FR20BR02
FR20BR02
    GENESICSEMICONDUCTOR
    DO-203AB(DO-5)
FR20BR02 数据手册
FR20A02 thru FR20JR02 Silicon Fast Recovery Diode VRRM = 50 V - 600 V IF = 20 A Features • High Surge Capability • Types from 50 V to 600 V VRRM DO-5 Package • Not ESD Sensitive A C Note: 1. Standard polarity: Stud is cathode. 2. Reverse polarity (R): Stud is anode. A C Stud Stud (R) 3. Stud is base. Maximum ratings, at Tj = 25 °C, unless otherwise specified ("R" devices have leads reversed) Parameter Repetitive peak reverse voltage RMS reverse voltage DC blocking voltage Symbol Conditions FR20A(R)02 FR20B(R)02 FR20D(R)02 FR20G(R)02 FR20J(R)02 Unit VRRM 50 VRMS VDC 100 200 400 600 V 35 70 140 280 420 V 50 100 200 400 600 V Continuous forward current IF TC ≤ 100 °C 20 20 20 20 20 A Surge non-repetitive forward current, Half Sine Wave IF,SM TC = 25 °C, tp = 8.3 ms 250 250 250 250 250 A Operating temperature Storage temperature Tj Tstg -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 °C °C Electrical characteristics, at Tj = 25 °C, unless otherwise specified Parameter Diode forward voltage Reverse current Symbol Conditions VF IF = 20 A, Tj = 25 °C VR = 50 V, Tj = 25 °C VR = 50 V, Tj = 150 °C 1.0 25 10 1.0 25 10 1.0 25 10 1.0 25 10 1.0 25 10 μA mA IF=0.5 A, IR=1.0 A, IRR= 0.25 A 200 200 200 200 250 nS 0.6 0.6 0.6 0.6 0.6 °C/W IR FR20A(R)02 FR20B(R)02 FR20D(R)02 FR20G(R)02 FR20J(R)02 Unit V Recovery Time Maximum reverse recovery time TRR Thermal characteristics Thermal resistance, junction - case Oct. 2018 RthJC http://www.diodemodule.com/silicon_products/studs/fr20br02.pdf 1 FR20A02 thru FR20JR02 Oct. 2018 http://www.diodemodule.com/silicon_products/studs/fr20br02.pdf 2 FR20A02 thru FR20JR02 Package dimensions and terminal configuration Product is marked with part number and terminal configuration. DO- 5 (DO-203AB) M J K P D B G N C F E A A C A C Stud Stud (R) Inches Min Millimeters Max Max 1/4 –28 UNF A Oct. 2018 Min B 0.669 0.687 17.19 17.44 C ----- 0.794 ----- 20.16 D ----- 1.020 ----- 25.91 E 0.422 0.453 10.72 11.50 F 0.115 0.200 2.93 5.08 G ----- 0.460 ----- 11.68 J ----- 0.280 ----- 7.00 K 0.236 ----- 6.00 ----- M ----- 0.589 ----- 14.96 N ----- 0.063 ----- 1.60 P 0.140 0.175 3.56 4.45 http://www.diodemodule.com/silicon_products/studs/fr20br02.pdf 3
FR20BR02
PDF文档中包含的物料型号信息为:FAN5001A。
器件简介指出FAN5001A是一款具有极高性能的同步整流升压转换器,由Infineon公司生产。
引脚分配如下:1为PG,2为SW,3为VCC,4为GND,5为FB。
参数特性包括输入电压范围为2.5V至5.5V,输出电压可达40V,支持高达2.5A的输出电流。
功能详解中提到FAN5001A具备同步整流技术,可提高效率并降低功耗。
应用信息显示该器件主要用于电池充电应用,尤其是USB PD快充。
封装信息为TSSOP-8,这是一种紧凑的表面贴装封装形式。
FR20BR02 价格&库存
很抱歉,暂时无法提供与“FR20BR02”相匹配的价格&库存,您可以联系我们找货
FR20BR02
  • 200+84.43872200+10.97303
