GB01SLT12-220
Silicon Carbide Power
Schottky Diode
VRRM
IF (Tc = 25°C)
IF (Tc ≤ 150°C)
QC
Features
Package
RoHS Compliant
Industry’s leading low leakage currents
175 °C maximum operating temperature
Temperature independent switching behavior
Superior surge current capability
Positive temperature coefficient of VF
Extremely fast switching speeds
Superior figure of merit QC/IF
1200 V
2.5 A
1A
7 nC
case
PIN 1
CASE
PIN 2
2
1
TO – 220AC
Advantages
Applications
Low standby power losses
Improved circuit efficiency (Lower overall cost)
Low switching losses
Ease of paralleling devices without thermal runaway
Smaller heat sink requirements
Low reverse recovery current
Low device capacitance
Low reverse leakage current at operating temperature
Power Factor Correction (PFC)
Switched-Mode Power Supply (SMPS)
Solar Inverters
Wind Turbine Inverters
Motor Drives
Induction Heating
Uninterruptible Power Supply (UPS)
High Voltage Multipliers
Maximum Ratings at Tj = 175 °C, unless otherwise specified
Parameter
Repetitive peak reverse voltage
Continuous forward current
RMS forward current
Surge non-repetitive forward current, Half Sine
Wave
Non-repetitive peak forward current
2
Symbol
VRRM
IF
IF
IF(RMS)
IF,SM
IF,max
2
∫i dt
I t value
Power dissipation
Operating and storage temperature
Ptot
Tj , Tstg
Conditions
Values
1200
2.5
1
2
10
8
65
0.5
0.3
42
-55 to 175
TC = 25 °C
TC ≤ 150 °C
TC ≤ 150 °C
TC = 25 °C, tP = 10 ms
TC = 150 °C, tP = 10 ms
TC = 25 °C, tP = 10 µs
TC = 25 °C
Unit
V
A
A
A
A
A
A2s
W
°C
Electrical Characteristics at Tj = 175 °C, unless otherwise specified
Parameter
Symbol
Diode forward voltage
VF
Reverse current
IR
Total capacitive charge
QC
Switching time
ts
Total capacitance
C
Conditions
min.
IF = 1 A, Tj = 25 °C
IF = 1 A, Tj = 175 °C
VR = 1200 V, Tj = 25 °C
VR = 1200 V, Tj = 175 °C
VR = 400 V
IF ≤ IF,MAX
VR = 960 V
dIF/dt = 200 A/μs
VR = 400 V
Tj = 175 °C
VR = 960 V
VR = 1 V, f = 1 MHz, Tj = 25 °C
VR = 400 V, f = 1 MHz, Tj = 25 °C
VR = 1000 V, f = 1 MHz, Tj = 25 °C
Values
typ.
1.6
2.4
1
10
7
13
max.
1.8
3.7
10
100
Unit
V
µA
nC
< 17
ns
69
10
8
pF
3.6
°C/W
Thermal Characteristics
Thermal resistance, junction - case
RthJC
Mechanical Properties
Mounting torque
Aug 2014
M
http://www.genesicsemi.com/commercial-sic/sic-schottky-rectifiers/
0.6
Nm
Pg 1 of 4
GB01SLT12-220
Figure 1: Typical Forward Characteristics
Figure 2: Typical Reverse Characteristics
Figure 3: Power Derating Curve
Figure 4: Current Derating Curves (D = tP/T, tP= 400 µs)
(Considering worst case Zth conditions )
Figure 5: Typical Junction Capacitance vs Reverse Voltage
Characteristics
Figure 6: Typical Capacitive Energy vs Reverse Voltage
Characteristics
Aug 2014
Pg 2 of 4
GB01SLT12-220
Figure 7: Current vs Pulse Duration Curves at TC = 160 °C
Figure 8: Transient Thermal Impedance
Package Dimensions:
TO-220AC
Ref.
0.103 (2.616)
0.113 (2.870)
PACKAGE OUTLINE
0.400 (10.160)
0.420 (10.668)
Ø 0.146 (3.708) Ref.
0.156 (3.962)
0.171 (4.343)
0.181 (4.597)
0.045 (1.143)
0.055 (1.397)
0.248
(6.299)
0.585
0.595
(14.859)
(15.113)
0.308
(7.823)
0.487
(12.387)
GB01SLT12-220
XXXXXX
Lot Code
0.351
0.361
(8.915)
(9.169)
0.256 (6.502)
0.300 (7.620)
0.250 (6.350)
MAX.
0.047 (1.194)
0.053 (1.346)
0.080 (2.032)
0.120 (3.048)
0.028 (0.711)
0.035 (0.965)
0.100 BSC.
(2.540) BSC.
0.500 (12.700)
0.580 (14.732)
0.012 (0.305)
0.018 (0.457)
NOTE
1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER.
2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS
Aug 2014
Pg 3 of 4
GB01SLT12-220
Revision History
Date
2014/08/26
2013/02/05
Revision
3
2
Comments
Updated Electrical Characteristics
Second generation update
2012/05/22
2010/12/13
1
Second generation release
Initial release
Supersedes
Published by
GeneSiC Semiconductor, Inc.
43670 Trade Center Place Suite 155
Dulles, VA 20166
GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice.
GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any
intellectual property rights is granted by this document.
Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft
navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal
injury and/or property damage.
Aug 2014
Pg 4 of 4
GB01SLT12-220
SPICE Model Parameters
This is a secure document. Please copy this code from the SPICE model PDF file on our website
(http://www.genesicsemi.com/images/products_sic/rectifiers/GB01SLT12-220_SPICE.pdf)
into
LTSPICE (version 4) software for simulation of the GB01SLT12-220.
MODEL OF GeneSiC Semiconductor Inc.
$Revision:
1.0
$Date:
04-SEP-2013
43670 Trade Center Place Ste. 155
Dulles, VA 20166
COPYRIGHT (C) 2013 GeneSiC Semiconductor Inc.
ALL RIGHTS RESERVED
* These models are provided "AS IS, WHERE IS, AND WITH NO WARRANTY
* OF ANY KIND EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED
* TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
* PARTICULAR PURPOSE."
* Models accurate up to 2 times rated drain current.
* Start of GB01SLT12-220 SPICE Model
.SUBCKT GB01SLT12 ANODE KATHODE
R1 ANODE INT R=((TEMP-24)*0.0069); Temperature Dependant Resistor
D1 INT KATHODE GB01SLT12_25C; Call the 25C Diode Model
D2 ANODE KATHODE GB01SLT12_PIN; Call the PiN Diode Model
.MODEL GB01SLT12_25C D
+ IS
7.27E-19
RS
0.592251
+ N
1
IKF
407.773
+ EG
1.2
XTI
3
+ CJO
7.90E-11
VJ
0.367
+ M
1.63
FC
0.5
+ TT
1.00E-10
BV
1200
+ IBV
1.00E-03
VPK
1200
+ IAVE
1
TYPE
SiC_Schottky
+ MFG
GeneSiC_Semiconductor
.MODEL GB01SLT12_PIN D
+ IS
1.08E-17
RS
1.8
+ N
2.2313
IKF
999
+ EG
3.23
XTI
-65
+ FC
0.5
TT
+ BV
1200
IBV
1.00E-03
+ VPK
1200
IAVE
1
+ TYPE
SiC_PiN
.ENDS
* End of GB01SLT12-220 SPICE Model
Sep 2013
Pg 1 of 1
很抱歉,暂时无法提供与“GB01SLT12-220”相匹配的价格&库存,您可以联系我们找货
