FR12M05
FR12M05
    GENESICSEMICONDUCTOR
    DO-203AA(DO-5)
    FR12M05
FR12M05 数据手册
FR12K05 thru FR12MR05 Silicon Fast Recovery Diode VRRM = 800 V - 1000 V IF = 12 A Features • High Surge Capability • Types from 800 V to 1000 V VRRM DO-4 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage FR12K(R)05 FR12M(R)05 Unit VRRM 800 1000 V VRMS 560 700 V VDC 800 1000 V Symbol Conditions Continuous forward current IF TC ≤ 100 °C 12 12 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 180 180 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions FR12K(R)05 FR12M(R)05 Unit VF IF = 12 A, Tj = 25 °C VR = 100 V, Tj = 25 °C VR = 100 V, Tj = 150 °C 0.8 25 6 0.8 25 6 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 500 500 nS 2.0 2.0 °C/W IR V Recovery Time Maximum reverse recovery time TRR Thermal characteristics Thermal resistance, junction - case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/fr12m05.pdf 1 FR12K05 thru FR12MR05 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr12m05.pdf 2 FR12K05 thru FR12MR05 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 4 (DO-203AA) M J P D B G N C E F A A C A C Stud Stud (R) Inches Min Millimeters Max A Oct. 2018 Min Max 10-32 UNF B 0.424 0.437 10.77 11.10 C ----- 0.505 ----- 12.82 D ------ 0.800 ----- 20.30 E 0.453 0.492 11.50 12.50 F 0.114 0.140 2.90 3.50 G ----- 0.405 ----- 10.29 J ----- 0.216 ----- 5.50 M ----- φ0.302 ----- φ7.68 N 0.031 0.045 0.80 1.15 P 0.070 0.79 1.80 2.00 http://www.diodemodule.com/silicon_products/studs/fr12m05.pdf 3
FR12M05 价格&库存
很抱歉,暂时无法提供与“FR12M05”相匹配的价格&库存,您可以联系我们找货
