SST-10-UV-A130-F405-00
    LUMINUS(朗明纳斯)
    SMD2_EP
SST-10-UV-A130-F405-00 数据手册
SST-10-UV Product Datasheet SST-10-UV Surface Mount LED Features Table of Contents • High Power UV LED with peak wavelengths 365 nm, 385 nm, 395 nm, 405 nm and 415 nm Ordering Information. . . . . . . .. . . . . . . . 2 • Industry standard 3.5 mm x 3.5 mm package Binning Structure. . . . . . . . . . . . . . . . . . . 3 • 130° viewing angle Absolute Maximum Ratings . . . . . . . . . 4 • Low Thermal Resistance : 1.4 °C/W Device Characteristics . . . . . . . . . . . . . . 5 • Built-in ESD Protection Angular Distribution and Typical Spectrum. . . . . . . . .. . . . . . . . . . . . . . . . . 8 • Environmentally friendly: REACH, RoHS and Halogen compliant Soldering Profile. . . . . . .. . . . . . . . . . . . . 9 Mechanical Dimensions. . . . . . .. . . . 10 Tape and Reel Outline . .. . . . . . . . . . 12 Shipping Label . .. . . . . . . . . . . . . . . . 13 Applications • Curing- inks, coating and adhesives • Photocatalytic air/water purification Notes . .. . . . . . . . . . . . . . . . . . . . . . . . 14 • Fluorescence Imaging Revision History . . . . . . . . . . .. . . . . . . 15 • Antimicrobial surface disinfection • Medical and Analytic instrumentation • Diagnostics PDS-002674 Rev 05 Improving Life with Photons www.luminus.com SST-10-UV Product Datasheet Ordering Information Ordering Part Numbers1 Color Wavelength Range (nm) Luminous Flux Min. Flux Bin Min. Flux F 810 mW Wavelength Bins 365-375 365, 370 G 900 mW G 900 mW 380-390 380, 385 H 990 mW G 900 mW UV 390-400 390, 395 H 990 mW 400-410 G 900 mW 400, 405 410-420 G 900 mW 410, 415 Solder Pad Ordering Part Number A SST-10-UV-A130-F365-00 B SST-10-UV-B130-F365-00 A SST-10-UV-A130-G365-00 B SST-10-UV-B130-G365-00 A SST-10-UV-A130-G385-00 B SST-10-UV-B130-G385-00 A SST-10-UV-A130-H385-00 B SST-10-UV-B130-H385-00 A SST-10-UV-A130-G395-00 B SST-10-UV-B130-G395-00 A SST-10-UV-A130-H395-00 B SST-10-UV-B130-H395-00 A SST-10-UV-A130-G405-00 B SST-10-UV-B130-G405-00 A SST-10-UV-A130-G415-00 B SST-10-UV-B130-G415-00 Part Number Nomenclature SST Product Family 10 Chip Area UV Color X130 Package Configuration1 A130: "A" solder pad layout SST: Surface Mount package 10: 1 mm2 UV: Ultraviolet and 130° lens B130: "B" solder pad layout and 130° lens Bin Kit2,3 Refer to ordering part numbers in this document Note: 1. Refer to drawings on page 10 & 11 for details on "A" and "B" solder pad layouts. 2. A Bin Kit represents a group of flux and wavelength bins that are shippable for a given ordering part number. Individual bins are not orderable. 3. Flux Bin listed is minimum bin shipped - higher bins may be included at Luminus’ discretion. PDS-002674 Rev 05 2 www.luminus.com SST-10-UV Product Datasheet Binning Structure SST-10-UV LEDs are specified for flux peak wavelength and voltage at a drive current of 500 mA with a 20 ms pulse at 25°C and placed into one of the following Flux, Peak Wavelength and Forward Voltage Bins. Flux Bins Color UV Power Flux Bin (F) Minimum Flux (mW) Maximum Flux (mW) F 810 900 G 900 990 H 990 1080 I 1080 1170 J 1170 1260 K 1260 1350 Wavelength Bin (WWW) Minimum Wavelength (nm) Maximum Wavelength (nm) 365 365 370 370 370 375 380 380 385 385 385 390 390 390 395 395 395 400 400 400 405 405 405 410 410 410 415 415 415 420 Voltage Bin Minimum Voltage (V) Maximum Voltage (V) V0 2.8 3.0 V1 3.0 3.2 V2 3.2 3.4 V3 3.4 3.6 V4 3.6 3.8 V5 3.8 4.0 Peak Wavelength Bins Color UV Forward Voltage Bins Color UV Note: 1. Luminus maintains a +/- 6% tolerance on flux measurements. PDS-002674 Rev 05 3 www.luminus.com SST-10-UV Product Datasheet Absolute Maximum Ratings Symbol Values If 365 1 If 385-415 1.5 Ts min -40 Ts max 100 Junction Temperature Tj max 100 °C ESD sensitivity ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD 6000 V Absolute Maximum Forward Current (CW) Storage Temperature Unit A °C Note: 1. For reference only. 2. SST-10-UV LEDs are designed for operation to an absolute maximum current as specified above. Product lifetime data is specified at or below maximum drive current. Sustained operation beyond absolute maximum currents will result in a reduction of device life time . Actual device lifetimes will also depend on junction temperature and operation beyond maximum junction temperature is not recommended. Contact Luminus for lifetime derating curves and for further information. In pulsed operation, rise time from 10-90% of forward current should be longer than 0.5 μseconds. PDS-002674 Rev 05 4 www.luminus.com SST-10-UV Product Datasheet Device Characteristics1 Optical and Electrical Characteristics Symbol Value Unit Emitting Area AE 1.0 mm2 Test Drive Current If 500 mA 2Φ1/2 130 degree Viewing Angle Peak Wavelength Range λ 365-375 380-390 390-400 400-410 410-415 nm Peak Wavelength (Typ) λp 370 385 395 405 415 nm Vf min 3.0 3.0 3.0 3.0 2.9 Vf 3.7 3.4 3.3 3.3 3.2 Vf max 4.0 4.0 4.0 4.0 3.3 ΦE 875 1015 1015 930 930 W ∆λ1/2 10 10 10 10 10 nm Forward Voltage Peak Radiometric Flux 2 FWHM- Spectral bandwidth at 50% of ΦV V Note: 1. While SST-10-UV devices are tested at 500 mA, they can be driven at CW currents ranging from 200 mA to 1.5 A and at duty cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to meet application lifetime requirements.. 2. Typical radiometric flux is for reference only. Minimum flux values are guaranteed based on the bin kit ordered. For product roadmap and future performance of devices, contact Luminus. PDS-002674 Rev 05 5 www.luminus.com SST-10-UV Product Datasheet Relative Radiometric Flux - 365 nm/385 nm/395 nm/405 nm Forward current: φv/φv(500 mA), Tc = 25°C Temperature: φv/φv(25°C), If = 500 mA 300% 110% Relative Radiometric Flux Relative Radiometric Flux 365nm 105% 250% 385/395nm 405nm 100% 200% 150% 100% 365nm 50% 95% 90% 85% 80% 75% 385/395/405nm 70% 0% 0 0.2 0.4 0.6 0.8 1 1.2 1.4 0 10 20 30 40 50 60 70 80 90 100 Tc (°C) If (A) Forward Voltage - 365 nm/385 nm/395 nm/405 nm Forward current: Vf = V(If), Tc = 25°C Temperature: ΔVf = V(Tc) - V(25°C), If = 500 mA 4.2 0.4 365nm 385/395/405nm Forward Voltage (Vf) Forward Voltage (Vf) 4 3.8 3.6 3.4 365nm 3.2 0.2 0 -0.2 385nm 395/405nm 3 0 0.2 0.4 0.6 0.8 1 1.2 -0.4 1.4 0 10 20 30 40 50 60 70 80 90 100 Tc (°C) If (A) Peak Wavelength Shift - 365 nm/385 nm/395 nm/405 nm Forward current: Δλp= λp(If) - λp(500 mA), Tc = 25°C Temperature: Δλp= λp(Tc) - λp(25°C), If = 500 mA 4.5 5.0 4.0 365/385/395nm 3.0 Δ Peak Wavelength (λp) Δ Peak Wavelength (λp) 405nm 1.5 0.0 -1.5 -3.0 3.0 2.0 1.0 0.0 365/385/395nm -1.0 0 0.2 0.4 0.6 0.8 1 1.2 -2.0 1.4 If (A) PDS-002674 Rev 05 405nm 0 10 20 30 40 50 60 70 80 90 100 Tc (°C) 6 www.luminus.com SST-10-UV Product Datasheet Relative Radiometric Flux - 415 nm Forward current: φv/φv(500 mA), Tc = 25°C Temperature: φv/φv(25°C), If = 500 mA Relative Radiometric Power 300% 250% 200% 150% 100% 50% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 If (A) Forward Voltage - 415 nm Forward current: Vf = V(If), Tc = 25°C Temperature: ΔVf = V(Tc) - V(25°C), If = 500 mA 0.40 Δ Forward Voltage (Vf) 0.30 0.20 0.10 0.00 -0.10 -0.20 -0.30 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 If (A) Peak Wavelength Shift - 415 nm Forward current: Δλp= λp(If) - λp(500 mA), Tc = 25°C Temperature: Δλp= λp(Tc) - λp(25°C), If = 500 mA 0.6 Δ Peak Wavelength (λp) 0.4 0.2 0.0 -0.2 -0.4 -0.6 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 If (A) PDS-002674 Rev 05 7 www.luminus.com SST-10-UV Product Datasheet Angular Distribution and Typical Spectrum Angular Intensity Distribution Iref = f(Φ); Tc = 25°C Typical Spectrum Φref = f(λ); If = 500 mA; Tc = 25°C 1.0 365 nm 385 nm 395 nm 405 nm Relative Intensity 0.8 415 nm 0.6 0.4 0.2 0.0 300 320 340 360 380 400 420 440 460 480 500 Wavelength (nm) PDS-002674 Rev 05 8 www.luminus.com SST-10-UV Product Datasheet Soldering Profile Peak Temperature (235 - 245°C) Temperature Liquidus Temperature, TL (SAC305 = 220°C) Time Above Liquidus (45 - 90 sec) 65 -> 200°C, 120 - 250 sec max Preheat RT to 150°C 1 - 2.5°C/sec Soak 150°C to 180°C 0.4 - 1°C/sec Reflow 180 to TL + 20°C 3 - 6°C/sec Cool down Peak to below 150°C 3 - 7°C/sec Time SMT Rework Guideline Manual Hotplate Reflow Heating Time Hotplate Temperature Hot Air Gun Reflow < 60 sec < 245°C < 150°C Note: 1. Product complies to Moisture Sensitivity Level 1 (MSL 1). 2. The numbers in the table are specific to SAC305. Luminus recommends using an SAC305 solder paste with a no-clean flux for RoHS compliant products. 3. During the pick and place process, axial forces on the dome (or window) should not exceed 0.5 Newtons (N). 4. Use of a multi-zone IR reflow oven with a nitrogen blanket is recommended. 5. Time-temperature profile of the reflow process showing the four functional profile zones are defined in IPC-7801. Temperature is referenced to the center of the PCB. 6. Luminus recommends to use the solder paste data sheet information as a starting point in time-temperature process development. 7. These are general guidelines. Consult the solder paste manufacturer’s datasheet for guidelines specific to the alloy and flux combination used in your application. For more information, please refer to: https://luminusdevices.zendesk.com/hc/en-us/articles/360060306692-How-do-I-Reflow-Solder-Luminus-SMD-Components8. For any technical questions about soldering process, please contact Luminus at techsupport@luminus.com. PDS-002674 Rev 05 9 www.luminus.com SST-10-UV Product Datasheet Mechanical Dimensions - A130 package 8 5 6 7 4 2 3 1 REVISIONS ECO REV. DESCRIPTION DATE A 3.45 APPROVED 05/20/2022 1.98±0.10 D THERMAL PAD (NEUTRAL) CATHODE D ANODE 1.30 3.45 C C R1.30 0.68 ANODE OPTICAL REFERENCE FRONT VIEW 8 5 6 7 SIDE VIEW 4 BACK VIEW 3 2 1 B B D 3.25 1145 SONORA COURT SUNNYVALE, CA 94086 408-708-7000 PROPRIETARY AND CONFIDENTIAL This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. 0.50 A 3.25 C UNLESS OTHERWISE SPECIFIED TOLERANCES ARE ANGLES 0.5 1.15 SURFACES 3.25 2.30 X = 0.5mm 0.8 MICRONS .X = 0.127mm .XX = 0.050mm .XXX = 0.010mm 1.30 6 7 8 DESCRIPTION: B MILLIMETERS [INCHES] DRAFTER: 1 OF 2 NONE SHEET: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: SCALE: NUMBER: ENGINEER: A REV: A DWG- X.XIE 4 5 0.58 DRAWING,OUTLINE,SST-08-UV-A130 2 3 1 0.48 0.48 0.25 3.25 B 0.75 Recommended PCB Solder Pad Recommended Stencil Pattern PROPRIETARY AND CONFIDENTIAL This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A DESCRIPTION: DRAWING, OUTLINE,SST-08-UV-A130 DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: ALL MEASUREMENTS AER 0.13mm UNLESS OTHERWISE SPECIFIED TOLERANCES ARE MILLIMETERS [INCHES] DRAFTER: NUMBER: ENGINEER: PDS-002674 Rev 05 7 6 5 10 4 3 SHEET: SCALE: 2 OF 2 25:1 DWG- X.XIE 8 B 2 www.luminus.com 1 REV: A SST-10-UV Product Datasheet Mechanical Dimensions - B130 package 8 5 6 7 4 2 3 1 REVISIONS ECO REV. DESCRIPTION DATE A 1.98±0.10 APPROVED 05/20/2022 3.45 D THERMAL PAD (NEUTRAL) CATHODE D ANODE 1.30 3.45 2.70 C C R1.30 1.70 2.70 8 B 1.00 OPTICAL REFERENCE ANODE FRONT VIEW SIDE VIEW 5 6 7 4 BACK VIEW2 3 1 B D D 2.70 This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A 0.35 UNLESS OTHERWISE SPECIFIED TOLERANCES ARE ANGLES 0.5 2.70 1.70 0.90 SURFACES X = 0.5mm 0.8 MICRONS .X = 0.127mm .XX = 0.050mm .XXX = 0.010mm 2.70 C 6 7 8 2.70 PROPRIETARY AND CONFIDENTIAL DESCRIPTION: A DRAWING,OUTLINE,SST-08-UV-B130 0.40 SHEET: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: B MILLIMETERS [INCHES] DRAFTER: SCALE: NUMBER: ENGINEER: 1 OF 2 NONE REV: A DWG- X.XIE 4 5 1145 SONORA COURT SUNNYVALE, CA 94086 408-708-7000 2 3 C 1 0.50 0.50 0.25 0.55 Recommended Stencil Pattern Recommended PCB Solder Pad B B PROPRIETARY AND CONFIDENTIAL This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A DESCRIPTION: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: ALL MEASUREMENTS AER 0.13mm UNLESS OTHERWISE SPECIFIED TOLERANCES ARE MILLIMETERS [INCHES] DRAFTER: PDS-002674 Rev 05 7 6 4 5 11 3 B NUMBER: ENGINEER: REV: SHEET: SCALE: A 25:1 DWG- X.XIE 8 A DRAWING,OUTLINE,SST-08-UV-B130 2 1 www.luminus.com SST-10-UV Product Datasheet Tape and Reel Outline  “  “  “  “  “  “         $ &$7+2'(6,'( %                   %  “  “  “  “  “  “ “ “                    $12'(6,'( “ $          ƒ 6(&7,21%% ƒ 6(&7,21$$ 127(6   ),1$/7$3($1'5((/3$&.$*,1*08670((77+( 5(48,5(0(1762)-('(&67'/(9(/$       /($9(PP>LQ@2)7$3((037
SST-10-UV-A130-F405-00 价格&库存
很抱歉,暂时无法提供与“SST-10-UV-A130-F405-00”相匹配的价格&库存,您可以联系我们找货
