GAP3SLT33-220FP
3300V 0.3A SiC Schottky MPS™ Diode
TM
Silicon Carbide Schottky Diode
VRRM
IF (TL ≤ 125°C) =
QC
Features
Package
Enhanced Surge and Avalanche Robustness
Superior Figure of Merit QC/IF
Low VF for High Temperature Operation
Low Thermal Resistance
Low Reverse Leakage Current
Temperature Independent Fast Switching
Positive Temperature Coefficient of VF
High dV/dt Ruggedness
Case
RoHS
TO-220-FP
Advantages
3300 V
0.3 A
14 nC
K
A
REACH
Applications
High System Reliability
Optimal Price Performance
Improved System Efficiency
Reduced Cooling Requirements
Increased System Power Density
Zero Reverse Recovery Current
Easy to Parallel without Thermal Runaway
Enables Extremely Fast Switching
Medical Imaging
High Voltage Sensing
Oil Drilling
Geothermal Instrumentation
High Voltage Multipliers
High Frequency Rectifiers
High Voltage Switching
Pulsed Power
Absolute Maximum Ratings (At TL = 25°C Unless Otherwise Stated)
Parameter
Repetitive Peak Reverse Voltage
Continuous Forward Current
Non-Repetitive Peak Forward Surge Current, Half Sine
Wave
Symbol
VRRM
IF
Repetitive Peak Forward Surge Current, Half Sine Wave
IF,RM
i2t Value
Diode Ruggedness
Power Dissipation
Operating and Storage Temperature
Apr. 20 Rev 1.4
IF,SM
IF,MAX
∫i2dt
dV/dt
PTOT
Tj , Tstg
Conditions
TL ≤ 125°C, D = 1
TL = 25°C, tP = 10 ms
TL = 150°C, tP = 10 ms
TL = 25°C, tP = 10 µs
VR = 0 ~ 2640 V
TL = 25°C
Values
3300
0.3
2
1
1.4
1
10
0.02
100
89
-55 to 175
www.genesicsemi.com/sic-schottky-mps/GAP3SLT33-220FP/GAP3SLT33-220FP.pdf
Unit
V
A
Note
A
A
A
A2 s
V/ns
W
°C
Fig. 3
Page 1 of 6
GAP3SLT33-220FP
TM
Electrical Characteristics
Parameter
Symbol
Diode Forward Voltage
VF
Reverse Current
IR
Total Capacitive Charge
QC
Switching Time
tS
Total Capacitance
C
Conditions
Min.
IF = 0.3 A, Tj = 25°C
IF = 0.3 A, Tj = 175°C
VR = 3300 V, Tj = 25°C
VR = 3300 V, Tj = 175°C
VR = 1500 V
VR = 2000 V
IF ≤ IF,MAX
dIF/dt = 200 A/µs
VR = 1500 V
VR = 2000 V
VR = 1 V, f = 1MHz
VR = 2000 V, f = 1MHz
Values
Typ.
1.15
1.5
1
10
12
14
Max.
3
10
100
Unit
Note
V
Fig. 1
µA
Fig. 2
nC
Fig. 7
< 10
ns
93
5
pF
Fig. 6
Unit
Note
°C/W
g
Nm
Fig. 9
Thermal/Package Characteristics
Parameter
Symbol
Thermal Resistance, Junction - Lead
Weight
Mounting Torque
Apr. 20 Rev 1.4
RthJL
WT
TM
Conditions
Min.
Values
Typ.
1.69
2
Screws to Heatsink
Max.
1
Page 2 of 6
GAP3SLT33-220FP
Figure 1: Typical Forward Characteristics
IF = f(VF,Tj); tP = 250 µs
Figure 3: Power Derating Curves
PTOT = f(TL); Tj = 175°C
Apr. 20 Rev 1.4
TM
Figure 2: Typical Reverse Characteristics
IR = f(VR,Tj)
Figure 4: Typical Junction Capacitance vs Reverse
Voltage Characteristics
C = f(VR); f = 1MHz
Page 3 of 6
GAP3SLT33-220FP
Figure 5: Typical Capacitive Charge vs Reverse Voltage
Characteristics
TM
Figure 6: Typical Capacitive Energy vs Reverse Voltage
Characteristics
QC = f(VR); f = 1MHz
EC = f(VR); f = 1MHz
Figure 7: Forward Curve Model
Forward Curve Model Equation:
IF = (VF - VBI)/RDIFF (A)
Built-In Voltage (VBI):
VBI(Tj) = m × Tj + n (V)
m = -1.42e-03 (V/°C)
n = 0.903 (V)
Differential Resistance (RDIFF):
1/RDIFF
RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω)
a = 1.81e-05 (Ω/°C2)
b = 0.00878 (Ω/°C)
c = 0.725 (Ω)
VBI
Forward Power Loss Equation:
PLOSS = VBI(Tj) × IAVG + RDIFF(Tj) × IRMS2
IF = f(VF,Tj)
Apr. 20 Rev 1.4
Page 4 of 6
GAP3SLT33-220FP
TM
Package Dimensions
TO-220-FP Package Outline
0.102 (2.60)
0.118 (3.00)
0.392 (9.96)
0.408 (10.36)
Ø 0.148 (3.750)
0.155 (3.930)
0.167(4.24)
0.183(4.64)
0.045(1.15)
0.055(1.40)
0.254
(6.45)
0.579
0.630
(14.70)
(16.00)
0.501
(12.73)
0.347
0.355
(8.82)
(9.02)
0.306 (7.77)
0.047(1.20)
0.067(1.70)
0.157(4.00)
MAX.
0.530(13.47)
0.550(13.97)
0.091 (2.30)
0.106 (2.70)
0.027(0.70)
0.035(0.90)
0.016(0.40)
0.237(0.60)
0.100 BSC.
(2.540) BSC.
Recommended Solder Pad Layout
Package View
0.12 (3.1)
0.20 (5.1)
0.05 (1.3)
K
A
NOTE
1. CONTROLLED DEIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER.
2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS.
Apr. 20 Rev 1.4
Page 5 of 6
GAP3SLT33-220FP
TM
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the
threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive
2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive
2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative.
REACH Compliance
REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency
(ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a
GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information
(REACH Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human
body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not
limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency
medical equipment, aircraft navigation or communication or control systems, or air traffic control systems.
GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or
implied to any intellectual property rights is granted by this document.
Related Links
• SPICE Models:
https://www.genesicsemi.com/sic-schottky-mps/GAP3SLT33-220FP/GAP3SLT33-220FP_SPICE.zip
• PLECS Models:
https://www.genesicsemi.com/sic-schottky-mps/GAP3SLT33-220FP/GAP3SLT33-220FP_PLECS.zip
• CAD Models:
https://www.genesicsemi.com/sic-schottky-mps/GAP3SLT33-220FP/GAP3SLT33-220FP_3D.zip
• Evaluation Boards: https://www.genesicsemi.com/technical-support
• Reliability:
https://www.genesicsemi.com/reliability
• Compliance:
https://www.genesicsemi.com/compliance
• Quality Manual:
https://www.genesicsemi.com/quality
Apr. 20 Rev 1.4
Copyright© 2020 GeneSiC Semiconductor Inc. All Rights Reserved.
The information in this document is subject to change without notice.
Published by GeneSiC Semiconductor, Inc.
43670 Trade Center Place Suite 155, Dulles, VA 20166; USA
Page 6 of 6
很抱歉,暂时无法提供与“GAP3SLT33-220FP”相匹配的价格&库存,您可以联系我们找货
