CR-174L
CR-174L
    BIVAR
CR-174L 数据手册
ITEM Q'TY PART NUMBER REV. PART DESCRIPTION 1 1 C-174L T-1¾ (5mm) LED CLIP 2 1 R-174 T-1¾ (5mm) LED RING C D E F DESCRIPTION Engineering Update w/o Changes Corrected BOM, LED size from 3mm to 5mm Typo Correction Engineering Update w/o Changes Ø.350 [Ø8.9mm] 1 Ø.205 [Ø5.2mm] Ø.300 [Ø7.6mm] DATE APPROVED 02/26/04 02/05/14 11/05/14 05/28/16 M. C. J. C. J. C. J. C. 2 Ø.270 [Ø6.9mm] 0.355 [9.0mm] 0.04 [1.0mm] 4 Slots 0.313 [8.0mm] 0.160 [4.1mm] LED Base Location 0.030 [0.8mm] Panel Thickness Panel Hole Size 0.270±0.003 0.250 [6.4mm] 0.160 [4.0mm] Recommended Application STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6/6, 94V-2, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 11/24/98 DATE: 05/17/02 T-1¾ LED CLIP & RING SET REVISION: PART NO: CR-174L CAGE CODE : 32559 F SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
CR-174L 价格&库存
很抱歉,暂时无法提供与“CR-174L”相匹配的价格&库存,您可以联系我们找货
CR-174L
  • 1+4.610651+0.59890
  • 10+2.7663910+0.35934
  • 100+2.67940100+0.34804
库存:71
CR-174L
    • 1+2.782841+0.36148
    • 5+2.303045+0.29916
    • 10+2.1260510+0.27617
    • 25+1.9354125+0.25140
    • 50+1.8034150+0.23426
    • 100+1.68826100+0.21930
    • 300+1.53003300+0.19875
    • 500+1.46555500+0.19037
    • 1000+1.386151000+0.18006
    库存:22137
    CR-174L
    • 1+4.70735
    • 10+2.82801
    • 100+2.75015
    库存:71
