UV3TZ-400-15
UV3TZ-400-15
    BIVAR
    插件
    UV3TZ-400-15
UV3TZ-400-15 数据手册
Tight Tolerance Ultraviolet LED Lamp TZ Series (T1, 3mm Round / 15° & 30°) UV3TZ-XXX-XX ♦ ♦ ♦ ♦ ♦ ♦ RoHS Compliant Low Power Consumption Low Current Requirement High Efficiency Tight Tolerance of Wavelengths Equipped with a Protective Zener Diode Built-in Bivar UV3TZ-XXX-XX Tight Tolerance Ultraviolet (UV) LEDs have peak wavelengths in the highly desirable ranges from 385 to 405nm with a tight tolerance of +/-2.5nm. These UV LEDs also have a built-in Zener Diode providing protective circuit against electrostatic discharge (ESD). Applications: Industrial curing, fluorescence disclosing and verification, air purification, medical and biomedical applications, dermatological equipment, and hazardous materials detection. Part Number Chip Material Emitted Color Peak Wavelength UV3TZ-385-15 385nm UV3TZ-390-15 390nm UV3TZ-395-15 InGaN/Sapphire Purple 395nm UV3TZ-400-15 400nm UV3TZ-405-15 405nm UV3TZ-385-30 385nm UV3TZ-390-30 UV3TZ-395-30 Lens Color Viewing Angle Water Clear 15° Water Clear 30° 390nm InGaN/Sapphire Purple 395nm UV3TZ-400-30 400nm UV3TZ-405-30 405nm Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. • This UV (ultraviolet) LED during operation radiates intense UV light. • Do not look directly into the UV light during operation of device. This can be harmful to human body especially to the eyes and skin, even for brief period due to the intense UV light. • If viewing the UV light is necessary, please use UV filtered glasses to avoid damage by the UV light. • If the UV LED in your product might be viewed directly, please affix a caution label to your product to that effect. Avoid direct eye and skin exposure to UV light. Keep out of reach of children. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 10/15 Page 1 of 4 Tight Tolerance Ultraviolet LED Lamp UV3TZ-XXX-XX Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 120 mW Forward Current ( DC ) 20 mA Peak Forward Current 1 100 mA Electrostatic Discharge ( Class1 ) 2000 V Reverse Voltage —V Operating Temperature Range -25 ~ +80°C Storage Temperature Range -30 ~ +80°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (mA) MIN TYP MAX MIN TYP MAX MAX Peak Wavelength λp (nm)2 Emitting Power (mW) MIN MIN TYP3 TYP MAX UV3TZ-385-15 3.2 3.4 3.6 382.5 385.0 387.5 10 20 UV3TZ-390-15 3.2 3.4 3.6 387.5 390.0 392.5 10 20 UV3TZ-395-15 3.1 3.3 3.5 392.5 395.0 397.5 10 20 UV3TZ-400-15 3.1 3.3 3.5 397.5 400.0 402.5 10 20 UV3TZ-405-15 3.1 3.3 3.5 402.5 405.0 407.5 10 20 UV3TZ-385-30 3.2 3.4 3.6 382.5 385.0 387.5 10 20 UV3TZ-390-30 3.2 3.4 3.6 387.5 390.0 392.5 20 40 UV3TZ-395-30 3.1 3.3 3.5 392.5 395.0 397.5 20 40 UV3TZ-400-30 3.1 3.3 3.5 397.5 400.0 402.5 20 40 UV3TZ-405-30 3.1 3.3 3.5 402.5 405.0 407.5 20 40 10 10 Notes: 1. Tolerance of forward voltage : ±0.05V. 15 15 20 20 100 100 2. Tolerance of peak wavelength : ±1.0nm. 50% Power Angle (deg) TYP 15 30 3. Tolerance of emitting power (Typ) : ±15%. Directivity Radiation — Relative Luminous Intensity vs. Radiation Angle TA = 25°C unless otherwise noted (15° Viewing Angle) (30° Viewing Angle) Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 10/15 Page 2 of 4 Tight Tolerance Ultraviolet LED Lamp UV3TZ-XXX-XX Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 10/15 Page 3 of 4 Tight Tolerance Ultraviolet LED Lamp UV3TZ-XXX-XX Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Profile Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: 1. All top preheat stages are to be turned off so that the lamp body is not directly exposed to the heat source. 2. Profile taken on the LED lead at the bottom of the PCB. Packaging and labeling plan Antistatic poly bag with desiccant (500 pieces max per bag) Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 10/15 Page 4 of 4
UV3TZ-400-15 价格&库存
很抱歉,暂时无法提供与“UV3TZ-400-15”相匹配的价格&库存,您可以联系我们找货
UV3TZ-400-15
  • 1+27.523221+3.55950
  • 5+22.193335+2.87020
  • 20+19.3099420+2.49730
  • 100+15.81493100+2.04530
  • 200+14.41693200+1.86450
  • 500+13.80530500+1.78540
  • 1000+12.407291000+1.60460
  • 2000+11.708292000+1.51420
UV3TZ-400-15
  • 1+25.63292
  • 5+20.67403
  • 20+17.97898
  • 100+14.73294
  • 200+13.42734
  • 500+12.85239
  • 1000+11.55877
  • 2000+10.89998
