Tight Tolerance Ultraviolet LED Lamp
TZ Series (T1¾, 5mm Round / 15° & 30°)
UV5TZ-XXX-XX
RoHS Compliant
Low Power Consumption
Low Current Requirement
High Efficiency
Tight Tolerance of Wavelengths
Equipped with a Protective Zener Diode Built-in
Bivar UV5TZ-XXX-XX Tight Tolerance Ultraviolet (UV) LEDs have peak wavelengths in the highly desirable
ranges from 385 to 405nm with a tight tolerance of +/-2.5nm. These UV LEDs also have a built-in Zener Diode providing protective circuit against electrostatic discharge (ESD).
Applications: Industrial curing, fluorescence disclosing and verification, air purification, medical and biomedical applications, dermatological equipment, and hazardous materials detection.
Part Number
Chip Material
Emitted Color
Peak Wavelength
UV5TZ-385-15
385nm
UV5TZ-390-15
390nm
UV5TZ-395-15
InGaN/Sapphire
Purple
395nm
UV5TZ-400-15
400nm
UV5TZ-405-15
405nm
UV5TZ-385-30
385nm
UV5TZ-390-30
UV5TZ-395-30
Lens Color
Viewing Angle
Water Clear
15°
Water Clear
30°
390nm
InGaN/Sapphire
Purple
395nm
UV5TZ-400-30
400nm
UV5TZ-405-30
405nm
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
• This UV (ultraviolet) LED during operation radiates intense UV light.
• Do not look directly into the UV light during operation of device. This can be harmful to human body especially to the eyes and
skin, even for brief period due to the intense UV light.
• If viewing the UV light is necessary, please use UV filtered glasses to avoid damage by the UV light.
• If the UV LED in your product might be viewed directly, please affix a caution label to your product to that effect.
Avoid direct eye and skin exposure to UV light. Keep out of reach of children.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision D 10/15
Page 1 of 4
UV5TZ-XXX-XX
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
120 mW
Forward Current ( DC )
20 mA
Peak Forward Current 1
100 mA
Electrostatic Discharge ( Class1 )
2000 V
Reverse Voltage
—V
Operating Temperature Range
-25 ~ +80°C
Storage Temperature Range
-30 ~ +80°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current
(mA)
MIN TYP MAX MIN TYP MAX
MAX
Peak Wavelength
λp (nm)2
Emitting
Power (mW)
MIN
MIN
TYP3
TYP
MAX
UV5TZ-385-15
3.2
3.4
3.6
382.5 385.0 387.5
10
UV5TZ-390-15
3.2
3.4
3.6
387.5 390.0 392.5
UV5TZ-395-15
3.1
3.3
3.5
392.5 395.0 397.5
UV5TZ-400-15
3.1
3.3
3.5
397.5 400.0 402.5
UV5TZ-405-15
3.1
3.3
3.5
402.5 405.0 407.5
UV5TZ-385-30
3.2
3.4
3.6
382.5 385.0 387.5
10
UV5TZ-390-30
3.2
3.4
3.6
387.5 390.0 392.5
UV5TZ-395-30
3.1
3.3
3.5
392.5 395.0 397.5
UV5TZ-400-30
3.1
3.3
3.5
397.5 400.0 402.5
UV5TZ-405-30
3.1
3.3
3.5
402.5 405.0 407.5
10
10
Notes: 1. Tolerance of forward voltage : ±0.05V.
15
15
100
2. Tolerance of peak wavelength : ±1.0nm.
50% Power
Angle (deg)
TYP
15
30
3. Tolerance of emitting power (Typ) : ±15%.
Directivity Radiation — Relative Luminous Intensity vs. Radiation Angle
(15° Viewing Angle)
(30° Viewing Angle)
Revision D 10/15
Page 2 of 4
UV5TZ-XXX-XX
Typical Electrical / Optical Characteristics Curves
Revision D 10/15
Page 3 of 4
UV5TZ-XXX-XX
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Profile Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note:
1. All top preheat stages are to be turned off so that the lamp body is not directly exposed to the heat source.
2. Profile taken on the LED lead at the bottom of the PCB.
Packaging and labeling plan
Antistatic poly bag with desiccant
(500 pieces max per bag)
Revision D 10/15
Page 4 of 4
很抱歉,暂时无法提供与“UV5TZ-405-30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.34447
- 2+16.99678
- 10+14.07415
- 40+12.30141
- 100+11.24734
- 200+10.51668
- 500+9.71416
- 1000+9.06735
- 1500+8.74394
- 2000+8.49240
