ITEM
Q'TY
PART NUMBER
REV.
PART DESCRIPTION
1
1
C-174
T-1¾ (5mm) LED CLIP
2
1
R-174
T-1¾ (5mm) LED RING
B
C
DESCRIPTION
Engineering Update w/o Changes
Remove Material Code
Ø.350 [Ø8.9mm]
1
Ø.205 [Ø5.2mm]
Ø.300 [Ø7.6mm]
DATE
APPROVED
02/26/04
05/28/16
M. C.
J. C.
2
Ø.270 [Ø6.9mm]
0.260 [6.6mm]
0.04 [1.0mm]
4 Slots
0.175 [4.4mm]
LED Base Location
0.160 [4.1mm]
0.030 [0.8mm]
Panel Hole Size
0.270±0.003
0.125 [3.2mm]
0.032 [0.8mm]
Panel Thickness
Recommended Application
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-2, BLACK.
DESIGNED:
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
± .1
± .01
± .005
S. Irving
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
11/24/98
DATE:
05/17/02
T-1¾ LED CLIP AND RING SET
REVISION:
PART NO:
CR-174
CAGE CODE : 32559
C
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“CR-174”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.505341+0.32474
- 5+2.042655+0.26477
- 10+1.8944610+0.24556
- 25+1.7160025+0.22243
- 50+1.5991550+0.20728
- 100+1.49606100+0.19392
- 300+1.35462300+0.17559
- 500+1.29681500+0.16809
- 1000+1.225861000+0.15890
