1N1188 thru 1N1190R
Silicon Standard
Recovery Diode
VRRM = 400 V - 600 V
IF = 35 A
Features
• High Surge Capability
• Types from 400 to 600 V VRRM
DO-5 Package
• Not ESD Sensitive
A
Note:
1. Standard polarity: Stud is cathode.
2. Reverse polarity (R): Stud is anode.
C
A
C
Stud Stud
(R)
3. Stud is base.
Maximum ratings, at Tj = 25 °C, unless otherwise specified
1N1188 (R)
1N1189 (R)
1N1190 (R)
Unit
VRRM
400
500
600
V
VRMS
280
350
420
V
VDC
400
500
600
V
Parameter
Symbol
Repetitive peak reverse voltage
RMS reverse voltage
DC blocking voltage
Conditions
("R" devices have leads reversed)
Continuous forward current
IF
TC ≤ 140 °C
35
35
35
A
Surge non-repetitive forward
current, Half Sine Wave
IF,SM
TC = 25 °C, tp = 8.3 ms
595
595
595
A
Operating temperature
Storage temperature
Tj
Tstg
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
-55 to 150
°C
°C
Electrical characteristics, at Tj = 25 °C, unless otherwise specified
Parameter
Diode forward voltage
Reverse current
Symbol
VF
IR
Conditions
1N1188 (R)
1N1189 (R)
1N1190 (R)
Unit
IF = 35 A, Tj = 25 °C
VR = 50 V, Tj = 25 °C
VR = 50 V, Tj = 140 °C
1.2
10
10
1.2
10
10
1.2
10
10
μA
mA
0.25
0.25
0.25
°C/W
V
Thermal characteristics
Thermal resistance, junction case
Oct. 2018
RthJC
http://www.diodemodule.com/silicon_products/studs/1n1190.pdf
1
1N1188 thru 1N1190R
Oct. 2018
2
1N1188 thru 1N1190R
Package dimensions and terminal configuration
Product is marked with part number and terminal configuration.
DO- 5 (DO-203AB)
M
J
K
P
D
B
G
N
C
F
E
A
A
C
A
C
Stud Stud
(R)
Inches
Millimeters
Min
Max
Min
Max
B
0.669
0.687
17.19
17.44
C
0.794
20.16
D
1.020
25.91
E
0.422
0.453
10.72
11.50
F
0.115
0.200
2.93
5.08
G
0.460
11.68
J
0.280
7.00
K
0.236
6.00
M
0.589
14.96
N
0.063
1.60
P
0.140
0.175
3.56
4.45
1/4 –28 UNF
A
Oct. 2018
3
很抱歉,暂时无法提供与“1N1190”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+117.61200
- 200+46.92600
- 500+45.36000
- 1000+44.58240
