BAV23,215
BAV23,215
    NEXPERIA(安世)
    SOT143B
    开关二极管(小信号) 200V 3.00 x 1.40mm SMT SOT143B 225mA
BAV23,215 数据手册
BAV23 series Dual high-voltage switching diodes Rev. 07 — 19 March 2010 Product data sheet 1. Product profile 1.1 General description Dual high-voltage switching diodes, encapsulated in small Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package Configuration JEDEC Nexperia BAV23A SOT23 TO-236AB dual common anode BAV23C SOT23 TO-236AB dual common cathode BAV23S SOT23 TO-236AB dual series BAV23 SOT143B - dual isolated 1.2 Features and benefits  High switching speed: trr  50 ns  Low leakage current  Repetitive peak reverse voltage: VRRM  250 V  Low capacitance: Cd  2 pF  Small SMD plastic package 1.3 Applications  High-speed switching at high voltage  High-voltage general-purpose switching 1.4 Quick reference data Table 2. Symbol Quick reference data Parameter Conditions Min Typ Max Unit IR reverse current VR = 200 V - - 100 nA VR reverse voltage - - 200 V - - 50 ns Per diode trr [1] reverse recovery time [1] When switched from IF = 10 mA to IR = 10 mA; RL = 100 ; measured at IR = 1 mA. BAV23 series Nexperia Dual high-voltage switching diodes 2. Pinning information Table 3. Pin Pinning Description Simplified outline Graphic symbol BAV23A 1 cathode (diode 1) 2 cathode (diode 2) 3 common anode 3 3 1 2 1 2 006aab099 BAV23C 1 anode (diode 1) 2 anode (diode 2) 3 common cathode 3 3 1 2 1 2 006aab034 BAV23S 1 anode (diode 1) 2 cathode (diode 2) 3 cathode (diode 1), anode (diode 2) 3 3 1 2 1 2 006aaa763 BAV23 1 cathode (diode 1) 2 cathode (diode 2) 3 anode (diode 2) 4 anode (diode 1) 4 1 3 4 3 2 1 2 006aab100 BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 3. Ordering information Table 4. Ordering information Type number Package Name Description Version - plastic surface-mounted package; 3 leads SOT23 BAV23 - plastic surface-mounted package; 4 leads SOT143B Table 5. Marking codes BAV23A BAV23C BAV23S 4. Marking Type number Marking code[1] BAV23A *V0 BAV23C *V9 BAV23S *V5 BAV23 *L3 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit - 250 V Per diode VRRM repetitive peak reverse voltage VR reverse voltage IF BAV23_SER_7 Product data sheet forward current IFRM repetitive peak forward current IFSM non-repetitive peak forward current square wave - 200 V [1] - 225 mA [2] - 125 mA - 625 mA [3] tp = 1 s - 9 A tp = 100 s - 3 A tp = 10 ms - 1.7 A All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 13 BAV23 series Nexperia Dual high-voltage switching diodes Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tamb  25 C - 250 mW Tj Tamb junction temperature - 150 C ambient temperature 65 +150 C Tstg storage temperature 65 +150 C Per device [1] [4] Single diode loaded. [2] Double diode loaded. [3] Tj = 25 C prior to surge. [4] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 7. Symbol Thermal characteristics Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point Min Typ Max Unit - - 500 K/W - - 360 K/W Per device [1] [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 7. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit forward voltage IF = 100 mA - - 1.0 V IF = 200 mA - - 1.25 V VR = 200 V - - 100 nA VR = 200 V; Tj = 150 C - - 100 A - - 2 pF - - 50 ns Per diode VF IR Cd diode capacitance trr reverse recovery time [1] BAV23_SER_7 Product data sheet reverse current f = 1 MHz; VR = 0 V [1] When switched from IF = 10 mA to IR = 10 mA; RL = 100 ; measured at IR = 1 mA. All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 006aab212 600 mbg703 102 IFSM (A) IF (mA) 10 400 (2) 200 (1) 1 (3) (4) 10−1 0 0 0.4 0.8 1.2 10 1 1.6 102 103 104 tp (μs) VF (V) (1) Tamb = 150 C Based on square wave currents. (2) Tamb = 85 C Tj = 25 C; prior to surge (3) Tamb = 25 C (4) Tamb = 40 C Fig 1. Forward current as a function of forward voltage; typical values Fig 2. Non-repetitive peak forward current as a function of pulse duration; maximum values 006aab213 102 IR (μA) 10 (1) (2) 1 10−1 (3) 10−2 10−3 10−4 (4) 10−5 0 50 100 150 200 250 VR (V) (1) Tamb = 150 C (2) Tamb = 85 C (3) Tamb = 25 C (4) Tamb = 40 C Fig 3. Reverse current as a function of reverse voltage; typical values BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 13 BAV23 series Nexperia Dual high-voltage switching diodes mbg447 1.0 006aab214 300 Cd (pF) IF (mA) (1) 0.8 200 0.6 (2) 100 0.4 0.2 0 2 4 6 VR (V) 0 8 0 f = 1 MHz; Tamb = 25 C 50 100 150 200 Tamb (°C) FR4 PCB, standard footprint (1) Single diode loaded. (2) Double diode loaded. Fig 4. Diode capacitance as a function of reverse voltage; typical values Fig 5. Forward current as a function of ambient temperature; derating curves 8. Test information tr t D.U.T. RS = 50 Ω V = VR + IF × RS tp 10 % + IF IF SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω VR (1) 90 % mga881 input signal output signal (1) IR = 1 mA Fig 6. Reverse recovery time test circuit and waveforms BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 9. Package outline 3.0 2.8 3.0 2.8 1.1 0.9 1.1 0.9 1.9 3 4 3 0.45 0.15 2.5 1.4 2.1 1.2 2.5 2.1 1 1 2 0.48 0.38 1.9 2 0.88 0.78 0.15 0.09 0.48 0.38 0.15 0.09 1.7 Dimensions in mm Fig 7. 0.45 0.15 1.4 1.2 04-11-04 Package outline SOT23 (TO-236AB) Dimensions in mm Fig 8. 04-11-16 Package outline SOT143B 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BAV23A Package Description Packing quantity 3000 10000 SOT23 4 mm pitch, 8 mm tape and reel -215 -235 SOT143B 4 mm pitch, 8 mm tape and reel -215 -235 BAV23C BAV23S BAV23 [1] BAV23_SER_7 Product data sheet For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 11. Soldering 3.3 2.9 1.9 solder lands solder resist 3 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 Fig 9. sot023_fr Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig 10. Wave soldering footprint SOT23 (TO-236AB) BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 3.25 0.6 (3×) 0.5 (3×) 1.9 solder lands 0.7 0.6 (3×) (3×) solder resist 2 solder paste 3 occupied area 0.7 0.6 Dimensions in mm 0.75 0.95 0.9 1 sot143b_fr Fig 11. Reflow soldering footprint SOT143B 4.45 2.2 1.2 (3×) 1.425 (3×) solder lands solder resist 4.6 2.575 occupied area Dimensions in mm 1.425 preferred transport direction during soldering 1 1.2 sot143b_fw Fig 12. Wave soldering footprint SOT143B BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 9 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BAV23_SER_7 20100319 Product data sheet - BAV23_SER_6 Modifications: BAV23_SER_6 • • • • • • Type numbers BAV23A/DG, BAV23C/DG, BAV23S/DG and BAV23/DG deleted Type numbers BAV23A and BAV23C added Table 5 “Marking codes”: updated Figure 6: adaptation of test condition to specified characteristics in Table 8 Figure 9, 10, 11 and 12: updated Section 13 “Legal information”: updated 20080303 Product data sheet - BAV23S_5 BAV23_2 BAV23S_5 20011012 Product specification - BAV23S_4 BAV23_2 19960917 Product specification - BAV23_1 BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 10 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or BAV23_SER_7 Product data sheet malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 11 of 13 BAV23 series Nexperia Dual high-voltage switching diodes 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BAV23_SER_7 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 07 — 19 March 2010 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BAV23 series Dual high-voltage switching diodes 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 March 2010
BAV23,215 价格&库存
很抱歉,暂时无法提供与“BAV23,215”相匹配的价格&库存,您可以联系我们找货
BAV23,215
  • 5+0.36144
  • 20+0.33010
  • 100+0.29876
  • 500+0.26742
  • 1000+0.25280
  • 2000+0.24235
