F3-16-08
F3-16-08
    NORITAKE
    FILTER AQUA 109.0 X 24.0MM
F3-16-08 数据手册
Noritake Standard Acrylic Color Filters Key Features Noritake NTC has developed a series of acrylic color filters for Vacuum Fluorescent Displays (VFDs). These filters are durable, cost-effective, and optimized for VFDs. Five colors in ten sizes are available as standard items. Custom colors, sizes and thickness are welcome. No. Standard Colors Color Color Code Transmission* BL N6401 21% Blue Smoke Gray SG N217 31% GR N6515 Green 29% AQ N8912 Aqua 16% 28% Rose RO N660 01 05 12 16 17 01 Removable Protective Film (Green) 02 03 04 05 06 07 08 Filter Part Number 01-01 05-01 12-01 16-01 17-01 F3- 10 11 12 15 01-09 05-09 12-09 16-09 17-09 01-10 05-10 12-10 16-10 17-10 01-11 05-11 12-11 16-11 17-11 01-12 05-12 12-12 16-12 17-12 01-15 05-15 12-15 16-15 17-15 109.0×31.0 GU256x64C-3xxx/7xxx 97.0×26.0 CU20027-Y CU24043-Y 09 Suffix 01-02 05-02 12-02 16-02 17-02 01-03 05-03 12-03 16-03 17-03 01-04 05-04 12-04 16-04 17-04 01-05 05-05 12-05 16-05 17-05 01-06 05-06 12-06 16-06 17-06 01-07 05-07 12-07 16-07 17-07 01-08 05-08 12-08 16-08 17-08 SG N217 BL N6401 90 90 80 80 transmittance(%) 100 transmittance(%) Plastic Base (1.0mm Thickness) Prefix 100 70 60 50 40 30 20 70 The Nomenclature NTC Standard filter w/ Tape F3- Color No.-Size Code-T 60 For example, filter F3-01-01-T is blue color with size 94x24mm & Tape. 50 F3 type filters have 1.0mm thickness as default and other thickness are available. Please contact with sales department for details. 40 30 20 10 10 0 0 300 400 500 600 wavelength(nm) 700 800 300 400 500 600 wavelength(nm) 700 800 AQ N8912 GR N6515 90 transmittance(%) 80 70 60 50 40 30 100 90 90 80 80 70 60 50 40 30 20 10 10 400 500 600 wavelength(nm) 700 800 60 50 40 30 20 10 0 300 70 300 400 500 600 wavelength(nm) 700 800 0 300 400 500 600 700 800 wavelength(nm) Note: 1. Colors shown are approximate colors of filters 2. Noritake selected a popular module as a sample in the spec; the filter may be suited to other modules. 3. Data just for reference Noritake Co., Inc. 2635 Clearbrook Drive, Arlington Heights, IL. 60005 (800)779-5846 www.noritake-elec.com/colorFilter.html E-M-0016-02 DATE OF ISSUE: 07/20/2011 REVISION Rev 1.2 20 0 RO N660 100 transmittance(%) 100 transmittance(%) Non Glare Surface Texture 115.0x60.0 GU256x128C-3xxx * Transmission Values are based on information we believe to be reliable. It is offered in good faith, but without guarantee. Removable Protective Film (Clear) ASTM D-542 ASTM D1003 ASTM D638 ASTM D-638 ASTM D-638 ASTM D-256 JIS D0202 ASTM D-785 ASTM D-638 ASTM D-638 ASTM C-177 Overall Size 144.0x42.0 GU256x64D-7xxx/3xxx Size Code Standard (Stock) Items Color No. Materials and Construction (Cross-Section) of F3 Filter w/o Tape Condition 84.0x41.0 GU128x64D-7xxx Value -30 to +80 C -30 to +80 C 1.49 1.9 5% 750 kg/ cm² 1200 kg/ cm² 2.0 kJ/m² 2-3H 100 M scale 110 C 7x10 exp-5 cm/cm/C 0.17 W/mC 0.5mm 0.12mm 95.0x22.0 GU140x16G-7xxx 129.0x31.0 CU20029ECPB-W1J GU140x16J-7xxx 95.0x34.0 CU20045-UW5J GU140x32F-7xxx 109.0x24.0 CU24025ECPB-W1J Operating Temperature Storage Temperature Reflective Index Haze Elongation Tensile Rupture Strength Flexural Strength Impact Strength Pencil Hardness Rockwell Hardness Heat Distortion Temperature Coefficient of Thermal Expansion Coefficient of Thermal Conductivity Cutting Tolerance Thickness Tolerance 94.0x24.0 CU20025ECPB-W1J CU20025-UW1J 164.0x24.0 CU40025-UW6J GU280x16G-7xxx 75.0x22.0 CU16025ECPB-W6J GU112x16G-7xxx Main Specifications Parameter 83.0x24.0 GU128x32D-7xxx Inexpensive  Optical Quality Large Selection  Non glare Surface Available w/ 3M Adhesive Tape Excellent Weather Ability & Durability UL Approval for Flammability Std. 94HB Filter Size (mm) Noritake Module P/N.**     
F3-16-08 价格&库存
很抱歉,暂时无法提供与“F3-16-08”相匹配的价格&库存,您可以联系我们找货
