1N2133A thru 1N2138AR
Silicon Standard
Recovery Diode
VRRM = 300 V - 600 V
IF =60 A
Features
• High Surge Capability
• Types from 300 V to 600 V VRRM
DO-5 Package
• Not ESD Sensitive
A
C
Note:
1. Standard polarity: Stud is cathode.
2. Reverse polarity (R): Stud is anode.
A
C
Stud Stud
(R)
3. Stud is base.
Maximum ratings, at Tj = 25 °C, unless otherwise specified
Conditions
1N2133A(R) 1N2135A(R) 1N2137A(R) 1N2138A(R)
Parameter
Symbol
Unit
Repetitive peak reverse voltage
VRRM
300
400
500
600
V
RMS reverse voltage
VRMS
210
280
350
420
V
DC blocking voltage
VDC
200
V
50
100
150
Continuous forward current
IF
TC ≤ 150 °C
60
60
60
60
A
Surge non-repetitive forward
current, Half Sine Wave
IF,SM
TC = 25 °C, tp = 8.3 ms
1050
1050
1050
1050
A
Operating temperature
Storage temperature
Tj
Tstg
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
°C
°C
Electrical characteristics, at Tj = 25 °C, unless otherwise specified
Parameter
Diode forward voltage
Reverse current
Symbol
VF
IR
Conditions
IF = 60 A, Tj = 25 °C
VR = 50 V, Tj = 25 °C
VR = 50 V, Tj = 150 °C
Unit
1.1
10
15
1.1
10
15
1.1
10
15
1.1
10
15
μA
mA
V
0.65
0.65
0.65
0.65
°C/W
Thermal characteristics
Thermal resistance, junction case
Oct. 2018
RthJC
http://www.diodemodule.com/silicon_products/studs/1n2138ar.pdf
1
Oct. 2018
2
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
DO- 5 (DO-203AB)
M
J
K
P
D
B
G
N
C
F
E
A
A
C
A
C
Stud Stud
(R)
Inches
Millimeters
Min
Max
Min
Max
B
0.669
0.687
17.19
17.44
C
0.794
20.16
D
1.020
25.91
E
0.422
0.453
10.72
11.50
F
0.115
0.200
2.93
5.08
G
0.460
11.68
J
0.280
7.00
K
0.236
6.00
M
0.589
14.96
N
0.063
1.60
P
0.140
0.175
3.56
4.45
1/4 –28 UNF
A
Oct. 2018
3
很抱歉,暂时无法提供与“1N2138AR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+140.09760
- 200+55.90080
- 500+54.03240
- 1000+53.11440
