ITEM
Q'TY
PART NUMBER
REV.
PART DESCRIPTION
1
1
C-175
T-1¾ (5mm) LED CLIP
2
1
R-175
T-1¾ (5mm) LED RING
C
D
1
Ø.205 [Ø5.2mm]
Ø.312 [Ø7.9mm]
DESCRIPTION
Engineering Update w/o Changes
Remove Material Code
DATE
APPROVED
02/26/04
05/28/16
M. C.
J. C.
2
Ø.365 [Ø9.3mm]
Ø.278 [Ø7.1mm]
.265 [6.7mm]
LED Base Location
0.160 [4.1mm]
0.165 [4.2mm]
0.025 [0.6mm]
Panel Hole Size
0.276+0.004
-0.002
0.125 [3.2mm]
0.040 [1.0mm]
Panel Thickness
Recommended Application
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-0, BLACK.
± .1
± .01
± .005
DESIGNED:
S. Irving
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
M. Chen
ANGULAR
X°
± 1°
DATE:
11/18/98
DATE:
01/09/02
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: CLIP & RING SET FOR SMALL
FLANGE T-1¾ (5mm) LED
REVISION:
PART NO:
CR-175
CAGE CODE : 32559
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“CR-175”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.004051+0.64975
- 10+2.9937310+0.38872
- 100+2.67173100+0.34691
- 1000+2.341031000+0.30397
- 国内价格 香港价格
- 6+151.515986+19.67360
- 10+116.5515310+15.13364
- 25+89.6547725+11.64123
- 50+65.7077250+8.53182
- 100+63.93206100+8.30126
- 250+63.07982250+8.19060
- 500+60.65354500+7.87556
- 1000+59.137121000+7.67866
- 国内价格
- 1+5.16252
- 10+3.06158
- 100+2.73218
- 1000+2.39440
- 国内价格 香港价格
- 1+2.509401+0.32584
- 5+2.045975+0.26566
- 10+1.8975410+0.24639
- 25+1.7187825+0.22318
- 50+1.6015450+0.20795
- 100+1.49828100+0.19455
- 300+1.35658300+0.17615
- 500+1.29868500+0.16863
- 1000+1.227621000+0.15940
