MBRF10100CTR
MBRF10100CTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF10100CTR 数据手册
SANGDEST MICROELECTRONICS MBRF10100CTR Technical Data Data Sheet N0078, Rev. A Green Products MBRF10100CTR SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB(HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10100CTR Technical Data Data Sheet N0078, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 10 100 CTR SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF10100CTR Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Max. 100 Units V Average Forward Current IF(AV) 50% duty cycle @TC =105 °C rectangular wave form 10 A Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 120 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10100CTR Technical Data Data Sheet N0078, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current at DC condition (per leg) Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt VISO Condition @ 5A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.85 0.75 Units V V 1.0 mA 15 mA 300 pF 8.0 nH 10,000 V/μs 4500 V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF10100CTR
物料型号为MBRF10100CTR,属于Sangdest Microelectronics公司的绿色产品系列。
这是一款肖特基整流器,适用于开关电源转换器、续流二极管、反向电池保护等。
主要特性包括150°C的工作结温、中心抽头配置、低正向电压降、高纯度、高温环氧封装、高频操作、加固环以提高鲁棒性和长期可靠性,并且是无铅设备。
引脚分配封装信息如下: - 中心抽头配置 - 机械尺寸以毫米为单位,包括A、A1、A2、b、b1、b2、b3、b4、C、D、E等尺寸参数 - 封装型号为ITO-220AB(HD)
参数特性包括: - 最大额定值:包括峰值反向电压(VRWM)为100V,平均正向电流(F(AV))为10A等 - 电气特性:如正向电压降(VF1, VF2)、直流条件下的反向电流(IR1, IR2)、结电容(CT)、典型串联电感(Ls)、电压变化率(dv/dt)等
功能详解应用信息: - 该器件适用于高频操作,具有低正向电压降,能够提高能效 - 中心抽头配置使其在某些应用中具有优势,例如用于电流平衡或反向电压保护 - 加固环设计增加了器件的鲁棒性,延长了使用寿命
附加信息: - 所有SMC部件都可以追溯到晶圆批次 - 可以根据要求提供额外的测试 - 订购信息包括器件型号、封装类型和运输方式,例如MBRF10100CTR的ITO-220AB(Pb-Free)封装,每管50件
免责声明中提到,所提供的信息包括规格和尺寸可能会在不通知的情况下更改,以改进产品特性。
在订购前,购买者应联系SMC - Sangdest Microelectronics (Nanjing) Co., Ltd销售部门获取最新版本的数据手册。
MBRF10100CTR 价格&库存
很抱歉,暂时无法提供与“MBRF10100CTR”相匹配的价格&库存,您可以联系我们找货
