FR85JR05
FR85JR05
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
FR85JR05 数据手册
FR85B05 thru FR85JR05 Silicon Fast Recovery Diode VRRM = 100 V - 600 V IF = 85 A Features • High Surge Capability • Types from 100 V to 600 V VRRM DO-5 Package • Not ESD Sensitive C A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. 3. Stud is base. A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage FR85B(R)05 FR85D(R)05 FR85G(R)05 FR85J(R)05 Unit 100 200 400 600 V VRMS 70 140 280 420 V VDC 100 200 400 600 V Symbol Conditions VRRM Continuous forward current IF TC ≤ 100 °C 85 85 85 85 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 1369 1369 1369 1369 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions FR85B(R)05 FR85D(R)05 FR85G(R)05 FR85J(R)05 Unit VF IF = 85 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 125 °C 1.3 25 20 1.3 25 20 1.3 25 20 1.3 25 20 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 500 500 500 500 nS IR V Recovery Time Maximum reverse recovery time Oct. 2018 TRR http://www.diodemodule.com/silicon_products/studs/fr85jr05.pdf 1 FR85B05 thru FR85JR05 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr85jr05.pdf 2 FR85B05 thru FR85JR05 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr85jr05.pdf 3
FR85JR05
PDF文档中的物料型号为:STM32F103C8T6。
器件简介:STM32F103C8T6是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种应用场景。
引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压2.0V至3.6V,最大工作频率72MHz,内置64KB的闪存和20KB的RAM。
功能详解:该芯片具备多种外设接口,如UART、SPI、I2C等,并支持多种通信协议。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:采用LQFP48封装。
FR85JR05 价格&库存
很抱歉,暂时无法提供与“FR85JR05”相匹配的价格&库存,您可以联系我们找货
FR85JR05
  • 1+300.784901+38.80373
  • 10+221.2731310+28.54606
  • 100+177.59982100+22.91184
FR85JR05
    • 1+379.49040
    • 200+151.42680
    • 500+146.36160
    • 1000+143.86680
