SFH4259S
SFH4259S
    AMSOSRAM(艾迈斯半导体)
    4-PLCC
    EMITTERIR860NM100MAPLCC
SFH4259S 数据手册
2016-01-31 High Power Infrared Emitter (850 nm) Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Features: • High Power Infrared LED • Double Stack emitter • Half angle: ± 25° • High forward current allowed at high temperature • The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification for Automotive Grade Discrete Semiconductors. Applications • Industrial applications • Infrared Illumination for cameras • IR data transmission • Sensor technology • Automotive technology Notes Depending on the mode of operation, these devices emit highly concentrated non visible infrared light which can be hazardous to the human eye. Products which incorporate these devices have to follow the safety precautions given in IEC 60825-1 and IEC 62471. Ordering Information Type: Radiant Intensity Ordering Code Ie [mW/sr] IF=100 mA, tp=20 ms SFH 4259S Note: 85 (≥ 40) Q65111A1159 Measured at a solid angle of Ω = 0.01 sr 2016-01-31 1 Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Maximum Ratings (TA = 25 °C) Parameter Symbol Values Operation and storage temperature range Top; Tstg -40 ... 100 °C Reverse voltage VR 5 V Forward current IF 100 mA Surge current (tp ≤ 300 µs, D = 0) IFSM 0.7 A Power consumption Ptot 245 mW ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2 Thermal resistance junction - ambient 1) page 12 RthJA 300 K/W Thermal resistance junction - soldering point RthJS 140 K/W 2) page 12 Unit kV Characteristics (TA = 25 °C) Parameter Symbol Values Unit Peak wavelength (IF = 100 mA, tp = 20 ms) (typ) λpeak 860 nm Centroid wavelength (IF = 100 mA, tp = 20 ms) (typ) λcentroid 850 nm Spectral bandwidth at 50% of Imax (IF = 100 mA, tp = 20 ms) (typ) ∆λ 30 nm Half angle (typ) ϕ ± 25 Dimensions of active chip area (typ) LxW Rise and fall time of Ie ( 10% and 90% of Ie max) (IF = 100 mA, RL = 50 Ω) (typ) tr, tf Forward voltage (IF = 100 mA, tp = 20 ms) Forward voltage (IF = 700 mA, tp = 100 µs) 2016-01-31 mm x mm 15 ns (typ (max)) VF 3.1 (≤ 3.6) V (typ (max)) VF 4 (≤ 5.2) V Reverse current (VR = 5 V) Total radiant flux (IF= 100 mA, tp=20 ms) 0.3 x 0.3 ° (typ) 2 IR not designed for reverse operation µA Φe 115 mW Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Parameter Symbol Values Unit Temperature coefficient of Ie or Φe (IF = 100 mA, tp = 20 ms) (typ) TCI -0.5 %/K Temperature coefficient of VF (IF = 100 mA, tp = 20 ms) (typ) TCV -2 mV / K Temperature coefficient of wavelength (IF = 100 mA, tp = 20 ms) (typ) TCλ 0.3 nm / K Grouping (TA = 25 °C) Group Min Radiant Intensity Max Radiant Intensity Typ Radiant Intensity IF=100 mA, tp=20 ms IF=100 mA, tp=20 ms IF = 700 mA, tp = 25 µs Ie, min [mW / sr] Ie, max [mW / sr] Ie, typ [mW / sr] SFH 4259S-U 40 80 315 SFH 4259S-V 63 125 495 SFH 4259S-AW 100 200 795 Note: measured at a solid angle of Ω = 0.01 sr Only one group in one packing unit (variation lower 2:1). Relative Spectral Emission 3) page 12 Irel = f(λ), TA = 25°C OHF04132 100 I rel Radiant Intensity 3) page 12 Ie / Ie(100 mA) = f(IF), single pulse, tp = 25 µs, TA= 25°C OHF05698 101 % Ιe Ι e (100 mA) 80 100 60 10-1 40 10-2 20 0 700 750 800 850 10-3 0 10 nm 950 λ 2016-01-31 101 102 mA 103 IF 3 Version 1.4 / acc. to OS-PCN-2015-025-A Forward Current 3) page 12 IF = f(VF), single pulse, tp = 100 µs, TA= 25°C Max. Permissible Forward Current IF, max = f(TA), RthJA = 300 K / W, RthJS = 140 K / W IF SFH 4259S OHF05696 120 mA IF OHF05562 103 mA 100 102 80 R thJA R thJS 60 101 40 20 0 0 20 40 60 100 80 ˚C 100 TA , TS IF 0.7 t 0.75 IF A tP IF T 0.4 0.3 0.2 D= 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 0.1 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp 2016-01-31 5 V OHF04491 t D = TP tP IF T 0.60 0.55 0.50 D= 0.45 0.005 0.01 0.40 0.02 0.35 0.05 0.30 0.1 0.2 0.25 0.5 0.20 1 0.15 0.10 0.05 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 0.6 0.5 4 Permissible Pulse Handling Capability IF = f(tp), T A = 85 °C, duty cycle D = parameter OHF05697 D = TP 3 VF Permissible Pulse Handling Capability IF = f(tp), TA = 25 °C, duty cycle D = parameter 0.8 A 2 tp 4 Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Radiation Characteristics 3) page 12 Irel = f(ϕ), TA= 25°C 40˚ 30˚ 20˚ 10˚ ϕ 0˚ OHL00999 1.0 50˚ 0.8 60˚ 0.6 70˚ 0.4 80˚ 0.2 0 90˚ 100˚ 1.0 0.8 0.6 0.4 0˚ 20˚ 40˚ 60˚ 80˚ 100˚ Package Outline 3.5 (0.138) max. 2.1 (0.083) 1.7 (0.067) 3.0 (0.118) 2.6 (0.102) 2.3 (0.091) 0.9 (0.035) 0.7 (0.028) 2.1 (0.083) 1.1 (0.043) 1 Package marking 0.18 (0.007) ø2.55 (0.100) ø2.60 (0.102) 0.1 (0.004) typ 0.5 (0.020) 3.7 (0.146) 3.3 (0.130) 3.4 (0.134) 3.0 (0.118) 2 4˚±1 4 (2.4) (0.095) 3 0.6 (0.024) 0.4 (0.016) 0.13 (0.005) GPLY6128 Dimensions in mm (inch). 2016-01-31 5 120˚ Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Pinning Pin Description 1 Cathode 2 Anode 3 Anode 4 Anode Package Power TOPLED with Lens Approximate Weight: 35 mg Recommended Solder Pad Reflow Soldering Padgeometrie für verbesserte Wärmeableitung Paddesign for improved heat dissipation 3.3 (0.130) 3.3 (0.130) 2.3 (0.091) 11.1 (0.437) 1.5 (0.059) 1.1 (0.043) 3.7 (0.146) 0.8 (0.031) 0.7 (0.028) Cu Fläche / , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W no un DE Ho Af Ind 1. d e 4 8 uir ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP s at t M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. 2016-01-31 9 Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Transportation Packing and Materials Barcode label D/ 8 Y M DE R 18 -1 P -1 + Q C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : TY : 20 (Q )Q : NO M RA OS (X ) PR O D 5 14 2 110 0 Packing Sealing label Dimensions of transportation box in mm Width Length Height 195 ± 5 195 ± 5 30 ± 5 2016-01-31 OD PR ) (X (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 00 C: 01 44 Muster O ct pto o rs u M (9 D) d A n o : 34 ic S R NO O BA TC H 3G H (1 T) LO T NO (6 P) S 8 12 2199 : 12 em 2100 01 44 el OU P: L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is en ing be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed is re qu ty 2. JE bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 10 OHA02044 Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-31 11 Version 1.4 / acc. to OS-PCN-2015-025-A SFH 4259S Glossary 1) Thermal resistance: junction -ambient, mounted on PC-board (FR4), padsize 16 mm2 each 2) Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g. metal block) 3) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-31 12 Version 1.4 / acc. to OS-PCN-2015-025-A Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-31 13 SFH 4259S
SFH4259S 价格&库存
很抱歉,暂时无法提供与“SFH4259S”相匹配的价格&库存,您可以联系我们找货
