MBRB30100CTTR
MBRB30100CTTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    DIODEARRAYSCHOTTKY100VD2PAK
MBRB30100CTTR 数据手册
MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products MBR30100CT /MBRB30100CT /MBR30100CT-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBR30100CT TO-220AB Case styles MBRB30100CT D2PAK MBR30100CT-1 TO-262 Mechanical Dimensions: In Inches / mm TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° D2PAK TO-262 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 30 100 CT/CT-1 SSG YY WW L MBR30100CT = Device Type = Package type = Forward Current (30A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number MBRB30100CT Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) D²PAK (Pb-Free) MBR30100CT MBRB30100CT Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current(per device) Peak Repetitive Forward Current(per leg) Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFRM IFSM Condition 50% duty cycle @TC = 133°C, rectangular wave form Rated VR square wave, 20KHz TC = 133°C Max. 100 30 Units V A 20 A 8.3 ms, half Sine pulse 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * IR1 IR2 Junction Capacitance (per leg) Max. Voltage Rate of Change * CT dv/dt Condition @ 15 A, Pulse, TJ = 25 °C @ 30 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @ 30 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.85 1.05 0.70 0.85 1.00 Units V 15.0 mA 500 pF 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C 50 °C/W 0.50 °C/W V mA Pulse Width < 300µs, Duty Cycle
MBRB30100CTTR
物料型号: - MBR30100CT - MBRB30100CT - MBR30100CT-1
器件简介: 这些是肖特基整流器,适用于开关电源、转换器、飞轮二极管和防反接保护等应用。
它们具有150°C的工作结温、中心抽头配置、低正向电压降、高纯度、耐高温环氧封装以增强机械强度和防潮性能、高频率操作和增强的鲁棒性及长期可靠性。
引脚分配: - MBR30100CT:TO-220AB封装,有3个引脚。
- MBRB30100CT:D2PAK封装,有3个引脚。
- MBR30100CT-1:TO-262封装,有3个引脚。
参数特性: - 最大额定反向电压:100V - 平均正向电流(每个二极管):在133°C时,50%占空比下为30A - 正向电压降:在25°C下,15A时为0.85V,30A时为1.05V;在125°C下,15A时为0.70V,30A时为0.85V - 反向电流:在25°C下,额定反向电压时为1.00mA;在125°C下,额定反向电压时为15.0mA - 结电容:在5V反向电压下,1MHz时为500pF
功能详解: 这些肖特基二极管具有低正向电压降和高效率,适用于高频开关电源和电机驱动等应用。
中心抽头配置允许在全波整流应用中使用。
高纯度封装材料提供了良好的机械强度和防潮性能,而增强的鲁棒性则确保了长期可靠性。
应用信息: 适用于开关电源、转换器、飞轮二极管和防反接保护等应用。
封装信息: - MBR30100CT:TO-220AB封装,50pcs/管 - MBRB30100CT:D2PAK封装,800pcs/卷 - MBR30100CT-1:TO-262封装
请注意,这些信息是基于PDF文档内容的中文分析,具体应用时还需参考最新的产品数据手册。
MBRB30100CTTR 价格&库存
很抱歉,暂时无法提供与“MBRB30100CTTR”相匹配的价格&库存,您可以联系我们找货
