MBRB20100CTTR
MBRB20100CTTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    DIODE ARRAY SCHOTTKY 100V D2PAK
MBRB20100CTTR 数据手册
MBRB20100CT Technical Data Data Sheet N0791, Rev. A Green Products MBRB20100CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In mm): Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBRB20100CT Technical Data Data Sheet N0791, Rev. A Green Products OPTION 2(MX) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRB20100CT Technical Data Data Sheet N0791, Rev. A Green Products OPTION 3(CJ) D²PAK • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRB20100CT Technical Data Data Sheet N0791, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 20 100 CT SSG YY WW L = Device Type = Package type = Forward Current (20A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package D²PAK (Pb-Free) MBRB20100CT Shipping 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. 100 Units V IF (AV) 50% duty cycle @TC =105°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRB20100CT Technical Data Data Sheet N0791, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current at DC condition (per leg) * Reverse Current (per leg) * Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.76 0.84 0.63 0.70 0.0015 Max. 0.80 0.90 0.70 0.80 1.0 Units V 4.0 6.0 mA 200 250 pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C °C/W 1.41 g V mA Pulse Width < 300µs, Duty Cycle
MBRB20100CTTR 价格&库存
很抱歉,暂时无法提供与“MBRB20100CTTR”相匹配的价格&库存,您可以联系我们找货
