHF05031 5.5 A t tP IF D = TP T 4.5 4.0 D= 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp Radiation Characteristics 1) page 13 Irel = f(ϕ), TA= 25°C 40˚ 30˚ 20˚ 10˚ ϕ 0˚ OHL04470 1.0 50˚ 0.8 60˚ 0.6 70˚ 0.4 80˚ 0.2 0 90˚ 100˚ 2016-01-29 1.0 0.8 0.6 0.4 0˚ 5 20˚ 40˚ 60˚ 80˚ 100˚ 120˚ Version 1.5 SFH 4715 Package Outline Dimensions in mm [inch]. Package OSLON Black Series Approximate Weight: 32 mg Note: IRED is protected by ESD device which is connected in parallel to chip. Note: Package is not suitable for ultra sonic cleaning. Note: Corrosion robustness better than EN 60068-2-60 (method 4): with enhanced corrosion test: 40°C / 90%rh / 15ppm H2S / 336h Note: Anode mark: Anode pad has chamfered edge, which points to cathode 2016-01-29 6 Version 1.5 SFH 4715 Recommended Solder Pad Dimensions in mm [inch]. Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. 2016-01-29 7 Version 1.5 SFH 4715 Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 50 0 100 150 200 250 s 300 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2016-01-29 °C 8 s Version 1.5 SFH 4715 Taping Dimensions in mm [inch]. Tape and Reel 12 mm tape with 600 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 2016-01-29 9 Version 1.5 SFH 4715 Tape dimensions [mm] Tape dim ensions in m m W P0 12 + 0.3 / - 0.1 4 ± 0.1 P1 P2 D0 E F 4 ± 0.1 or 8 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 Reel dimensions [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 12 60 12.4 + 2 18.4 Barcode-Product-Label (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Moisture-sensitive label or print L VE el LE . see lab e If ve ati nk, bla cod bar y H) (R . dit mi hu e ed ag RH % /60 Barcode label ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < urs ). urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 wi nt tim e or l wi fac ˚C Flo tim at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W no un DE Ho Af Ind 1. d e 4 8 uir ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP s at t M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. 2016-01-29 10 Version 1.5 SFH 4715 Transportation Packing and Materials Barcode label D/ 8 Y M DE R 18 -1 P -1 + Q C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : TY : 20 (Q )Q : NO M RA OS (X ) PR O D 5 14 2 110 0 Packing Sealing label Dimensions of transportation box in mm Width Length Height 195 ± 5 195 ± 5 30 ± 5 2016-01-29 OD PR ) (X (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 00 C: 01 44 Muster O ct pto o rs u M (9 D) d A n o : 34 ic S R NO O BA TC H 3G H (1 T) LO T NO (6 P) S 8 12 2199 : 12 em 2100 01 44 el OU P: L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is en ing be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed is re qu ty 2. JE bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 11 OHA02044 Version 1.5 SFH 4715 Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-29 12 Version 1.5 SFH 4715 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-29 13 Version 1.5 SFH 4715 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-29 14
SFH4715
物料型号:SFH 4715
器件简介: - 高效率红外光源 - 低热阻(最大11 K/W) - 中心波长850纳米 - 优越的耐腐蚀性
引脚分配:文档中未明确列出引脚分配,但提到了阳极和阴极标记。
参数特性: - 操作和存储温度范围:-40°C至125°C - 结温:145°C - 反向电压:1V - 正向电流:1000mA - 浪涌电流:5A(500秒,D=0) - 功耗:1.8W - ESD耐压:2kV - 热阻结点到焊接点:11 K/W
功能详解: - 红外照明适用于摄像头 - 监控系统 - 机器视觉系统 - 眼动追踪系统
应用信息: - 根据操作模式,这些设备可能会发出高度集中的不可见红外光,对眼睛有害。包含这些设备的产品设计必须遵循IEC 60825-1和IEC 62471中的安全预防措施。
封装信息: - 封装轮廓图提供了尺寸信息,包括阳极和阴极的位置。 - 封装不适合超声波清洗。 - 重量大约为32毫克。
SFH4715 价格&库存
很抱歉,暂时无法提供与“SFH4715”相匹配的价格&库存,您可以联系我们找货
