BAT54CTR
BAT54CTR
    SMCDIODESOLUTIONS(桑德斯)
    SOT-23
    DIODEARRAYSCHOTTKY30VSOT23
BAT54CTR 数据手册
BAT54/A/C/S SURFACE MOUNT SCHOTTKY BARRIER DIODE Technical Data Data Sheet N0123, Rev. C Green Products BAT54/A/C/S SCHOTTKY RECTIFIER Applications: • Small signal switching Features: • • • • • • • • • Negligible switching losses Very small conduction losses Low forward voltage drop Surface mount device Double diodes with different pining are available Schottky barrier diodes encapsulated in a SOT-23 small SMD packages This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In Inches / mm SOT-23 Package BAT54C Common Cathode BAT54A Common Anode BAT54 Single BAT54S Series • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • BAT54/A/C/S SURFACE MOUNT SCHOTTKY BARRIER DIODE Technical Data Data Sheet N0123, Rev. C Green Products Marking Diagram: KL1/KL2/KL3/KL4 BAT54 = Part Name BAT54A BAT54C BAT54S Note: If date code is before 16221, please contact with factory about marking. Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device BAT54/A/C/S Package Shipping SOT-23(Pb-Free) 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • BAT54/A/C/S SURFACE MOUNT SCHOTTKY BARRIER DIODE Technical Data Data Sheet N0123, Rev. C Green Products Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Power dissipation# Symbol VRRM VRWM VR Condition - Max. Units 30 V IF(AV) 50% duty cycle @TC =80°C, rectangular wave form 0.2 A IFSM 8.3 ms, half Sine pulse 0.6 A Ptot Tamb = 25 °C 200 mW Max. 0.24 0.32 0.40 0.50 1.0 Units V 2.0 μA 100 μA 10 pF 5 ns # for double diodes, Ptot is the total dissipation of both diodes. Electrical Characteristics: Characteristics Forward Voltage Drop(per leg)* Reverse Current(per leg)** Symbol VF1 IR1 IR2 Junction Capacitance (per leg) Reverse Recovery Time CT trr Condition @ 0.1mA, Pulse, TJ = 25 °C @ 1mA, Pulse, TJ = 25 °C @ 10mA, Pulse, TJ = 25 °C @ 30mA, Pulse, TJ = 25 °C @ 100mA, Pulse, TJ = 25 °C @VR = rated VR, Pulse, TJ = 25 °C @ VR = rated VR, Pulse, TJ = 100°C @VR = 5.0 V, Tc=25℃ fSIG = 1MHz IF=10mA IR = 10mA TJ = 25 °C Irr =1 mA RL=100Ω Pulse test: * tp=380ms, δ
BAT54CTR 价格&库存
很抱歉,暂时无法提供与“BAT54CTR”相匹配的价格&库存,您可以联系我们找货
