1N1184AR
1N1184AR
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
    DIODE GEN PURP REV 100V 40A DO5
1N1184AR 数据手册
1N1183A thru 1N1190AR Silicon Standard Recovery Diode VRRM = 50 V - 600 V IF = 40 A Features • High Surge Capability • Types up to 600 V VRRM DO-5 Package • Not ESD Sensitive A Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. 3. Stud is base. C A C Stud Stud (R) Maximum ratings, at Tj = 25 °C, unless otherwise specified Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Symbol Conditions 1N1183A(R) 1N1184A(R) 1N1186A(R) 1N1188A(R) 1N1190A(R) Unit VRRM 50 100 200 400 600 V VRMS 35 70 140 280 420 V VDC 50 100 200 400 600 V Continuous forward current IF TC ≤ 150 °C 40 40 40 40 40 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 800 800 800 800 800 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Symbol Diode forward voltage VF Reverse current IR Conditions IF = 40 A, Tj = 25 °C VR = 50 V, Tj = 25 °C VR = 50 V, Tj = 140 °C 1N1183A(R) 1N1184A(R) 1N1186A(R) 1N1188A(R) 1N1190A(R) Unit V 1.1 10 15 1.1 10 15 1.1 10 15 1.1 10 15 1.1 10 15 μA mA 1.25 1.25 1.25 1.25 1.25 °C/W Thermal characteristics Thermal resistance, junction case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/1n1184ar.pdf 1 1N1183A thru 1N1190AR Oct. 2018 http://www.diodemodule.com/silicon_products/studs/1n1184ar.pdf 2 1N1183A thru 1N1190AR Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Oct. 2018 Min Max 1/4 –28 UNF A B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/1n1184ar.pdf 3
1N1184AR 价格&库存
很抱歉,暂时无法提供与“1N1184AR”相匹配的价格&库存,您可以联系我们找货
1N1184AR
    • 1+120.30120
    • 200+48.00600
    • 500+46.39680
    • 1000+45.60840
