BAT54H,115
BAT54H,115
    NEXPERIA(安世)
    SOD-123F
    肖特基二极管 30V 2.70 x 1.70mm SMT SOD123F 200mA
BAT54H,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BAT54H Schottky barrier single diode in small SOD123F package 25 July 2012 Product data sheet 1. Product profile 1.1 General description Planar Schottky barrier diode with an integrated guard ring for stress protection, encapsulated in a SOD123F small and flat lead Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits • Low forward voltage • Low capacitance • AEC-Q101 qualified 1.3 Applications • Ultra high-speed switching • Voltage clamping • Line termination • Inverse-polarity protection 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter IF Conditions Min Typ Max Unit forward current - - 200 mA VR reverse voltage - - 30 V VF forward voltage - - 400 mV IF = 10 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode[1] 2 A anode [1] Simplified outline 1 Graphic symbol 2 SOD123F The marking bar indicates the cathode. Scan or click this QR code to view the latest information for this product K A aaa-003679 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package 3. Ordering information Table 3. Ordering information Type number Package BAT54H Name Description Version SOD123F plastic surface-mounted package; 2 leads SOD123F 4. Marking Table 4. Marking codes Type number Marking code BAT54H AG 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VR Min Max Unit reverse voltage - 30 V IF forward current - 200 mA IFRM repetitive peak forward current tp ≤ 1 s; δ ≤ 0.5 - 300 mA IFSM non-repetitive peak forward current tp ≤ 10 ms; Tj(init) = 25 °C - 600 mA Ptot total power dissipation Tamb = 25 °C - 375 mW Tj junction temperature - 125 °C Tamb ambient temperature -65 125 °C Tstg storage temperature -65 150 °C [1] Conditions [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point BAT54H Product data sheet All information provided in this document is subject to legal disclaimers. 25 July 2012 Min Typ Max Unit [1] - - 330 K/W [2] - - 70 K/W © NXP B.V. 2012. All rights reserved 2/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package [1] [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Soldering point of cathode tab. 7. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 0.1 mA; pulsed; tp ≤ 300 µs; - - 240 mV - - 320 mV - - 400 mV - - 500 mV - - 800 mV δ ≤ 0.02 ; Tamb = 25 °C IF = 1 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IF = 10 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IF = 30 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IF = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C IR reverse current VR = 25 V; Tamb = 25 °C - - 2 µA Cd diode capacitance f = 1 MHz; Tamb = 25 °C; VR = 1 V - - 10 pF msa892 103 IF (mA) msa893 103 IR (µA) (1) (2) (3) 102 (1) 102 (2) 10 10 1 10- 1 Fig. 1. (1) (2) (3) 0 1 0.4 0.8 VF (V) 10- 1 0 1.2 (3) 10 (1) Tamb = 125 °C (1) Tamb = 125 °C (2) Tamb = 85 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (3) Tamb = 25 °C Forward current as a function of forward voltage; typical values BAT54H Product data sheet Fig. 2. VR (V) 30 Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 25 July 2012 20 © NXP B.V. 2012. All rights reserved 3/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package msa891 15 Cd (pF) 10 5 0 0 10 20 VR (V) 30 f = 1 MHz; Tamb = 25 °C Fig. 3. Diode capacitance as a function of reverse voltage; typical values 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 1.7 1.5 1.2 1.0 1 0.55 0.35 3.6 3.4 2.7 2.5 2 0.70 0.55 0.25 0.10 Dimensions in mm Fig. 4. 04-11-29 SOD123F BAT54H Product data sheet All information provided in this document is subject to legal disclaimers. 25 July 2012 © NXP B.V. 2012. All rights reserved 4/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package 10. Soldering 4.4 4 2.9 1.6 solder lands solder resist 2.1 1.6 1.1 1.2 solder paste occupied area 1.1 (2×) Fig. 5. Reflow soldering footprint for SOD123F (SOD123F) 11. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BAT54H v.3 20120725 Product data sheet - BAT54H v.2 Modifications: • • • The format of this document has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Section "Test information" added BAT54H v.2 20100128 Product data sheet - BAT54H v.1 20050407 Product data sheet - BAT54H Product data sheet All information provided in this document is subject to legal disclaimers. 25 July 2012 BAT54H v.1 © NXP B.V. 2012. All rights reserved 5/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. BAT54H Product data sheet Suitability for use in automotive applications — This NXP Semiconductors product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. All information provided in this document is subject to legal disclaimers. 25 July 2012 © NXP B.V. 2012. All rights reserved 6/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse, QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. BAT54H Product data sheet All information provided in this document is subject to legal disclaimers. 25 July 2012 © NXP B.V. 2012. All rights reserved 7/8 BAT54H NXP Semiconductors Schottky barrier single diode in small SOD123F package 13. Contents 1 1.1 1.2 1.3 1.4 Product profile ....................................................... 1 General description .............................................. 1 Features and benefits ...........................................1 Applications .......................................................... 1 Quick reference data ............................................ 1 2 Pinning information ............................................... 1 3 Ordering information ............................................. 2 4 Marking ................................................................... 2 5 Limiting values .......................................................2 6 Thermal characteristics .........................................2 7 Characteristics ....................................................... 3 8 8.1 Test information ..................................................... 4 Quality information ......................................... 9 Package outline ..................................................... 4 10 Soldering ................................................................ 5 11 Revision history ..................................................... 5 12 12.1 12.2 12.3 12.4 Legal information ...................................................6 Data sheet status ................................................. 6 Definitions .............................................................6 Disclaimers ...........................................................6 Trademarks .......................................................... 7 © NXP B.V. 2012. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 25 July 2012 BAT54H Product data sheet All information provided in this document is subject to legal disclaimers. 25 July 2012 © NXP B.V. 2012. All rights reserved 8/8
BAT54H,115 价格&库存
很抱歉,暂时无法提供与“BAT54H,115”相匹配的价格&库存,您可以联系我们找货
BAT54H,115
  • 3000+0.287313000+0.03729
  • 9000+0.239139000+0.03104
BAT54H,115
    BAT54H,115
    • 10+0.60548
    • 100+0.49045
    • 600+0.38986
    • 1200+0.38401
