CR-300
CR-300
    BIVAR
CR-300 数据手册
REV. DESCRIPTION C D Engineering Update w/o Changes Remove Material Code DATE APPROVED 02/26/04 05/28/16 M. C. J. C. 0.200 [5.1mm] 0.146 [3.7mm] 0.324 [8.2mm] 0.270 [6.9mm] 0.268 [6.8mm] 0.368 [9.3mm] 0.370 [9.4mm] 0.151 [3.8mm] 0.246 [6.2mm] LED Slot Location (HP#: HLMP-T200,T300,T400&T500) 0.022 [0.6mm] Panel Thickness Panel Hole Size 0.312±.004 X .212±.004 0.188 [4.8mm] 0.062 [1.6mm] 0.01 [0.2mm] Recommended Application STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS K C A L B , 2 V 4 9 , 6 / 6 N O L Y N 2. MATERIAL: . 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 11/13/02 DATE: 11/13/02 PART NO: FAX: (949) 951-3974 CLIP & RING SET FOR RECTANGULAR LED REVISION: CR-300 CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
CR-300 价格&库存
很抱歉,暂时无法提供与“CR-300”相匹配的价格&库存,您可以联系我们找货
