1N3671A thru 1N3673AR
Silicon Standard
Recovery Diode
VRRM = 800 V - 1000 V
IF = 12 A
Features
• High Surge Capability
• Types from 800 V to 1000 V VRRM
DO-4 Package
• Not ESD Sensitive
C
A
Note:
1. Standard polarity: Stud is cathode.
2. Reverse polarity (R): Stud is anode.
A
C
Stud Stud
(R)
3. Stud is base.
Maximum ratings, at Tj = 25 °C, unless otherwise specified
1N3671A (R)
1N3673A (R)
Unit
VRRM
800
1000
V
VRMS
560
700
V
VDC
800
1000
V
Parameter
Symbol
Repetitive peak reverse voltage
RMS reverse voltage
DC blocking voltage
Conditions
Continuous forward current
IF
TC ≤ 150 °C
12
12
A
Surge non-repetitive forward
current, Half Sine Wave
IF,SM
TC = 25 °C, tp = 8.3 ms
240
240
A
Operating temperature
Storage temperature
Tj
Tstg
-55 to 150
-55 to 150
-55 to 150
-55 to 150
°C
°C
Electrical characteristics, at Tj = 25 °C, unless otherwise specified
Parameter
Diode forward voltage
Reverse current
Symbol
VF
IR
Conditions
1N3671A (R)
1N3673A (R)
Unit
IF = 12 A, Tj = 25 °C
VR = 50 V, Tj = 25 °C
VR = 50 V, Tj = 175 °C
1.1
10
15
1.1
10
15
μA
mA
2.00
2.00
°C/W
V
Thermal characteristics
Thermal resistance, junction case
Oct. 2018
RthJC
http://www.diodemodule.com/silicon_products/studs/1n3673ar.pdf
1
Oct. 2018
2
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
DO- 4 (DO-203AA)
M
J
P
D
B
G
N
C
E
F
A
A
C
A
C
Stud Stud
(R)
Inches
Min
Millimeters
Max
A
Oct. 2018
Min
Max
10-32 UNF
B
0.424
0.437
10.77
11.10
C
0.505
12.82
D
0.800
20.30
E
0.453
0.492
11.50
12.50
F
0.114
0.140
2.90
3.50
G
0.405
10.29
J
0.216
5.50
M
φ0.302
φ7.68
N
0.031
0.045
0.80
1.15
P
0.070
0.79
1.80
2.00
3
很抱歉,暂时无法提供与“1N3673AR”相匹配的价格&库存,您可以联系我们找货
