GB02SLT12-214
GB02SLT12-214
    GENESICSEMICONDUCTOR
    SMB(DO-214AA)
GB02SLT12-214 数据手册
GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode TM Silicon Carbide Schottky Diode VRRM = IF (TL ≤ 150°C) = QC = Features • • • • • • • • Package Low VF for High Temperature Operation Enhanced Surge and Avalanche Robustness Superior Figure of Merit QC/IF Low Thermal Resistance Low Reverse Leakage Current Temperature Independent Fast Switching Positive Temperature Coefficient of VF High dV/dt Ruggedness K RoHS A DO-214 Advantages • • • • • • • • 1200 V 2A 11 nC REACH Applications Improved System Efficiency High System Reliability Optimal Price Performance Reduced Cooling Requirements Increased System Power Density Zero Reverse Recovery Current Easy to Parallel without Thermal Runaway Enables Extremely Fast Switching • • • • • • • • High Voltage Sensing Solar Inverters Electric Vehicles High Frequency Converters Battery Chargers AC/DC Power Supplies Anti-Parallel / Free-Wheeling Diode LED and HID Lighting Absolute Maximum Ratings (At TL = 25°C Unless Otherwise Stated) Parameter Repetitive Peak Reverse Voltage Continuous Forward Current Non-Repetitive Peak Forward Surge Current, Half Sine Wave Symbol VRRM IF Repetitive Peak Forward Surge Current, Half Sine Wave IF,RM Non-Repetitive Peak Forward Surge Current i2t Value Non-Repetitive Avalanche Energy Diode Ruggedness Power Dissipation Operating and Storage Temperature Apr. 20 Rev 1.4 IF,SM IF,MAX ∫i2dt EAS dV/dt PTOT Tj , Tstg Conditions TL ≤ 150°C TL = 25°C, tP = 10 ms TL = 150°C, tP = 10 ms TL = 25°C, tP = 10 ms TL = 150°C, tP = 10 ms TL = 25°C, tP = 10 µs TL = 25°C, tP = 10 ms L = 18.0 mH, IAS = 2 A VR = 0 ~ 960 V TL = 25°C Values 1200 2 20 16 12 9 100 2 36 200 84 -55 to 175 www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214.pdf Unit V A Note A A A A2s mJ V/ns W °C Fig. 3 Page 1 of 6 GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode TM Electrical Characteristics Parameter Symbol Diode Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Switching Time tS Total Capacitance C Conditions Min. IF = 2 A, Tj = 25°C IF = 2 A, Tj = 175°C VR = 1200 V, Tj = 25°C VR = 1200 V, Tj = 175°C VR = 400 V VR = 800 V IF ≤ IF,MAX dIF/dt = 200 A/µs VR = 400 V VR = 800 V VR = 1 V, f = 1MHz VR = 800 V, f = 1MHz Values Typ. 1.5 1.9 1 3 7 11 Max. 1.8 5 Unit Note V Fig. 1 µA Fig. 2 nC Fig. 5 < 10 ns 122 7 pF Fig. 4 Unit Note Thermal/Package Characteristics Parameter Thermal Resistance, Junction - Lead Weight Apr. 20 Rev 1.4 Symbol RthJL WT Conditions Min. Values Typ. 5.17 0.3 www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214.pdf Max. °C/W g Page 2 of 6 GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode Figure 1: Typical Forward Characteristics IF = f(VF,Tj); tP = 250 µs Figure 3: Power Derating Curves PTOT = f(TL); Tj = 175°C Apr. 20 Rev 1.4 TM Figure 2: Typical Reverse Characteristics IR = f(VR,Tj) Figure 4: Typical Junction Capacitance vs Reverse Voltage Characteristics C = f(VR); f = 1MHz www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214.pdf Page 3 of 6 GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode Figure 5: Typical Capacitive Charge vs Reverse Voltage Characteristics TM Figure 6: Typical Capacitive Energy vs Reverse Voltage Characteristics QC = f(VR); f = 1MHz EC = f(VR); f = 1MHz Figure 7: Forward Curve Model Forward Curve Model Equation: IF = (VF - VBI)/RDIFF (A) Built-In Voltage (VBI): VBI(Tj) = m × Tj + n (V) m = -0.00123 (V/°C) n = 0.995 (V) Differential Resistance (RDIFF): 1/RDIFF RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω) a = 5.96e-06 (Ω/°C2) b = 8.46e-04 (Ω/°C) c = 0.251 (Ω) VBI Forward Power Loss Equation: PLOSS = VBI(Tj) × IAVG + RDIFF(Tj) × IRMS2 IF = f(VF,Tj) Apr. 20 Rev 1.4 www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214.pdf Page 4 of 6 GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode TM Package Dimensions DO-214 Package Outline 0.155(3.940) 0.130(3.300) 0.086(2.200) 0.077(1.950) 0.180(4.570) 0.160(4.060) 0.096(2.440) 0.084(2.130) 0.060(1.520) 0.030(0.760) 0.008(0.203) max 0.220(5.590) 0.205(5.210) Recommended Solder Pad Layout Package View 0.085(2.160) min 0.085(2.160) min K 0.107(2.740) max 0.089(2.260) max A NOTE 1. CONTROLLED DEIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS. Apr. 20 Rev 1.4 www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214.pdf Page 5 of 6 GB02SLT12-214 1200V 2A SiC Schottky MPS™ Diode TM RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive 2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative. REACH Compliance REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control systems. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Related Links • SPICE Models: https://www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214_SPICE.zip • PLECS Models: https://www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214_PLECS.zip • CAD Models: https://www.genesicsemi.com/sic-schottky-mps/GB02SLT12-214/GB02SLT12-214_3D.zip • Evaluation Boards: https://www.genesicsemi.com/technical-support • Reliability: https://www.genesicsemi.com/reliability • Compliance: https://www.genesicsemi.com/compliance • Quality Manual: https://www.genesicsemi.com/quality www.genesicsemi.com/sic-schottky-mps/ Apr. 20 Rev 1.4 Copyright© 2020 GeneSiC Semiconductor Inc. All Rights Reserved. The information in this document is subject to change without notice. Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155, Dulles, VA 20166; USA Page 6 of 6
GB02SLT12-214 价格&库存
很抱歉,暂时无法提供与“GB02SLT12-214”相匹配的价格&库存,您可以联系我们找货
GB02SLT12-214
  • 1+55.068611+7.12460
  • 10+36.6895710+4.74678
  • 100+26.24655100+3.39570
  • 500+23.37115500+3.02369
