REV.
DESCRIPTION
A Engineering Update w/o Changes
B Removed Material Code
0.300 [7.6mm]
0.200 [5.1mm]
0.100 [2.5mm]
R.150 [R3.8mm]
DATE
APPROVED
02/26/04
05/28/16
M. C.
J. C.
0.374 [9.5mm]
0.280 [7.1mm]
0.091 [2.3mm]
Ø.240 [Ø6.1mm]
0.035 [0.9mm] SQ.
TYP.
0.300 [7.6mm]
0.150 [3.8mm]
Holder Faces
0.290 [7.4mm]
Ø.032+.003
-.002
TYP.
0.100 [2.5mm]
TYP.
0.100 [2.5mm]
LED Lead
Recommended Mounting Holes
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6/6, 94V-0, BLACK.
± .1
± .01
± .005
DESIGNED:
S. Irving
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
CHECKED:
D. Green
ANGULAR
X°
± 1°
DATE:
02/08/99
DATE:
02/26/04
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1¾ (5mm) TRI-LEAD LED HOLDER
REVISION:
PART NO:
H-178C-3
CAGE CODE : 32559
B
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H-178C-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+3.8504225+0.48285
- 75+3.7619175+0.47175
- 150+3.71765150+0.46620
- 400+3.62914400+0.45510
- 1000+3.496361000+0.43845
