MBRF1045CT
MBRF1045CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODEARRAYSCHOTTKY45VITO220
MBRF1045CT 数据手册
MBRF1045CT Technical Data Data Sheet N0820, Rev. A Green Products MBRF1045CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions (In mm): SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF1045CT Technical Data Data Sheet N0820, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 10 45 CT SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF1045CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Rectified Output Current(per device) Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Io IFSM Condition 50% duty cycle @TC =80°C, rectangular wave form Max. 45 Units V 10 A 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF1045CT Technical Data Data Sheet N0820, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 5A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125°C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.70 0.57 1.0 Units V V mA 15 mA 300 pF 10,000 V/μs Pulse Width < 300µs, Duty Cycle
MBRF1045CT
物料型号:MBRF1045CT 器件简介:肖特基整流器,用于开关电源转换器、自由轮流通路二极管和反向电池保护。
引脚分配:ITO-220AB封装,中心抽头配置。
参数特性:最大反向电压45V,正向电流10A,正向电压低,结电容300pF,dv/dt 10,000V/µs。
功能详解:150°C TJ操作,高纯度、高温度环氧树脂封装,高频率操作,保护环提高耐用性和长期可靠性。
应用信息:适用于开关电源、转换器、自由轮流通路二极管和反向电池保护。
封装信息:ITO-220AB封装,50pcs/管,符合无铅标准。
以上信息摘自SMC MBRF1045CT的PDF数据手册。
MBRF1045CT 价格&库存
很抱歉,暂时无法提供与“MBRF1045CT”相匹配的价格&库存,您可以联系我们找货
