MBR10150CT
MBRB10150CT
MBR10150CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Data Sheet N0036, Rev. -
Green Products
MBR10150CT/MBRB10150CT/MBR10150CT-1
SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
MBR10150CT
TO-220AB
Case styles
MBRB10150CT
D2PAK
MBR10150CT-1
TO-262
Mechanical Dimensions: In Inches / mm
TO-220AB
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
MBR10150CT
MBRB10150CT
MBR10150CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
0.10
2.69
0.81
1.27
0.38
1.27
8.70
0.61
1.37
8.85
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
4.85
0.25
2.89
0.96
15.6
2.70
1.40
2.20
8°
D2PAK
TO-262
MBR10150CT
MBRB10150CT
MBR10150CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
= Device Type
B
= Package type
10
= Forward Current (10A)
150
= Reverse Voltage (150V)
CT/CT-1 = Configuration
SSG
= SSG
YY
= Year
WW
= Week
L
= Lot Number
MBR10150CT
MBRB10150CT
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
D²PAK
(Pb-Free)
MBR10150CT
MBRB10150CT
Shipping
50pcs / tube
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Average Forward Current
Symbol
VRWM
IF(AV)
Peak One Cycle NonRepetitive Surge Current
(per leg)
IFSM
Condition
50% duty cycle @TC =105°C,
rectangular wave form
Max.
150
10
Units
V
A
8.3 ms, half Sine pulse
138
A
MBR10150CT
MBRB10150CT
MBR10150CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop(per
leg)*
Reverse Current (per leg)*
Symbol
VF1
VF2
IR1
IR2
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Voltage Rate of Change
CT
LS
dv/dt
Condition
@ 5A, Pulse, TJ = 25 °C
@ 5A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Max.
0.93
0.73
1.00
Units
V
V
mA
7.0
mA
200
pF
8.0
nH
10,000
V/μs
Specification
-55 to +150
-55 to +150
4.5
Units
°C
°C
°C/W
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR10150CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.57040
- 50+2.01960
- 150+1.79280
- 500+1.50120
- 2000+1.37160
- 5000+1.28520
- 国内价格 香港价格
- 1+9.648571+1.20682
- 50+4.4803350+0.56039
- 100+3.97012100+0.49658
- 500+3.07247500+0.38430
- 1000+2.783311000+0.34813
- 2000+2.539912000+0.31769
- 5000+2.276465000+0.28474
- 10000+2.1136710000+0.26437
